Going from a suspension to rigid fork...help with bearings?
Old 03-29-20, 07:17 PM
batpot
Quoted: 5 Post(s)
It's been a while since I've put a head tube together, but know I need a cup to be pressed into the replacement fork. Going to be a surly fork (probably ogre, but maybe 27.5 ecr) - straight, so it's going to be significantly narrower than the current fork and bottom of the head tube.
So the bottom line: Will I need to replace the bottom of the head tube also, or just add a cup to the new fork, and get the right size bearing?
batpot is offline
Old 03-30-20, 05:42 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
It's the other way around, cup on the lower head tube and a headset race on the fork steerer. Just look at a headset diagram on the web like cane Creek.
qclabrat is offline
Old 03-31-20, 12:27 AM
batpot
Quoted: 5 Post(s)
Thanks, yeah, same difference.
i haven't taken the old fork off, but it's a very good possibility it's a straight fork anyway, so even better.
​​​​​​On a related subject, Surly recommended getting a fork length ~10% shorter than the fully unsprung length of the suspension fork. That would put me at a bridge club fork vs an ogre/ecr.
But I'm still heading towards Ogre at 5% less.
Any thoughts on length?
batpot is offline
Old 03-31-20, 12:40 AM
dabac
Quoted: 1000 Post(s)
Liked 196 Times in 147 Posts
That surprises me. The general recommendation when going from sus to rigid - assuming you want least amount of change to handling - is to look for a fork that matches the ”sagged” height of the sus fork. ”Sag” meaning how much the fork compresses with rider on the bike, rolling along casually.
And sag is usually recommended to be considerably more than 10%.
The sus-to-rigid swaps I’ve made, I’ve always aimed for the sagged height, or shorter.
dabac is offline
Likes For dabac:
Old 03-31-20, 05:50 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Which frame is this going on?, sag is one of the biggest contributors. Along with offset/rake and your riding expectations.
qclabrat is offline
Old 04-01-20, 08:56 AM
unterhausen
Randomhead
Liked 991 Times in 734 Posts
The rule of thumb I have always heard is 25% sagged.
You are going to need a conversion headset, it sounds like
unterhausen is offline
Old 04-02-20, 12:44 AM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 2262 Post(s)
Liked 936 Times in 618 Posts
25% of the travel is like 1.25 in or 30mm for most hard tails today. 10% of the fork length is like 50mm or two inches. So there’s a disconnect somewhere.
while this does change the geometry, it’s not going to explode and kill you if you get it wrong.
Darth Lefty is online now
Old 04-05-20, 08:10 PM
batpot
Quoted: 5 Post(s)
The ogre and ecr are identical, except some versions of the ogre have canti mounts.
And I ended up getting ~40 cm shorter, which is only about 5% of the overall axlebto crown length, but 25% 5if there total fork range of travel, so it's right in the where it should be based on above.
Surly rep meant 10-20% of sag; believe I misunderstood what he was saying, and paraphrased incorrectly.
I also pinged Cannondale find out what headset bearings they use, but haven't heard back yet.
batpot is offline
