Tire thread pattern: terrain & application
Quoted: 477 Post(s)
Liked 584 Times
On visual inspection alone, for what type of terrain/surface and application would you say this tire thread pattern is best suited?
climber has-been
Quoted: 3487 Post(s)
Liked 3,626 Times
Likes For terrymorse:
Quoted: 4227 Post(s)
Liked 2,489 Times
Looks like a cheap multi terrain tire.
Likes For wolfchild:
Quoted: 696 Post(s)
Liked 910 Times
Paved bike path.
Quoted: 368 Post(s)
Liked 423 Times
I'd say:
Surface: gravel to dirt that is a little loose but not muddy, nor deep sand/snow.
Terrain: looks OK for gravel roads through crushed gravel paths to mild off-road on a fairly even surface, as above.
(BTW, I really like your diction and syntax - it's refreshing to see someone express themselves elegantly on an internet forum, where such niceties are routinely devalued.)
Likes For noimagination:
Quoted: 4471 Post(s)
Liked 4,945 Times
This actually looks pretty useless. It has no side knobs for loose off-road cornering grip and the tread spacing in the centre looks too tight to offer any extra traction beyond a slick. But I’m sure it would cope with a bike path.
The tread pattern looks to be inspired by car tyres ie aimed at moving water to prevent high speed aqua planing rather than grip. This is not required on a narrow bike tyre at low speed.
Likes For PeteHski:
Likes For CAT7RDR:
Dirty Heathen
Quoted: 889 Post(s)
Liked 926 Times
"Rail-trail" hybrid tire.
The center ridge looks like it should roll well on mixed hard surfaces (paved/unpaved) but it doesn't look wide or aggressive enough for technical MTB trails or soft surfaces like loam or mud.
What size are we looking at? A tread pattern that looks super gnarly on a 700x32 can look like goldfish scales when you put it on a 29x2.35"
Quoted: 6247 Post(s)
Liked 4,849 Times
If you always ride paved roads or paved trails with a thin wash of mud going over them, they might be good for that. And perhaps for riding dirt and sand that is not too loose.
But I'd recommend you pick your tires and tread pattern for the riding you do most. Not for something you'll occasionally be in for very brief periods. More tread is usually more rolling resistance. More rolling resistance uses more of your energy. More of your energy means you tire faster and not ride as far.
While the differences might seem low to your legs, remember the effects are cumulative.
Is there a surprise answer for us? The way you worded it makes me think there is.
Habitual User
Quoted: 5010 Post(s)
Liked 8,195 Times
I would consider that a multi-terrain tire that will be just fine on lots of surfaces, but not brilliant on any. It will probably roll reasonably efficiently on pavement, but not as fast, or corner as well, as true road tire. It will probably handle most dirt surfaces okay, but will be challenged by loose/demanding conditions. For someone who is not looking to optimize speed and/or handling, and regularly encounters a variety of different - but mild - conditions, it could be a pretty solid choice.
Le Crocodile
Quoted: 370 Post(s)
Liked 788 Times
Inexpensive, low quality, poor compound composition, sunny weekend day on a bike path tyre?
I went with "tyre" because it goes better (syntax and all).
Sunshine
Quoted: 11012 Post(s)
Liked 7,548 Times
Cant say I have ever thought much about a tire's threads. I have pulled some threads off a Conti tire or two thru the years- they sometimes have a loose thread around where the tire and rim meet. But I definitely havent thought about the pattern of threads.
Quoted: 3558 Post(s)
Liked 2,974 Times
I thought this thread was about tires?
Paved and improved surfaces like hard pack and light gravel roads. Tire looks to be on a hybrid of some sort.
Method to My Madness
Quoted: 1981 Post(s)
Liked 1,501 Times
Tire appears to be suitable for short grass and medium pile carpet, assuming that both (surfaces, not the tires) are installed more-or-less flat.
Likes For SoSmellyAir:
