Disc brake pad longevity
Old 01-05-21, 08:16 PM
headwind15
Bikeable
headwind15's Avatar
Quoted: 50 Post(s)
Liked 28 Times in 19 Posts
I was recently checking out my disc pads, and was alarmed about how the were already almost down to metal on metal. I understand that it is difficult to come up with a measurement to be looking for, I mean hours, or miles. The thing is that as a roadie, gee I used to basically never wear out brake pads. I put side pulls on a road bike in 1978. I toured on that bike from San Francisco to Atlanta (4,200 miles) and had not replaced the brake pads 10 years later. I think these disc pads lasted about 10 mountain bike rides. Maybe someone comparing V brake pad wear would be better, as I recognize that mountain biking requires harder braking force,. I would like to hear your experience.
headwind15 is offline
Old 01-05-21, 09:01 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 553 Post(s)
Liked 648 Times in 368 Posts
Disc brake pads can last from 1 hour to more than a year. If you do a muddy/wet CX race they won't last the whole hour. If you only ride in the dry and don't descend much, they last for ages. I doubt your pads are nearly worn out unless it's been wet every ride. There are metallic compound pads that last longer but they're noisier and wear the rotors faster. I'd stay w/ the resin pads.
Comparing disc brake pad life to V brake pad life is pretty reasonable, they're actually pretty close.
cxwrench is offline
Old 01-05-21, 09:36 PM
DeadGrandpa
Philosopher of Bicycling
DeadGrandpa's Avatar
Bikes: Too many, yet not enough.
Quoted: 423 Post(s)
Liked 204 Times in 146 Posts
If you want your disk brake pads to last a long time, I recommend using a spray lubricant on your cassette and chain. I used a farm/industrial lanolin based lube called "Fluid Film". I liked it because it had no petroleum solvents. However, the overspray found its way to the rear brake rotor, and now all my braking is on my front wheel. It's a good thing I live in very flat terrain. I really need to replace those rear brake pads.
I recommend that you don't worry about the life of the brake pads. Just replace when necessary.
DeadGrandpa is offline
Old 01-06-21, 07:18 AM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 102 Post(s)
Liked 122 Times in 92 Posts
Yes, disk brake pads seem to wear out faster than rim brakes. I only remember changing pads on V brakes one time over the span of several bikes in about 10 years. Ever since they phased out V brakes I need to keep spare pads around, and every bike uses a different style.
c_m_shooter is offline
Old 01-06-21, 07:21 AM
sloppy12
Quoted: 83 Post(s)
Liked 152 Times in 75 Posts
My cargo bike maybe 6 months so like 1500 miles.
sloppy12 is offline
Old 01-06-21, 07:31 AM
headwind15
Bikeable
headwind15's Avatar
Quoted: 50 Post(s)
Wow, I really like your input. The pads are warn down to about the thickness of paper, so I believe that it would be prudent to replace them. I definitely feel lucky that I checked them, as one more ride and I would think that they would have gone to the metal to metal stage.
Old 01-06-21, 01:29 PM
prj71
Quoted: 1264 Post(s)
Liked 139 Times in 107 Posts
You are comparing apples to oranges.
Brakes are used more in less miles on a mountain bike vs. a road bike.
Just ride it and don't worry about it.
prj71 is offline
Likes For prj71:
Old 01-07-21, 11:38 AM
Kapusta
Cyclochondriac
Quoted: 1835 Post(s)
Liked 1,133 Times in 667 Posts
Iím still on my first set pads on my gravel bike for 4 years.
MTB... typically a year-ish., but on occasion much less than that.
Kapusta is offline
