Removing your Front Derailleur Permanently
Old 06-22-05, 08:08 AM
mx_599
Lost in the Black Hills
mx_599's Avatar
I noticed some people convert their MTB to a single speed. I just had the thought of making a bike an 8-speed or something close.
Do people do this?? Remove the front derailleur and two of the spockets and then just leave the 8 sprockets in the rear? Or are there major drawbacks or issues I am not thinking about?
Okay...so if people do this and it is not stupid, are the following assumptions correct?
1) I can remove my front derailleur and shifter assembly from my handlebars.
2) I can simply have a single sprocket and a bashring upfront.
3) The best choice of sprocket up front would be the middle one??
Riding: non-serious XC and goofing around. I was thinking simplifying the 24-speed would be "a change".
mx_599 is offline
Old 06-22-05, 08:22 AM
cydewaze
Emondafied
cydewaze's Avatar
Bikes: See sig
Quoted: 63 Post(s)
I've been thinking about this too - for different reasons.
I have an awesome hardtail MTN bike that has a braze-on front derailleur. The braze-on broke off a number of years ago, and I had it repaired, but it's been very hard to find a derailleur for it (the old one rusted badly).
I was thinking of going with a single 30 or 32t up front, and an 11-34 out back. The bike climbs like a billygoat, and I rarely used the small ring up front anyway. I'll be paying attention to the replies this thread gets.
my bike page - my journal
Current Stable: Trek Emonda SL - Trek Top Fuel 8 - Scattante XRL - Jamis Dakar Expert - Trek 9700 - AlpineStars Al Mega
cydewaze is offline
Old 06-22-05, 08:32 AM
ndelaude
My only concern would be the chain line running at extreme angles. But I've never done it. someone here has to know....
ndelaude is offline
Old 06-22-05, 08:33 AM
dutret
It is possible(I did once with a 6s), but the chain may occaisionally come off espcially if you don't switcht to a ss chainring. The extra width of the 8s cassette may make this even more likely.
dutret is offline
Old 06-22-05, 08:45 AM
SpiderMike
eert a ekil yzarc
SpiderMike's Avatar
Bikes: many bikes
Originally Posted by mx_599
...Do people do this?? Remove the front derailleur and two of the spockets and then just leave the 8 sprockets in the rear? Or are there major drawbacks or issues I am not thinking about?
Been there done it. I had a front D poop out on me, and went to "Manual Shifting" for at least 2 years. I have seen "8" or "9" speed bikes (especially in Downtown areas). From the start I thought chain skipping of would be a bad thing...sure it happened but nowhere as frequent as I had thought.
1. If its broke take em off.
2. Leave them their, this will eliminate your need to choose which to keep for number 3.
3. See number 2.
Oh and I am going to PM ya on the Lyric challenge
SpiderMike is offline
Old 06-22-05, 09:01 AM
TheOtherGuy
Knows Bigfoot's Momma
Bikes: yeah; got a couple...
That's my only concern too, as I've been wanting to do the same on a weight weenie bike. The extreme chain angles in either the high or low couple of cogs could cause problems with excessive wear (both to chain and cogs/chainring). Although some people don't pay attention to it, each chainring is really only comfortable on about 3 cogs it's most in line with...
nice lugs baby!
TheOtherGuy is offline
Old 06-22-05, 09:21 AM
SpiderMike
eert a ekil yzarc
SpiderMike's Avatar
Bikes: many bikes
One thing I wish I had was a chain guide, like I've seen on some DH rigs. Something like the Kore Chain Reactor. https://www.kore-usa.com/index.html click Drive and go to Chain Reactor.
Old 06-22-05, 01:43 PM
mx_599
mx_599's Avatar
So I am thinking if I did this to stay away from using the #1 and #8 cog? Then it would probably work good?
mx_599 is offline
Old 06-22-05, 02:23 PM
TheOtherGuy
Yeah; that would probably work OK if you just kept the middle ring. It would be best if you just used 3,4,5, and 6, - at least as far as chain and gear life goes. I have a road bike set up as a 5 speed, using a single chainring in the outer position, and it's not really happy on the big cog in back... You can see that chain line is pretty far off.
nice lugs baby!
Old 06-22-05, 04:07 PM
dooley
I run a 5 speed block on my commuter and the chain line slightly favours the larger sprockets, it runs perfectly.
If you do decide to use only 6 of the 8 sprockets it might be worth swapping the largest and smallest into the mix and adjusting their positions on the freehub to get the chainline right.
dooley is offline
Old 06-22-05, 04:11 PM
dirtbikedude
Gravity Is Yer Friend
dirtbikedude's Avatar
Location: "Over the Hill" and going down fast in the 805.
Bikes: Scott Gambler, Scott Ransom, Kona Bear, Bianchi 928 Carbon/Chorus, C'Dale Rize4
The Reactor will take the slack out of the chain but it does float from side to side so you can shift gears and on a big enough hit can allow the chain to drop off. If you do not want to get new cranks then use the middle ring w/a bash guard on the out side. The easiest way to do this would be to get an MRP System 3
You will get a bashring and a guide but no inner plate which will save some weight. It should bolt right up to your current cranks. I have found some crants wont accept the bash guard with out a bit of filling but it is not much.
;beer:
dirtbikedude is offline
Old 06-22-05, 04:51 PM
alcahueteria
alcahueteria's Avatar
Bikes: Specialized AWOL, Soma Juice
A friend of mine's urban bike is like that. The chain only popped off on me once when I borrowed it for two weeks, and that was after a jump. He had an inner and outer bashgaurd, but it didn't really do anything for the chainline.
alcahueteria is offline
Old 06-22-05, 05:03 PM
Eros
Keep Right Except to Pass
Here are my thoughts on the matter.
I'm running sans FD on my freeride bike with 22-32-bash. Sometimes when going up I will manually shift to the 22T with my finger. Getting it back on the 32T is a little harder but not enough to worry about. **Be careful, I don't want someone getting a mangled digit.
I only lose the chain every once in a while, maybe once or twice per rough ride.
As far as chainline worries go, how many people are actually thinking about this and shifting chainrings to keep it on the most inline cogs consistantly? Chains are cheap so this doesn't concern me much.
I would probably be running some kind of chainguide if they weren't so spendy.
Cheers
Eros is offline
Old 06-22-05, 05:06 PM
Totoro
King of the Forest
Totoro's Avatar
I have done it because I needed the front derailleur for a hybrid that I was building for my son. Anyway, I rode that bike around last summer and I never had any problems with it. Mind you, I kept the chain on the small chainring. For beginners, it may even help force a higher cadence. Beginning mountain bikers should rarely, if ever, use the large chainring.
Totoro is offline
Old 06-22-05, 05:22 PM
cryptid01
one less horse
cryptid01's Avatar
Bikes: are better than yours
Yes, but why is your front derailleur attached to your handlebars in the first place?
You will need some sort of chainguide also...I agree with dbd's recommendation of an MRP, but E.13 is also a popular option.
Yep. Your chainline will be okay. You may consider a dedicated DH type ring rather than the stock one (which has ramps and pins to aid shifting and is therefore more prone to dropping the chain), but it hasn't been an issue for me with my System 3.
cryptid01 is offline
Old 06-22-05, 05:44 PM
mx_599
mx_599's Avatar
Okay, I worded that wrong!
I was looking at that link to MRP. I am not familiar with these items yet. I need to investigate a little more and then probably post another question. But here are some initial questions:
1) Do you need any specialty tools for installation of these?
2) Do these items create a lot of drag...or not noticeable?
3) Currently I have a Bullet Bros Chain tensioner (remember those?). Would this MRP device eliminate the need for the Bullet bros tensioner? Does the MRP as pictured in the link help to prevent chain slap as well?
1) If I were to buy a dedicated DH type are all the fitments pretty standard? I don't want to buy cranks or anything.
2) What tooth # might you recommend?
3) As another poster suggested, if I am understanding him right, I could rearrange the #1-8 cogs slightly to take advantage of greater gear variability without subjecting the chain to extreme angles.
an arrangement of say... 2-1-3-4-5-6-8-7 cogs. Is this possible? A viable option?
Before anyone says, "Why the hell is he doing all this?" I don't know? I guess when I think about it, I hardly use all 24 speeds so I was just thinking of how I could simplify the bike set-up without going to a single speed either.
thanks
mx_599 is offline
Old 06-22-05, 06:23 PM
cryptid01
one less horse
cryptid01's Avatar
You will need the appropriate bottom bracket tool, as your '95 does not have ISCG mounts (three tapped holes concentric to the bottom bracket), and you'll have to sandwich the boomerang (or ISCG adapter) between the bb shell and the bb.
The MRPs are nearly unnoticeable. The E13's make more noise but I'm not sure if they create more drag.
3)Would this MRP device eliminate the need for the Bullet bros tensioner? Does the MRP as pictured in the link help to prevent chain slap as well?
Yes and Yes.
Get the one that matches your crank's bolt pattern...5x110mm, 4x104mm, etc.
That's trial and error, dependent upon your bike, trails and personal preference.
Yes and No.
You can tell them it looks much cleaner, sounds quieter, simplifies maintenance, and forces you to become a more powerful climber because you don't have the bailout option.
Old 06-22-05, 07:22 PM
mx_599
mx_599's Avatar
gastro....thanks for all that info. I need to look some things up now. Interesting.
So changing the order of cogs is not something I should do? Does the reason for this have to do with shifting problems?
mx_599 is offline
Old 06-23-05, 01:01 AM
dooley
You might be able to shift from 1 to 3 easy enough, but shifting from 6 to 8 might be too much of a jump. Look at your cassette and work out which cogs you can do without.
If you do stick with it you might want to get a custom cassette to optimise the ratios.
dooley is offline
Old 06-23-05, 03:28 AM
matheprat
matheprat's Avatar
To change the order of the cogs you MUST have a cassette, opposed to a freewheel. I assume you do? Then you'll need to separate the main cluster, probably by filing down the rivet holding them all together, and nocking it out with a hammer. You can, in theory, arrange the cogs in any order you want. However, I think the smallest cog must stay at the outside edge due to it's shape, and the way it fits on. Not sure about this though? If you don't plan on using the biggest cog (gear 1), then take it off and put a spacer there instead. That would look better than having some crazy arrangement of gears.
And you could just leave your FD on the bike, locked out over the cog your using at the front (taking the cable and shifter off). It would help keep the chain on.
matheprat is offline
Old 03-05-20, 11:25 AM
Gew
Gew's Avatar
I recently removed my front derailleur, and now chain keeps jumping off while at extreme gears (8 speed cassette). Any solution? 🤪
Gew is offline
Old 03-05-20, 12:47 PM
Happy Feet
Happy Feet's Avatar
Quoted: 1983 Post(s)
Liked 1,088 Times in 582 Posts
Which chainring did you keep? Usually the middle chainring can run up and down the cluster without crosschaining so that is the position you want with 1x.
If you swapped out the crankset for a dedicated single crank it may not have lined up the same as the old crankset. When I went from a shinano to sram setup I had to buy a different sized bottom bracket to compensate for the new/different offset.
That's your basic fix, look at the crank position, as even with adding a chain guide, if you don't have a good line you will still be crosschaining and putting the drivetrain under stress.
Happy Feet is offline
Old 03-05-20, 01:54 PM
prj71
Quoted: 1269 Post(s)
Liked 148 Times in 112 Posts
Wow...15 year old zombie thread.
Narrow/Wide chainring takes care of this issue. If you find one to fit your crank then problem solved.
prj71 is offline
Likes For prj71:
Old 03-05-20, 04:46 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 2267 Post(s)
Liked 941 Times in 621 Posts
Prophecy!
@Gew It's less satisfying, but you can leave the derailleur on and use it for a chain guide. OR, most inexpensive 1x town and kid bikes have a bash guard on either side of the ring that serves as a guide.
Genesis 49:16-17
Darth Lefty is online now
