A little Disc Help Pls
Old 09-25-20, 02:38 AM
daviddavieboy
daviddavieboy's Avatar
Bikes: I have a few
Quoted: 340 Post(s)
Liked 209 Times in 104 Posts
I am not sure what forum this question should go in but I THINK this is the best as this bike is closer to a MTB than a road bike. It has 160mm rotors with mechanical TRP spyre calipers and TRP RRL levers (frame up build).
How easily is it to install larger rotors? Is it ONLY a matter of getting different adapters to raise the caliper and install larger rotors? Currently the rear is post mount and the front is 'IS' mount and LOTS of room for a larger rotor to fit front and back.
daviddavieboy is offline
Old 09-25-20, 07:37 AM
prj71
Quoted: 2970 Post(s)
Liked 1,177 Times in 768 Posts
Question is...why do yo want larger rotors?
prj71 is offline
Old 09-25-20, 08:42 AM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
yes
noodle soup is offline
Old 09-25-20, 11:32 AM
Canker
Quoted: 330 Post(s)
Liked 209 Times in 133 Posts
You need to check and see if your fork can handle a bigger rotor. Physically you can slap a 203mm on there but the fork might not be strong enough to handle the leverage increase. Pretty much any mountain bike can handle larger rotors but a hybrid/road bike not so much.
Canker is offline
Old 09-26-20, 04:16 AM
daviddavieboy
Bikes: I have a few
Quoted: 340 Post(s)
Originally Posted by noodle soup
yes
Will check it out. It is a 920 Trek. On a couple hills they seemed VERY hot and this is just with me on it (210 lbs) and no touring load. I have never installed disc brakes before so this is all new to me.
Old 09-26-20, 08:24 AM
dsaul
Quoted: 713 Post(s)
Liked 796 Times in 473 Posts
Brake rotors get hot when you use them, regardless of the rotor size. This is from the 180 rotor on my mountain bike after a moderate downhill.
dsaul is offline
Likes For dsaul:
Old 09-26-20, 10:24 AM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
Nice bike, I had never heard of it until now. Brakes get hot, don't grab ahold of the rotor and you'll be fine. Come to think of it, I don't know why you would want to.
c_m_shooter is offline
Old 09-26-20, 08:48 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2761 Post(s)
Liked 2,534 Times in 1,433 Posts
Yes, as long as the frame and/or fork is rated for a larger rotor, you just need the adaptor (and rotor).
Kapusta is offline
