Questions about tubeless pressures
Everybody tells me one of the advantages of tubeless is that you can run lowest pressures without pinch flat risk. However, I'm already running my Nobby Nic 29x2.35 at the minimum pressure Schwalbe reccomends (1.6 bar), and so far I've had zero flats in 1500km.
I understand that people are running tubeless at lower pressures than ones specified by the tire? or maybe people weigh more than my 75kg?
Disco Infiltrator
Quoted: 2262 Post(s)
Liked 938 Times
You’re probably just not trying to get flats hard enough.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Don't change what is working for you.
I'm asking if people ride at lower pressures than specified by the manufacturer as I seem far from suffering pinch flat at minimum recommended pressure, even when maxing the fork on a drop or hitting a rock garden at more than 40kph.
I was considering going tubeless, but since I'm already at the minimum recommended pressure, I'm not sure about the benefits.
You need a Trail Chicken™
Proper pressure depends upon:
Rider weight
Tire size
Rim width
Riding style (aggressiveness)
tubed or tubeless
I’m 220 lbs and run my 29’er Nobby Nics at 22 psi front, 25 rear, tubeless. Have had no pinch flats (or any flats) and no rim strikes. I’m not jumping this bike. I just experimented on a bunch of rides (using a digital gauge) and went to 20, then up to high 20’, finally settled on these numbers based on comfort and handling. This is easily 10-15 psi lower than what I ran on 26” x 2.2 tires.
https://austin.mellowjohnnys.com/the...going-tubeless
https://reviews.mtbr.com/5-best-reas...tubeless-tires
The benefits of going tubeless relatively have little to do with pinch flats.
One of the main benefits of going tubeless is the additional traction and lower rolling resistance.Those advantages are directly related to being able to run lower pressures, pressures at which pinch flats are common.
Likes For HD3andMe:
