For the love of English 3 speeds...
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
Hi folks. I'm just about at the test ride stage of this build. 700c wheels with sturmey archer four speed hub and dynohub. For those who have worked on dynohubs, what level of play at the hub when installed and tight is to be expected? I've followed the proper procedure for cones and what not. Just seems to have more than a hint of play. Chain line is 95 percent. It might need to be a bit tighter. I may adjust the wheel position in the dropouts. Before the pandemic hit I was going to have a more modern alloy 26mm seat post brought down to 24mm, but it's too late. For the moment I'm stuck with the old one. Apart from that the headset is original (and in great shape). Handlebar is a Sakae unit off of my Voyageur. Original mafac calipers with kool stop pads and the Dia Compe levers off the Voyageur. Thoughts on the dynohub play? The FW is shifting beautifully.
At least here in Minnesota, bike shops are considered an 'essential industry' as they are in the transportation sector.
Likes For Salubrious:
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 467 Times
Generally speaking, one of the differences between four-speeds and 3-speeds is that there really shouldn't be any play in the cones of a four-speed.
Thanks for the tip about the cones. There is no discernible play in the four-speed hub. It is very smooth and the cranks do not rotate when the bike is pushed forward. Tomorrow is going to be sunny so I'm going to take the bike out at lunchtime for the shakedown.
Likes For Ged117:
Quoted: 1299 Post(s)
Liked 103 Times
Good to see you. This is a great thread you started. I thought I was all alone with my English roadster hobby until I found this nice group.
Inflate Hard
Inflate Hard
Bikes: 1972 Raleigh Tourist
Quoted: 27 Post(s)
Liked 14 Times
glad to be here, Big Chief
while it's still abit to cold and windy, my old faithful Raleigh Tourist beckons..
as ever, Julius in Ohio
Quoted: 86 Post(s)
Liked 78 Times
I got in a nice 20 mile spin, beautiful day today.
Likes For thorstein:
Quoted: 457 Post(s)
Liked 462 Times
Head tube angle looks absurdly laid back on that bike, I see the rear tire is slightly lower than the front tire, but...
Liked 103 Times
I think the frame geometry is what makes these bikes so comfortable on poor road surfaces. My DL-1 is much nicer to ride on bumpy and gravel roads than my Sports.
Inflate Hard
Inflate Hard
Likes For BigChief:
Quoted: 86 Post(s)
Liked 78 Times
Braking has improved since I installed Kool Stop brake shoes, made some slight adjustments to the linkages, & got the wheels trued - not that the braking was that bad to begin with. I've never understood the comments about horrid stopping power with rod brakes, but maybe that's because the brakes on my Tourist were set up well when I got it?
The brakes on my Raleigh Twenty, that I understand! The rear calipers flex & even with new pads they don't grab the rim.
Liked 103 Times
Yes, quite laid back; I think the lack of fenders accentuates the slack angles. It is such a smooth ride! I agree that the angles probably contribute to the ride quality, but I think the tall wide tires also play a part.
Inflate Hard
Inflate Hard
Quoted: 86 Post(s)
Liked 78 Times
Kool Stop inserts are the best pads I've found. I can see that you also have the proper distance between the brake levers and the hand grips. This helps a lot. Sometimes they get bent in too close and need to be bent out again. I also think there is some advantage to mount the front brake pads leading the stirrup like you have.
Here is my 1971 Tourist DL-1 w/28" wheels and rod brakes. Paint, chrome and Dunlop Roadster tires all original.
Likes For JIMBO53:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
Likes For clubman:
Bikes: Western Flyer, Schwinn, Rollfast, Gambles, J.C. Higgins, Waverley, Crescent, Hercules, Nishiki, Huffy, Mohawk, AMF, Electra, A ridable replica hi-wheel and a few others.
Quoted: 42 Post(s)
Liked 45 Times
Thanks!
Quoted: 457 Post(s)
Liked 462 Times
Likes For jackbombay:
Quoted: 360 Post(s)
Liked 467 Times
I took the Peugeot with an FW alloy four-speed out for a shakedown ride yesterday. The FW shifts really nicely - I'm very happy about that. A few adjustments of the stem and seatpost to be made and of course handlebar tape.
Likes For Ged117:
Liked 103 Times
Later Raleigh front rod brakes use arms that offset the pads from the center line of the stirrup. This was done to smooth out the braking action making it less grabby. You can either mount the pad assembly in front or behind the stirrup. Mounting it behind the stirrup would be "leading" considering the direction the wheel rotates.
Inflate Hard
Inflate Hard
Liked 103 Times
For anyone replacing rod brake pads the first time, I'll pass along my experience. Kool Stop salmon pads are meant to be used with the original Raleigh pad holders. The holders have a split tube formed into them that is closed at one end and open at the other. So you must be careful to mount the assembly on the bike in the right direction. What you do to install the new pads is open a vise just enough to catch the sides of the tube and use a hammer and punch to drift out the old pads and press the new ones in. The Kool Stop pads have curved tops that match the radius of the rim. Now, you can also buy Fibrax pads that come complete with holders that are closed on both ends, but they are not curved to match the rim. I suppose you are expected to let them wear into shape. I've tried this. It doesn't work. With only the front and rear edges of the pads contacting the rim, it's like having no brakes at all. I highly recommend using Kool Stops in the original pad holders.
Inflate Hard
Inflate Hard
Quoted: 86 Post(s)
Liked 78 Times
Rod brake shoe/pad install/remove
Quoted: 86 Post(s)
Liked 78 Times
If the brake shoe is put on the other side, it isn't pushed up into the rim, so it doesn't grab as much.
Quoted: 26 Post(s)
Liked 113 Times
I've kindly been given this Elswick 1960 Light Roadster, as it was going to be thrown away. Here are a few photos, as first seen, after decades in a garage. I have no experience of classic 3 speed roadsters.
There's a lot of character there and I'm happy it has been saved from the bike graveyard. Looking forward to catching up on a genre of bike I've completely missed out on, and a return
to the road for this lovely old bike.
Likes For avecReynolds531:
Quoted: 27 Post(s)
Liked 14 Times
avec Reynolds
Love that vintage Elswick...first that I have heard of that brand...is it an offshoot of Rudge or Raleigh?
Julius in Ohio
Julius in Ohio
Likes For julius rensch:
Quoted: 981 Post(s)
Liked 1,844 Times
https://en.wikipedia.org/wiki/Elswick_Hopper
Likes For Kilroy1988:
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
Liked 443 Times
Likes For gster:
