Short Top Tube & Reach for Singletrack?
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 424 Post(s)
Liked 455 Times
If that bike works for you, that's fine. it's NOT a REFERENCE point for how to get a mountain bike to fit and handle well for you. you're not comparing apples to apples at all here. it's just so far from what you have in mind that it makes no sense. it's like trying to decide what kind of hiking boot you want to buy based on your favorite flip-flops.
demo a few modern bikes that were designed with someone of your height in mind (when demos are possible again). ask around your local mtb community for someone that is close to your height and ask to take it for a spin. it will not fit anything like your current bike because it's not supposed to due to the very different demands from the terrain from what you're doing now. you can probably make any XL or XXL sized bike work better for you than what you have now without resorting to something extremely odd like a backwards stem, unless you have some sort of disfigurement that a doctor can diagnose like extremely short arms or a spine that is not conventionally mobile.
Likes For mack_turtle:
Drip, Drip.
Quoted: 665 Post(s)
Liked 106 Times
My old zaskar has a 590mm top tube, and 480mm reach. I,feel like the top tube is maybe a bit long which is good for singletrack. But I can feel that the reach is way too long for me when I am out of the saddle.
If I can find a trail bike with maybe 460mm for the reach, a similarly long top tube and sufficiently tall stack j think it would work.
My norco seems to have a reach closer to 400 or 405mm.
n00b
Quoted: 424 Post(s)
Liked 455 Times
I think you are focusing on numbers in a way that is not really helpful for you. you're over complicating things and making it hard on yourself. you need to let go of that and just find a bike that is made to fit a person of your height, which is not difficult. here's what you need to look for:
let's get real- what bikes are you considering and what's your budget? are you interested in buying a relatively modern bike, or scrounging around for dumpster parts and building a bunch of goofy-ass Frankenbikes?
I think you have a strange understanding or reach. a modern medium mountain bike designed for someone around 5'9" has a reach of 425–450mm and assumes a "short stem. an older mountain bike that assumes the rider is using a 90–100mm long stem might have a reach closer to 400mm. you're 6'3" and riding a bike with a 400mm reach would make you look like a bear on a tricycle and would wreak havoc on your spine. are you sure you understand what reach is?
- an extra-large frame, maybe XXL if the geometry is conservative. on a mountain bike, this will probably be a 20–22" frame. on a road-oriented bike, this will be a 59–61cm frame.
- to narrow down options, it sounds like you want to get your handlebar rather high. a frame with a relatively high stack measurement will get you there. a relatively tall head tube is a good place to start. these might be "endurance geometry" bikes or touring/ bikepacking- oriented bikes that are designed more for comfort than aerodynamics.
- dial in the fit with saddle position, stem dimensions, and handlebar dimensions. if the frame is designed for someone of your height and riding style, this will not be difficult and should not force you to use a some obscure seatpost or a goofy handlebar / stem.
Quoted: 567 Post(s)
Liked 391 Times
I think you have a strange understanding or reach. a modern medium mountain bike designed for someone around 5'9" has a reach of 425–450mm and an older bike that assumes the rider is using a 90–100mm long stem might have a reach closer to 400mm. you're 6'3" and riding a bike with a 400mm reach would make you look like a bear on a tricycle and would wreak havoc on your spine. are you sure you understand what reach is?
Likes For dsaul:
Drip, Drip.
Quoted: 665 Post(s)
Liked 106 Times
Using a 32mm stem on a bike with 480mm for the reach makes me feel like i am riding the front of the bike as if it were a unicycle. I do not feel like I have enough weight centered toward the rear.
As the reach decreases, this brings my legs forward on the pedal, which scoots my butt back towards the saddle. I know that trail bikes are designed with a longer reach for the purpose of allowing you to weigh the front axle accordingly over rough terrain.
However, being a rather top heavy individual with a relatively short length torso, I need a shorter reach than usual to have an otherwise similar amount of weight over the front axle. This is why I dread bikes with a long reach and top tube.
I dont care whether the bike is new or old, expensive or cheap, I only care that I feel comfortable on the bike. If I don't, I won't be riding any trails this season.
As long as i find a bike with a sufficiently tall stack, and somewhat less reach than average and use my short stem i got laying around, I think ill be good.
n00b
Quoted: 424 Post(s)
Liked 455 Times
Yeah, I am starting to think this is a textbook case of the Dunning-Kruger Effect. People who don't want to learn can't.
You need a Trail Chicken™
Cyclochondriac
Quoted: 1845 Post(s)
Liked 1,147 Times
Although these guys are good riders, using modern bikes/geometry and brakes would have prevented almost all of these crashes
https://www.youtube.com/watch?v=VzZkKE9Z35g
But the biggest thing that drives home is just how bad brakes used to be. Some of those folks just could not slow down. Made me remember the days of four-finger braking that was more of a suggestion to your bike to slow down.
EDIT: OK, having watched that a second time, I'm giving props to the guys doing it. They are wrecking HARD, and just keep going. That downhill must be a lot worse than it looks from where it is shot from (trails are often a lot worse than they look on camera) because a lot of those guys are clearly out of control. And the only one I can really point to as doing something wrong is the guy riding with one foot off the pedals.
Quoted: 1986 Post(s)
Liked 1,098 Times
Heck just a dropper post would have saved almost all of them.
Brakes. A lot of time its the ability to stop, or rather inability, that limits some trail choices for me. On one older bike, adding V brakes and compressionless housings has helped a lot.
All in all though. The OP’S idea of a tight cockpit, weight on the front wheel and high saddle definitely runs contrary to modern developments for maintaining control.
Drip, Drip.
Quoted: 665 Post(s)
Liked 106 Times
Trail bikes definetly go against the sort of fit I wanted, but I'm very eager to get back into trail riding this season - properly. I know there are trail bikes out there which should fit me properly. I've been intently searching classifieds, but all I'm finding is extremely high prices for used bikes.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,163 Times
n00b
Quoted: 424 Post(s)
Liked 455 Times
are you willing to buy something that is 99% certain to fit you but without seeing it in person?
If not, where are you located? if you have a reasonable budget for a decent bike, I'll bet I can find half a dozen bikes that will work for you nearby.
I could duplicate (and probably have) - ost of these crashes on my 8" travel DH bike
Drip, Drip.
Quoted: 665 Post(s)
Liked 106 Times
What's your budget? Put a number on it.
I would be very hesitant to buy a bike without trying it out first. But it might be a risk worth taking.
I'm located just north of Toronto. (Greater Toronto area),
If you can help me find some bikes, would be tremendously appreciated. I looked on pinkbike and local classifieds already.
n00b
Quoted: 424 Post(s)
Liked 455 Times
First, $800 CAD is under $650 USD (to put it in a value to which I can relate) and that's barely enough to buy anything remotely decent NEW from a reputable brand. This is a beggars/ choosers kind of situation, so until you can expand that budget, you're left scrounging the bottom of the barrel. I'm not talking down at you, just explaining the way things are.
Chain Reaction and BikesDirect might have something for you but supply chains are all screwed up right now. Keep an eye on those types of discount sites, but be aware that good deals will go fast due to current demand.
I don't know the Toronto area very well but the CL and PB listings for that area are pathetic! That really shocked me. sorry that's so crappy. I have found in recent years that Craigslist is lousy and I have much better luck finding good stuff on the Facebook marketplace. don't have a FB account? that's your choice.
With your budget, if you want a mountain bike, you're going to have to wait, save your $, and jump on the next deal that comes along that is the appropriate size for you. You need to have the humility to accept that your conception of how a mtb should fit is based on nothing, and that the advice of every bike designer with centuries of combined experience behind them would never build a mountain bike to fit a person of your height with the bizarre dimensions that you have in mind. sorry if that sounds harsh, but I don't think I am doing you any favors by sugar-coating the truth for you. it would be a disservice to you to let you continue on this weird fantasy line of thinking about how bikes should fit. there's a degree of variation within each fitting ideal where you can adjust for your individual preferences, but your ideas are something like three standard deviations from the norm. if you can't see past that, you're on your own with weird Frankenbikes, or you need to pay a custom frame fabricator to build something just for you.
Moisture,
This thing is perfect for flip flops. If I were you, I would definitely get some high quality flip flops. It's the solution to all the problems you are having.
Space Ghost
Bikes: 1989 Club Fuji, 1989 Bridgestone RB-1, 1989 Specialized Stumpjumper, 1997 Gary Fisher Big Sur, 2001 GT i-drive Race, Iro Mark V, a bunch more
Quoted: 200 Post(s)
Liked 264 Times
“You must unlearn what you have learned.” - clunky but applicable advice here.
For anyone wondering. Single track generally refers to trails that a single wheel width wide (<18in). There are frequently rocks, roots and other obstacles. You shouldn't be riding these at any speed while sitting, unless you're being lazy on a full suspension bike. If it's just a flat trail, that's generally considered gravel riding.
Likes For gsa103:
Drip, Drip.
Quoted: 665 Post(s)
Liked 106 Times
mack_turtle so you're telling me I should get a trail bike, but you use a gravel bike with drop bars ? I mean, there's nothing wrong with that, I know it is relatively common to do so.
What about using an off road touring bike? What are your opinion on using drop bars for single track?
My current plan for singletrack endeavors will be using my GT Zaskar mountain bike laying around. Only problem is that the front fork uses brakes only for a 700c rim. Im tired of sourcing a new fork for this bike, so I'm thinking of just using a wider 700c rear tire and using it like this. But obviously with the rigid fork I won't be able to do anything too crazy. But the fork is already about 15mm too long for bike, and then the 700c will jack up the front end a bit more and now the head tube angle is just not right. It honestly might be better to just try using my road bike with a lower stem on singletrack over that.. im not going to do that, mainly because the brakes aren't strong enough.
n00b
Quoted: 424 Post(s)
Liked 455 Times
if you primary goal is trails, I'd stick with a proper mountain bike of any sort, even an old one. if your trails are very mild and smooth and you want to ride a mix of surfaces including non-pave roads, bridle paths, occasional singletrack, something like a gravel bike might be better. there's a lot of grey area between what's considered a mountain bike and a gravel bike, so it's a bit subjective. there's also the question of "how much bike" you want/need. for your preferences and your trails, you might only feel confident on a full-suspension bike with balloon tires and a dropper post. some people prefer to "under bike," riding a lighter, simpler bike that makes difficult terrain more of a challenge. I can't emphasize enough that it's subjective. since I have never ridden bikes near Toronto, I have no idea what kind of trails are available to you. I'd ask the locals where they ride and what kind of bike provides the best balance of challenge and capability. if you want to ride an undersized road bike with a 90% rear tire weight bias and slick tires on a downhill course where everyone else is riding a 160mm travel downhill bike, and that's fun for you, go for it. most people will not enjoy that.
n00b
Quoted: 424 Post(s)
Liked 455 Times
I am curious about this Zaskar. if it's an older Zaskar, it should be designed with 26" wheels in mind. if it's an older 29er, that would make sense for a 700C wheel. 700C and 29" are the same diameter rim and really the same thing with different names based on application. can you post some photos and details about it?
