1993 Cannondale M800 BOTE
Old 02-19-21, 09:08 AM
retrodude
Bikes: 1984 & 1990 Marinoni Specials - 2008 Kona Dogma - 1976 Schwinn Suburban
Quoted: 27 Post(s)
Liked 94 Times in 33 Posts
Iíve been really into bicycles since the early 80s, when mountain bikes came out I started with a basic BRC unit and quickly moved to a Ritchey Ascent. Fitted as many XT parts as I could afford. I always drooled over Brodies, Fat Chance, etc, etc. My Ritchey was fantastic as well but Iíve always wanted to go next level. My grail bike would be a Klein (before they sold to Trek), any number of Kleins would fit the bill. Back in the late 80s early 90s I had an admiration for Trek/Cannondale/Specialized, some of the bigger top quality brands. Anyway, Cannondale was never a brand I drooled over. I always had respect and thought their sanded wells, American/built in-house frames were very cool, was always jealous of the listed frame weights, didnít like the cantilevered rear drop outs too much (at the time) Ö
Fast forward 25-30 years. Going through FB marketplace I noticed a pretty ugly Cannondale for $100. The Syncros seatpost and XT thumbies sold me right away, with the LX other parts it was a great parts bike at the very least. Talked him down to $90 and brought her home. Wouldnít be a problem to build up a vintage Cannondale and sell it right?
After stripping down to the frame and weighing it I started doing some research. Never took notice of the Beast of the East build, remembered the odd early version with the 24Ē rear wheel. Wheels started turning and before you knew it told the wife ďsorryĒ Iím keepiní itÖ
I have a bare frame aluminum GT Zaskar thatís polished and really like the look. After removing the rattle can blue paint I found it was one of the dark-blue-purplish ones with pink/fuchsia quick release and rear cantiís only. I needed a fork. Its has 1-1/4Ē steering, what to do? Ended up sourcing reducers, the best deal on a Pepperoni fork was unthreaded 1-1/8Ē steel steerer. The fork that I bought the bike with was 1-1/8Ē Rock Shox low end, with and extra crown race thrown in for good measure, not sure how the previous owner didnít die, plus 1-1/8Ē headsets and stems will be cheaper and easier to source.
Decided to go stripped of paint/polished and source decals. With black and silver only I wanted a bit of fun color. The decals I found had yellow in them so went with yellow grips instead of black (a first for me using non black) and a couple gold anodized (well more like orange) bits for chainring bolts and seat collar. Had to use the Dura-Ace RD I grabbed last year for $20 all scratched up which I then polished (yes, it needs a cable anchor trick to work with any other Shimano 7 speed shifter)
The flat carbon bar has been sitting, waiting for a couple years due to itís larger clamp diameter which came off a bike that needed a riser. Figured with the threadless fork I could go a bit modern in the steering area, then threw on the more modern Ritchey carbon railed saddle (yellow accents too &#128522. The Innova tires are crasy light at 618g a pair, love the skin wall look, Iím confident the minimal knobbies will be fine for the smooth trails I take me old school fully rigid MTBs on.
I was worried about the high BB at 13Ē. Here I am putting all this work and close to $500 into this project, what if I donít like the ride? Yikes!
Okay, so pretty long story, I know. What follows are pictures only. She weights 19.75lbs, I basically put almost every lightest version of a part on it as a light weight build. Drum roll ..Ö it rides amazingly well. If not my favorite vintage MTB itís in my top three with my Kona and Rocky Mountain. And I can say I have a real and proper Cannondale, built in the USA
retrodude is offline
Likes For retrodude:
Old 02-19-21, 09:51 PM
70sSanO
70sSanO's Avatar
Quoted: 826 Post(s)
Liked 586 Times in 395 Posts
Very Nice build.
I imagine more for pavement with a Dura Ace 74XX rear derailleur. May be the only M800 with that RD. Running in friction or alternative routing?
John
70sSanO is offline
Old 02-19-21, 11:49 PM
DMC707
DMC707's Avatar
Bikes: Too many to list
Quoted: 987 Post(s)
Liked 310 Times in 212 Posts
Originally Posted by 70sSanO View Post
Very Nice build.
John
naaaah
i was a NORBA expert BITD
i was running a paramount 70 series frameset, 8 speed Sachs 12-26 freewheel on an American Classic wheelset with a short cage 105 derailleur and Gripshift. No granny ring and i forget thespecifics of the crankset other than thesmall ring was deleted
That was a lowest common denominator bicycle - meaning if it didnt help the bike go faster or weigh less, it was deleted or replaced—- and was fairly typical for the time period. If you needed the 3rd ring and a long cage derailleur, you didnt need to be racing was the mindset
fast forward to today and i run an 11-50 12 speed setup with a 30 tooth front ring. I wish i still had the legsnto push the old setup , even if machismo seemed to be the reason it was used .
But back then , roadies using 52-42 cranks with 12-19 corncob freewheels was notuncommon either
DMC707 is offline
Likes For DMC707:
Old 02-20-21, 12:24 AM
veganbikes
Clark W. Griswold
Quoted: 2122 Post(s)
Liked 1,041 Times in 731 Posts
I liked it but one thing had me a bit reeling was the 7400 derailleur. I also liked the 3DV stuff but you did such a nice job I can forgive it.
veganbikes is offline
Old 02-20-21, 11:13 AM
retrodude
Quoted: 27 Post(s)
Very Nice build.
John
When you clamp the cable like so it will shift standard shimano 7 speed
I've always run short cages since the late 80s, the 7400 is limited to a 26 rear cog which is plenty with my 22 granny gear. I can climb a wall like hill on a nearby trail, the lightweight total bike helps too
its very light and I think it adds some bling. My other bike are a 2008 Dawgma for real BC trail riding, a 93' Kona Kilauea, a 1990 Bianchi Sika, 1994 Rocky Mountain Vapor and a 1996 GT Zaskar
Old 02-20-21, 11:24 AM
DMC707
DMC707's Avatar
Quoted: 987 Post(s)
yep. Quicker , more precise shifting and more importantly the cage is up a little more out of the way as well. I dont understand why people cant grasp the concept
DMC707 is offline
Old 02-20-21, 12:16 PM
70sSanO
70sSanO's Avatar
Quoted: 826 Post(s)
Legs pure and simple. Most people canít climb a wall with a 22/26.
I rode 7400 with a 26t, and then a 28t for a while. That said, Shimanoís M900 RD remains the best RD made, modern advances notwithstanding, as it is as quick as any 7400 Iíve had and gives a bit more capacity and max cog. Ironically Iím running an M910 on my road bike with 7401 DT shifters and the ďoppositeĒ alternate cable routing.
John
70sSanO is offline
Old 02-20-21, 02:54 PM
retrodude
Quoted: 27 Post(s)
John
I would so love to get my hands on some M900 kit. So expensive to buy now. The 7401 used I picked up on CL for $20 and then went to work polishing. I do have an M900 crankset I found for sale at $10 without chainrings and very well used. Lots of polishing later and an XTR decal found on eBay and it's not too shabby
Old 02-20-21, 11:05 PM
70sSanO
70sSanO's Avatar
Quoted: 826 Post(s)
Yeah prices on M900 is pretty nuts these days. I was able to pick up some of it a few years back, I wish I had found a set of hubs. They would make a nice build.
John
70sSanO is offline
