Go Back  Bike Forums > Bike Forums > Recumbent
Rotator no more.....?
Recumbent What IS that thing?! Recumbents may be odd looking, but they have many advantages over a "wedgie" bicycle. Discuss the in's and out's recumbent lifestyle in the recumbent forum.
Old 07-30-09, 09:42 AM
Glasspacker
Epitome of Mediocrity
Bikes: Rans V2
I noticed a Rotator Pursuit on Ebay, at a low price so far. I was wondering about parts, etc, since the seller thought it was a 96-97 vintage. I checked the Rotator website and noticed that his page on "dealers" was not available. I sent off an email and Steve Delaire (owner, I think) responded that he's no longer taking orders. I'm not a handy person....think I will pass. I do have a bent dealer near me, but I don't like complications- - - he's not, or should I say "was" not a Rotator dealer.
Glasspacker is offline
Old 07-30-09, 02:32 PM
gcottay
gcottay's Avatar
Bikes: Trice Q; Volae Century; TT 3.4
Steve has found employment that seems to have put his recumbent business on hold at least for a while. He also had some medical problems earlier this year.
Your best bet for a Rotator Pursuit may turn out to be a RANS X-Stream.
gcottay is offline
Old 07-30-09, 05:56 PM
PaPa
PaPa's Avatar
Unless the 'stream is pointed at reasonably flat and traffic free tarmac, I would disagree. With a half-a-yard of tiller, pronounced fork flop and well over 3/4 of its laden weight sitting on the rear axle, it wouldn't even make the Top Ten.
PaPa is offline
Old 07-31-09, 03:48 PM
Glasspacker
Bikes: Rans V2
Today I printed off photos from the ebay ad and took them to my lbs (95% df, 5% bent - sun dealer). The mechanic there said that Trek tried the mid-drive system and then gave up on it due to problems. He said he would probably steer clear of it, especially with the sachs components which are no longer made. I said the Rotator Pursuit is known for being a well-engineered product; I would just need them to be able to work on it. He said they'd do it, no problem there, but once a sachs component goes bad, you start looking at replacing the whole drivetrain which involves a lot of parts on this model. I'm sure some well-seasoned bent folks would have some ideas, but I will pass on it. This mechanic then steered me towards a Sun Tomahawk. Surprise. No thanks.
Old 08-02-09, 02:27 AM
sch
Quoted: 266 Post(s)
Liked 81 Times in 63 Posts
The only thing "Unique" about the rotator pursuit is the frame, seat and steering bar. The drive
train is completely standard and easily upgraded or repaired. The seat material can wear out
but could likely be replaced with a little searching and fabrication. The BB, cranks, headset and
wheels are standard items. The middrive cassette can be assembled out of standard cassettes
that come apart completely, Nashbar has several varieties of these for $5-20 that can serve as
donor cassettes for the mid drive. The one potential weak spot is the mid drive axle, if it breaks
you may have to rummage for one, but it is basically a 10mm solid axle, BMX variant. Mine has
been highly reliable over the past 19K miles. Tandem length cables are readily available. Since the rear has 7-8 or 9 speeds and the front has 6 speeds you
do need to use two Right hand twist grips with the left sided twist grip controlling the mid drive derailler. It is 'upside down' on the bar but works fine that way.
My R hand twist gave up at 13kmi but the left sided shifter is still working fine
at 19kmi. Nashbar was selling twist shifters a year or so back as singletons and
in sets for $15-30 so I stocked up.
sch is offline
Old 08-02-09, 06:57 AM
Glasspacker
Bikes: Rans V2
Thanks sch for the info. Reason I was looking at them is because I like the position of the BB. Not too high for me to get numb feet, which I am prone to, but not too low either.
Old 08-02-09, 09:00 AM
gcottay
gcottay's Avatar
It's always fun how different riders respond to the same bike. Though I favor SWB bents, the x-stream seems to me quite well behaved for a LWB and with a 41 inch x-seam, had a balanced feel to it.
gcottay is offline
Old 08-02-09, 12:18 PM
PaPa
PaPa's Avatar
Just like the bastardized, short lived Formula 26 (which embraces much the same steering geometry as the 'stream). Touted as a speed machine, it too possessed the low speed genes of a Kenworth, and commuting customers quickly realized that the bike was ill-suited for anything less than Battle Mountain. Suffice it to say, You just don't stack 80% of the laden weight over the rear axle, bolt-on 16" of tiller feeding over 3" dynamic trail, and expect the nimble and predictable commuting speed handling of a Stratus LE or Tour Easy. Sorry, it just doesn't happen.
PaPa is offline
Old 08-02-09, 09:10 PM
gcottay
gcottay's Avatar
Just like the bastardized. . . . Sorry, it just doesn't happen.
Guessing or test riding?
gcottay is offline
Old 08-02-09, 09:34 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 659 Post(s)
Liked 292 Times in 190 Posts
Steve had a bout with appendicitis and has found a job in the wind power business. In his own words:
https://www.recumbents.com/forums/top...?TOPIC_ID=2283
Jeff Wills
Jeff Wills is offline
Old 08-03-09, 03:50 PM
Glasspacker
Bikes: Rans V2
...in the meantime, I've noticed one on craigslist in OK City. $600 and it's a 2001 with Shimano components. That sort of puts a lid on how high one would go for the ebay listing- - now at $405.
Old 08-17-09, 02:07 PM
Glasspacker
Bikes: Rans V2
I noticed Steve D's personal bike is up for sale for $900 (and it has the fairing!)-
https://images.google.com/imgres?imgu...a%3DN%26um%3D1
His doesn't have the mid-drive. Hmmm......I'm sure there's a reasonable explanation.
I bought the Ok city one on craigslist for $600, thanks to Sch's reassurance on parts Plus, the Rotator website is pretty handy as it ID's each part on the bike. Mine has Velocity Razor wheels. I wonder if that was standard for 2001, or if it was a later change.
Old 08-17-09, 06:53 PM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1239 Post(s)
Liked 355 Times in 234 Posts
He put more unkindly than I'd have done. Pursuits are not known for their low-speed handling. So, in that respect I suspect he was making an educated guess; but one I'd make too. You'd definitely want to test ride one before buying, because you might think it looked good on paper then HATED it in real life. Or, maybe having that much tiller wouldn't bother you in the least.
BlazingPedals is offline
Old 08-17-09, 08:16 PM
cod.peace
cod.peace's Avatar
Bikes: Rans V-Rex
I don't know much about the Rotator bikes (other than that they're supposed to be fast & comfortable) but I believe the mid-drive systems were used on the dual 20" bikes. The one for sale there without mid-drive has a 26" or 700cc rear wheel, so a more standard shifting setup gives enough gear range.
cod.peace is offline
Old 08-18-09, 10:19 AM
Glasspacker
Bikes: Rans V2
Ahh...duh. I didn't even notice the larger rear wheel.
BP, thanks for the advice, but I already took the plunge (but won't be deliv until mid-oct). I've had a Stratus, V2, and Volae Century in the past. I know this will be different. I look forward to the challenge.
Old 08-18-09, 02:07 PM
BlazingPedals
The Trek did have a mid-drive, and it did have problems. Initially. But all of those problems were solved at a relatively early date. Trek might still be making a version of the R200 today if the original proponent within the company hadn't kicked the bucket and the rest of the upright-centric management immediately dropped it in spite of its respectable sales figures.
Old 07-27-19, 03:44 PM
Jacque35
How did you like the rotator? Do you still have it?
Do you still have the rotator?
Jacque35 is offline
Old 07-27-19, 06:50 PM
VegasTriker
Quoted: 392 Post(s)
Liked 85 Times in 65 Posts
I realize this is your first post at Bikeforums so you may not have noticed that this thread is over a decade old. It is highly unlikely the owner would still have it after all this time since it was for sale in 2009. After you get enough posts you can try using the private message function and contact owners. The link to the picture sends you to Angletech Cyclery. They no longer list Rotator among the brands they have available used.
SteveD is listed among the current members but has not logged in for over 2 years. You can still PM him by going to the list, find his name, and click on PM. He's on page 928 of the members under the letter "S".
There is a very old review of the bike on Bentrideronline. https://www.bentrideronline.com/?p=2565
VegasTriker is offline
Old 08-03-19, 01:49 PM
sch
Quoted: 266 Post(s)
Just a followup on my 2001 Ti Pursuit... Still ridden on regular basis, now up to ~32,500 miles. The original mid-drive axle was undersized at
0.38" for the 10mm bearings on the mid-drive so this allowed the mid-drive cassette to cock at a several degree angle which meant that
any really high torque ran the risk of derailling the mid drive drive chain. Solved the problem by making my own 4140 true 10mm diameter
axle (first used carbon steel drill rod, it broke at 800 miles, so switched to 4140). That axle is now above 25,000 miles. A few yrs ago I put
a chain keeper inside the mid-drive to minimize the rare derailling that began to occur then. This has solved the residual problem, possibly due
to wear on the mid-drive axle at its present mileage. This only happened on my 14% grade driveway.
Converted from 12-27 9spd cassette to 11-28 10spd cassette and mounted a Di2 RD on the rear cassette. Made a huge difference in shifting. Bike is ridden
1-2x/week for 40-55 miles each time and is fine for flattish club rides. The brass seat grommets wore out (corrosion) after ~15 yrs but it was
easy to drill them out and replace with stainless grommets. The 4mm bungee cord on the 'butt' part of the seat needs replacing every
2 yrs or so. Seat itself will need replacing in a yr or three, but I have a spare, purchased not long before Steve Delaire shut down the
operation. Making a new one does not look particularly hard, if necessary, but a 20 yr life span is not bad. Original Stronglite headset
replaced with another about 3 yrs ago.
sch is offline
Old 08-14-19, 08:13 AM
Joel Dickman
Hello sch -
I also have a ti pursuit that I am very fond of. Like you, my mid-drive axle snapped in two pieces some years back. Since I ride in a pretty flat area, I removed the mid-drive entirely and replaced it with a RANS chain idler. This meant giving up all those fine-grained gear choices and the extremes for climbing and descending hills. Not an optimal solution.
Is there any chance that I could bamboozle you into making a 4140 mid-drive axle for my Rotator? I would be happy to pay you for your time and trouble. Sometimes I miss all those extra gears.
(By the way, ROTATOR spelled backwards is ROTATOR.)
Safe riding,
Joel Dickman
These three prevent most accidents: seeing, being seen, & (usually) common sense.
Joel Dickman is offline
Old 08-16-19, 09:46 PM
sch
Quoted: 266 Post(s)
Joel Dickman, contact me at sch1943atgmail This is a project I was planning to do ~sometime~
now I have a reason to start.
Followup: made two mid-drive axles and sent them to Joel for nominal cost. I can make more easily enough if any one needs one.
sch is offline
Old 09-25-19, 01:35 PM
Joel Dickman
a big THANKS! to sch1943 for the mid-drive axles
My old Rotator titanium Pursuit bike will soon be restored to original fully-geared glory thanks to the efforts of sch1943. If you have a problem with your Rotator bike, I would heartily suggest consulting him. He really knows his stuff, and is glad to help fellow cyclists.
Soon I will be able to crank down hills at warp speed again, instead of spinning out. Climbing will be easier too. The mid-drive gives you an extremely wide overall range of gears combined with very small incremental steps gear to gear. It sometimes feels like an automatic transmission.
It is a shame that Steve Delaire's Rotator Recumbents business did not survive the 2008 recession. He made great bikes (and fairings too).
Thanks again sch1943!
Safe riding,
Joel Dickman
Old 04-24-20, 04:52 PM
mmatarella
Bikes: Rans Stratus, Linear, M5 CLR, Kingcycle, Rotator Pursuit, Ryan Vanguard
I know it has been several months but if you are still available to fab and sell a couple more... I'd take you up on it with gratitude. Sounds like it would be good to bank a couple.
I am getting a Rotator Pursuit delivered Monday. It is the one I had and sold 20+ years ago! I sold it as I got hit with arthritis and thought it too hard to get up off of. A few years later, new drugs and I am 99% arthritis free. Been kicking myself for selling that Pursuit for a long time now. I wrote to Mt Airy Bikes owner Larry back up in Md near where I Iived back then as he has a zillion bikes and a lot pass through there. I asked him to keep an eye out for one. Next day he replies he just got one in an estate, sends pics, and it is my old bike. I created and ran the Recumbents.com web site for years and had put the URL down both sides of the frame and there it was so no doubt it was mine. Larry stripped it, had it powder coated and sent it down to me. So after all this time and effort it sounds like I should try to get a spare axle or two!
While emailing I mentioned I had always loved a Kingcycle he had that I test road 20 years back there. Still had it. I got it. Oh, I also always loved Ryan Vanguards. OK, shipping it tomorrow. :-) When the bug bites the second time it bites HARD :-) This all adding to the three recumbents on had already.
mmatarella is offline
Old 09-02-20, 11:19 PM
tallbikeman
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 107 Post(s)
Liked 93 Times in 67 Posts
Mmatarella I love my Ryan Vanguard. Rode it 33 miles today. What a sweet bicycle.
tallbikeman is offline
Old 12-10-20, 11:15 PM
sch
Quoted: 266 Post(s)
Brief follow up to mmatarella post: after some back and forth emails, it developed that his steel Rotator needed a
different mid drive axle length from the Ti rotator I have and he elected not to disassemble a perfectly good bike to measure the
axle.
sch is offline
