Swapping drive train
Old 03-26-20, 12:56 PM
Chad991
Chad991's Avatar
Bikes: Lynsky Helix Pro
Quoted: 33 Post(s)
Liked 40 Times in 28 Posts
I have a problem I'm hoping you guys could help with. I have a Cannondale Trail 7 29er. I was kinda clueless when I bought it and was told I could justupgeadewhen I wanted . Lately I have been riding bikes at work, they have the sram 112 gx..wow those are pretty slick bikes. I wanted to switch mine over to the sram nx or go 112 but was told by the lbs that sold me the bike thati couldn't due to it not being a boost frame??? And also my hub wouldn't do the 1x...is this right or wrong, would it just benefit me looking for a better frame to build on?
Chad991 is offline
Old 03-26-20, 01:45 PM
eshew
Quoted: 30 Post(s)
Liked 36 Times in 21 Posts
You probably have a shimano freehub which isn't compatible with 12 speed SRAM GX, that requires a Sram Driver hub. What you can do, if you want is most likely upgrade to a Shimano 11 speed XT drivetrain. That will allow you to go 1X and save you a bunch of cash compared to SRAM. I've got both 11 speed Shimano & 12 speed GX bikes. 12 speed GX only benefit is the 50t rear cog compared to the 46 on shimano. The shimano shift's better as well.
In terms of going 1X, shouldn't be an issue if your crank can accept bolt on chain rings. Another option is upgrading your crank and BB to a shimano SLX setup.
eshew is offline
Old 03-26-20, 02:06 PM
Chad991
Chad991's Avatar
Quoted: 33 Post(s)
Actually,that is good news, I like shimano too. I was going g to buy the package kinda like this
This group? Deore XT
Chad991 is offline
Old 03-26-20, 05:43 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
you can probably reuse the crank, unless you like matchy-matchy
qclabrat is offline
Old 03-26-20, 05:46 PM
Chad991
Chad991's Avatar
Quoted: 33 Post(s)
And with shimano,I won't have to muck with the hub?
Chad991 is offline
Old 03-27-20, 03:27 AM
nomadmax
Quoted: 783 Post(s)
Liked 1,027 Times in 523 Posts
What I know about the 1x thing you can put in a thimble. But aren't the 1x chainring teeth different than the standard 2x, 3x versions? Different inasmuch that they're designed to help keep the chain on?
nomadmax is offline
Old 03-27-20, 04:16 AM
DeadGrandpa
Philosopher of Bicycling
DeadGrandpa's Avatar
Bikes: Too many, yet not enough.
Quoted: 423 Post(s)
Liked 204 Times in 146 Posts
I have about the same amount of drive train knowledge, and I am aware of a "narrow-wide" protocol in the 1x version that prevents interchange of chains and chain rings from 1x to 2x or 3x.
DeadGrandpa is offline
Likes For DeadGrandpa:
Old 03-27-20, 05:23 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
good point, a NW chainring will still be cheaper than a new crank and BB.
You could even experiment with oval rings if that's your thing. I have one bike with an oval ring, and I like it, but not enough to switch all my bikes over.
Between clutch derailleurs and the NW, x-shifting and drop chains have been almost non-existent for me. I don't miss the extra gear ratios and hate some jumps, but for MTBs can deal with it. Though, I personally don't get road/gravel bikes with the 1x. I'm too picky with the right cadence over long periods to have only 11 or 12 choices. 2x furever for 700c...
qclabrat is offline
Likes For qclabrat:
Old 03-27-20, 05:26 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
btw: good to see a fellow pocket llama owner. The BF is with my brother at the moment, for packables, currently riding a Airnamal Joey. /thread steal
qclabrat is offline
Old 03-27-20, 10:47 AM
Canker
Quoted: 232 Post(s)
Liked 79 Times in 45 Posts
12 speed will work fine you just have to run a cassette like Sunrace's 11-50 12 speed cassette that still use the standard freehub.
Canker is offline
Old 03-27-20, 03:54 PM
Chad991
Chad991's Avatar
Quoted: 33 Post(s)
Well thanks all for the good news, I am going to go with the shimano like others have suggested...probably order the build kit I posted above and enlist Nomadmax to run point on putting it together for me,lol....I'm not nearly the bicyclists most of you guys are and I doubt I would ever notice the difference between an 11 or 12 speed out in the dirt.
Chad991 is offline
Likes For Chad991:
