Dropped into LBS for Chain Lube
Quoted: 97 Post(s)
Liked 7 Times
Picture denied, not enough posts yet.
Ten speed Ultegra cs-6700 - can you tell by looking at this picture if these cogs are OK?
I just put a new chain on my bike. I thought the cogs looked OK. Have had no problems till now. Now, it seems I cannot get the gears indexed. They keep acting as if the derailleur is between gears. I try tightening the cable with the barrel adjuster, loosening... On the bike stand, pedaling by hand, sooth shifting. I start riding, chachunk... Chunk... Cha-cha, CHUNK...
Am I going to have to become the proud owner of a new cassette to run this new chain?
What are your thoughts?
Thank you.
Thank you.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
How many miles on that cassette and the old chain. It sure sounds like the cogs are not matching up with the new chain. Not unusual it they had a lot of miles.
Likes For delbiker1:
Rid'n Rev
Bikes: 2007 Felt F55, Vintage Univega, 2012 Specialized Mountain Bike
Quoted: 12 Post(s)
Liked 13 Times
I learned this the hard way. How long had you used the old chain before changing it? Did you compare the new chain's length with the old to see how much wear? The first chain I ever replaced on my old bike was OLD and the new chain jumped cogs like crazy. Like your situation - everything worked fine on a stand.
Likes For sour01:
Forum Moderator
Quoted: 3090 Post(s)
Liked 6,595 Times
Likes For cb400bill:
Cassette skips on a new chain = new cassette. You don't need a Park chain checker but it sure is convenient.
Likes For popeye:
Likes For HTupolev:
Quoted: 97 Post(s)
Liked 7 Times
Maybe I put on backward. I did not notice any difference in how the links are marked on the two sides, so I put it on so the labels are oriented right side up on the top from top of rear derailleur to chain ring, when viewed from right side of the bike.
Quoted: 97 Post(s)
Liked 7 Times
The new chain is SRAM P1051. The LBS siad this chain works with Shimano.
Likes For HTupolev:
Expired Member
Quoted: 3672 Post(s)
Liked 5,427 Times
Time for a new cassette. You have unknown mileage on that one and you can't judge wear by looking at it.
Likes For shelbyfv:
Chain skip normally occurs on only a few of the most- worn sprockets and then only upon heavy pedaling pressure.
Likes For DaveSSS:
You don't have a 6700 cassette - the lockring is clearly labelled: 7800, meaning Dura-Ace, unless someone inexplicably swapped out your lockring. The cassette doesn't look particularly worn, although if the original owner of the bike was putting in any decent miles, the chain should have been replaced at least a dozen times since purchase, and the cassette replaced 4+ times.
7800 cassettes new cost around $250 when you could get them; even used now they will fetch $50 at least. I am sure your local shop would be pleased to take this used and worthless cassette off of your hands for replacement. Then out the back door onto Ebay for mechanics beer fund money.
Are all of the cogs skipping, or only a few? Or is the problem with the chainrings? Or a mangled or mis-installed quick link? Too many vague clues here.
Likes For Dave Mayer:
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Yep. Plus I usually find my most used chainring will start jumping after about every 3rd cassette change, usually only on out of the saddle efforts.
Results matter
Results matter
Likes For Carbonfiberboy:
Quoted: 97 Post(s)
Liked 7 Times
New 6700 is available for about $60.
Not all cogs are affected. I read somewhere this problem can settle down after putting on a new chain. The problem was worse, now it is affecting 2-3 cogs in the middle of the rear cassette, when running the small chain ring.
The quick links appears correctly installed and moves as freely as any of the other links.
The chain rings are not jumping at all.
Quoted: 33 Post(s)
Liked 21 Times
chain routed correctly through the derailleur pulleys?
I have replaced about a zillion chains. In my haste a couple of chains ago, I accidentally threaded the chain over one of the metal guides on the rear derailleur. I rode the bike for a number of miles but things were not shifting just right. Came home to find out I screwed up how chain was routed. Fixed in about 2 minutes.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
OP I am disappointed, I clicked thinking this was going to be a new bike thread.
Likes For znomit:
NYC
Quoted: 1169 Post(s)
Liked 107 Times
IME chain skip is more often caused by
a misaligned [derailleur] hanger
than by a worn cassette, and we never think of the derailleur hanger first.
Quoted: 1163 Post(s)
Liked 442 Times
How do rear dropouts outs suffer that type of paint chipping? Just curious.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Thank you.
Thank you.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Port
Quoted: 985 Post(s)
Liked 1,864 Times
hanger is bent
