Travel adjustment on Rockshox forks?
Old 05-12-10, 06:44 AM
dabac
Quoted: 1000 Post(s)
Liked 196 Times in 147 Posts
Hi all,
I'm looking at the internal travel adjustment for Rockshox forks, where there's a bushing that can be added/removed for setting up the fork. And the part that I can't figure out is if the adjustment is on the "upper " end or the "lower" end.
Will a fork set for 80 mm travel have the same axle-to-crown as a 100 mm, but bottom out faster?
Or will a fork set for 80 mm travel have 20 mm less axle-to-crown as a 100 mm, and hit full extension faster?
(the above assuming that pressures and sag are set up correctly for both forks)
Last edited by dabac; 05-12-10 at 07:15 AM. Reason: never mind: I googled and found two different axle-to-crown measurements listed. The 80 mm rides lower - As I hoped.
dabac is offline
fcormier
Mountain Biking
4
01-22-21 02:09 PM
rpenmanparker
Bicycle Mechanics
20
11-07-14 03:33 PM
mccdam28
Bicycle Mechanics
8
08-12-11 06:10 AM
nbrinto
Mountain Biking
1
11-26-10 03:43 PM
dabac
Bicycle Mechanics
2
05-12-10 07:18 AM
