Box Four / Shimano Compatibility
Old 01-10-21, 08:39 PM
masonv45
Quoted: 21 Post(s)
Liked 32 Times in 16 Posts
I converted my used GT Aggressor Expert to a 1x8 and love it. However, the rear shifter won't shift up to the next gear in the middle of the cassette on one click. I have to upshift twice and down once. If I adjust he cable tension, it does the same thing - but on the downshift.
New cable, new chain. Rebuilt the shifter with no change. Clean drivetrain.
The last time this happened (on another bike) , the only fix was a new shifter.
I have hydraulic brakes and don't want the shifter gear window getting in the way of the brakes. I don't need /want it - I never look at it anyway.
Soooo ... long story short (too late!!) is the Box Four 8 speed shifter compatible with my Shimano rear mech?
masonv45 is offline
Old 01-11-21, 01:07 PM
prj71
Quoted: 1258 Post(s)
Liked 134 Times in 102 Posts
No.
It's amazing what you can find on the manufacturers website.
https://boxcomponents.com/products/b...shift-groupset
prj71 is offline
Old 01-11-21, 06:33 PM
masonv45
Quoted: 21 Post(s)
Thanks prj71...
I know manufacturer's "say" something doesn't work - but sometimes they do. I was just wondering if anyone had every tried it.
I'm having difficulty finding an 8 speed Shimano shifter (without the window) that doesn't cost more than the bike.
masonv45 is offline
Old 01-11-21, 07:42 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 2265 Post(s)
Liked 939 Times in 619 Posts
8 speed Shimano is going slowly away... I think they are down to only EZ-Fires and one shifter pod, and the different part numbers are just different finishes for different groupsets.
That said, the indicator should not interfere with the brake lever. The pod sits below the brake perch and the indicator goes through the gap between the master cylinder and handlebar. This is not 8 speed nor hydraulic, but you get the idea:
Genesis 49:16-17
Darth Lefty is offline
Old 01-12-21, 10:44 AM
70sSanO
70sSanO's Avatar
Quoted: 827 Post(s)
Liked 588 Times in 396 Posts
You can get an Altus M310 or Acera M315 RapidFire Plus shifter that will work fine. They do have gear windows, but if appearance is that important, then you’ll have to pay for it with a shifter from the 90’s.
John
70sSanO is offline
Likes For 70sSanO:
Old 01-13-21, 08:49 AM
prj71
Probably not. Most of us research using the almighty google machine before spending money.
prj71 is offline
Old 03-17-21, 09:26 PM
masonv45
Quoted: 21 Post(s)
This is the situation I have with my setup.
masonv45 is offline
Old 03-18-21, 07:20 AM
Darth Lefty
Disco Infiltrator
The brake lever goes outboard, the shifter pod goes inboard.
Genesis 49:16-17
Old 03-18-21, 07:00 PM
masonv45
Quoted: 21 Post(s)
I just switched it from that way. When I did, I had to use my middle finger on the brake lever. It was too close to use my first finger. If I move it further away, I have difficulty reaching the shifter levers.
masonv45 is offline
