Travel adjustment on Rockshox forks?
Old 05-12-10, 06:42 AM
dabac
Quoted: 1000 Post(s)
Liked 196 Times in 147 Posts
Hi all,
I'm looking at the internal travel adjustment for Rockshox forks, where there's a bushing that can be added/removed for setting up the fork. And the part that I can't figure out is if the adjustment is on the "upper " end or the "lower" end.
Will a fork set for 80 mm travel have the same axle-to-crown as a 100 mm, but bottom out faster?
Or will a fork set for 80 mm travel have 20 mm less axle-to-crown as a 100 mm, and hit full extension faster?
(the above assuming that pressures and sag are set up correctly for both forks)
dabac is offline
Old 05-12-10, 07:14 AM
Metzinger
Primate
Metzinger's Avatar
Bikes: Concorde Columbus SL, Rocky Mountain Edge, Sparta stadfiets
On adjustable travel forks, the longer travel position has the fork crown sitting higher when uncompressed. On older RockShox models I've worked on, shortening the top-out spring/bumper allowed them to telescope out farther. Then it was a matter of adding spring/air/elastomer to the compression side.
Metzinger is offline
Old 05-12-10, 07:18 AM
dabac
I got the bright idea to google axle-to-crown, and according to that the long travel axle does ride higher. I hoped for that, but mechanically it could have been either.
dabac is offline
fcormier
Mountain Biking
4
01-22-21 02:09 PM
wtherapy
Mountain Biking
3
03-29-17 04:28 PM
fcormier
Mountain Biking
3
11-13-16 10:30 PM
xenologer
Bicycle Mechanics
2
12-09-13 01:49 PM
dabac
Mountain Biking
0
05-12-10 06:44 AM
