Eclipse P20 vs Eclipse X22 - For Japan 3800 km tour - Where is the price difference?
Hello guys!
I'll do a trip to Japan. I'll ride 3800 km from south to north. And I'm between the Eclipse P20 and Eclipse X22.
I wanted to know where is the price difference between the Eclipse P20 and the Eclipse X22.
Why it should worth the extra $1000?
Thank you so much!
Thank you so much!
Quoted: 239 Post(s)
It appears the main difference is the little pieces and I would bet the rims on the more expensive one are Carbon---If not they should be. The specs on the ones I saw do not justify the 1k difference. I don't understand both bikes have aluminum forks. Carbon forks ride so much better than aluminum, I don't understand, they are not that much more expensive.
Are you riding with a big group? Are you carrying much gear? When you put 20 pounds of gear (8.5 kilo) you will notice a that the difference between bikes is significantly decreased.
Should be fun.
Should be fun.
Quoted: 239 Post(s)
I am fonder of 20" wheels for packing and shipping. I'd look closely at the Dahon SL11 which retails for 1399 I think.
Have a great trip no matter what you go with.
Bikes: to many
Quoted: 213 Post(s)
ultegra drivetrain .... bit better other components.... like Shimano hydros versus tectro ...
for a tour I would go with the less expensive model and use the saved money for nice carrier and bags, bigger fatter tires and lots of money left to treat myself to very good food and a good glas of wine once in a while ...
thor
thor
Bikes: Wheeler Mtn bike, Strida 5.0, Tern Link Uno, FSIR Spin 2.0, Dahon Mu P8
Quoted: 34 Post(s)
I'm looking at the differences and that's like $500/lbs of cost. wow. that's at most a 7.5% difference in weight and the higher you go the less of a improvement you are getting (diminishing returns). Like Thor said save the money on some good travel bags to hook up to it and make the trip more enjoyable. I already know both will roll really really well already (kojaks). And there's enough gearing there between the two bikes to easily take on those Mt. Fuji roads if you are passing through them and actually it looks like it'll be easier on the p20 with that bigger lower gear. Some of those roads around that mountain I think are on AVERAGE of 10% so best be prepared! And as Rick mentioned once you are carrying lots of water and clothes and stuff your % of different between the bikes lessens quite a bit. Just adding 20lbs of gear and bags on it and your difference between the bikes becomes a 4% difference in weight now.
On yer bike
It looks like that cost difference is spread between a whole lot of part differences between the bikes: drivetrain, brakes, wheels, seatpost/saddle, etc... Maybe a little high, but seems to be about right when comparing other brands when they make the jump from lower end 10spd to mid/high end 11spd.
But still, above advice is sound unless this will be a vehicle-supported type of credit card tour where speed is paramount in which case it's a personal value judgement.
Wooow!! Thank you so, so much guys! Now I everything is so clear!!
I really appreciate your time and comments. I'll go with the Tern Eclipse P20 with out doubts!
Rick Imby san:
I'll go alone and I I'll have just my tent, sleeping bag and clothes. They'll be all my stuff. I'll left my home and I'll go nomad.
ThorUSA san:
I'm totally with you. I'm doesnt drink wine, but I can image others things to do with those $1000 . You really have a point there!!.
You make me re think a lot!
Azreal911 san:
I'll go from Haterumashima to Hokkaido. In the middle I'll surraound the Fuji san. I want to see all the views.
Thank you so much for the data about gear and the combination with the information of the Fuji roads, that is very usefull!
Did you ride in Nihon?
Nightdiver san:
Thank you so much!
Rick Imby san:
ThorUSA san:
Azreal911 san:
Nightdiver san:
Thank you so much!
Quoted: 15 Post(s)
Here is the comparison between the 2 bikes: https://www.bikefolded.com/tern-ecli...-folding-bike/
Hope it helps
Hope it helps
Likes For chesky:
Thank you so much Chesky! This was the first thing that I found by Google.
The comments here gave me the data and information to make a good decition.
Thank you so much!
Thank you so much!
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times
Rick Imby san:
Rick Imby san:
Aluminum is very stiff, small wheels and triangles make it stiffer. Adding weight by doing a loaded tour will make it worse.
Thanks
Yan
Bikes: to many
Quoted: 213 Post(s)
hmm ? the eclipse I got are all 26 inch wheels, hydraulic disc brakes, Shimano drivetrains, vro adjustable stems.... great for going fast or load up for touring
Quoted: 282 Post(s)
Liked 24 Times
IMHO this is not a touring bike, nor is it suited for touring. A steel touring bike or a suspension mountain bike would be much better.
Thanks,
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
ThorUSA san, this is good to know! Thank you!
Im trying to find an Eclipse P20 in Japan online, but they are sold out.
It seams that its discontinued or something like that.
Anyways the Eclipse available everywhere is the Eclipse D16.
I was thinking of start with the Eclipse D16
Bikes: Civia Bryant, Tern Eclipse UNO, Brompton
Hi Eze,
I have a brand new unused Tern Eclipse UNO that you can put any drive train on that you like. I live in Tokyo and just put the bike up for sale on Craigslist here https://tokyo.craigslist.jp/bik/5951478069.html
You could pick it up once you fly over if you were interested. If you decide you'd want a steel full size touring bike I also have one that I am going to sell but it depends on your height as it is a 61 cm frame.
If your interested in the Tern feel free to PM me.
Cheers,
Ray
Cheers,
Ray
Quoted: 34 Post(s)
My suggestion? since looking at your profile seems like you are in Arkansas US. Buy a full sized folding bike here and package it up into a luggage and take it with you. At least you can ride around here for a good 100-200 km's before you bring it there and if there are any problems you would have them fixed already. Going to buy a new bike brand new right from the store and hope nothing comes loose during a 3800km tour, also it's quite a hassle finding a good bike in a foreign place. since you actually have a pretty good budget I was thinking of buying it here and ride around ahead of time to make sure everything is ok.
you can buy the P20 here:
https://www.nycewheels.com/tern-foldi...verge-p20.html (PLUS SHIPPING) not sure about stock levels.
or here:
https://thorusa.com/tern/eclipsep20.htm (shipping included) good to go.
ALSO an alternative brand for the similar price you have would be this:
https://www.montaguebikes.com/product/fit/
all three should be able to fold it into a big luggage. but someone correct me if it can't because I don't own big wheel folders.
hope this can help and not add more headaches ahhahah
Necrobumping this thread, because it applies so well to my situation - apologies if that's bad form here, I'm brand new.
I've put a couple of hundred miles on my P20 - full disclosure I never rode the X22 to compare - but have used both sets of components on different bikes - and the x22 would have been cooler but not enough to justify the extra cost for me - although as a value proposition it was perfectly rational. The components were appropriately premium - however, the P20 has been fantastic so far - and I'd be perfectly happy to take it on a grand tour. In terms of wear and tear on my body, and ability to add equipment, it's basically been a draw between the Tern and my "main" Cannondale Quick 2 Carbon.
I'd like to buy spare wheels to install knobby tires on for a quick swap (Kinetix 26 inch that I think are custom for that bike, or at least hard to google) - but can't get a reply from customer service on that question (and a q about a compatible airline bag) but in this crazy bike shortage, I'm not surprised - customer service WAS great in Jan and feb. Then Covid happened I guess.
I'm adding a pair of Wellgo removable dual platform pedals (found 'em on AliExpress for peanuts!) because I will get more efficiency out of SPDs, but have the option of sneakers and ability to loan it out -- and I'd like to source a L/R spare set of Wellgo quick release adapters so I can use them on my Cannondale too - but again weirdly hard to find.
Assuming this bike ages well - and doesn't encounter any welding or manufacturing defects - it's probably the best all-round bike I've ever owned, although my needs - including geometry and riding position - are a bit unusual - I want a bike for international and domestic travel - that doesn't feel compromised by wheel size - and with an upright position (I use stem riser on my regular bikes but the Eclipse bars adjust super high so no need for new hardware!) and more and more I've been picking this one from the garage over the Cannondale, simply because it's easier to live with and one less step to leave the house with (cleats!) but rides as quickly and smoothly.
I'm taking it to Hawaii this year and Tokyo next (Covid permitting, if I find a bag or case it fits and if I find spare wheels!) and expect to put about two or three hundred miles on over a week - I pack pretty light, but it takes a bottle cage and racks perfectly well. It may not be a traditional tourer, but I think it has the potential.
Likes For FoldingSpace:
I sure wish someone would make a 20" wheel folder that has wide gearing right out of the box. I converted my Dahon Speed to a double crank. Even with 20" wheels, it will be a challenge to pack under the airline linear size limit of 62" total. With 24" or 26" wheels, I think it may be impossible. However, many airlines now allow bikes with no oversize fee, but increasingly, the airlines are charging for all checked bags. A known exception is Southwest, free checked, provided it meets size limits.
Quoted: 800 Post(s)
Liked 247 Times
The Birdy Rohloff has a wide gearing right out the box (from about 1.6m to more than 8m with the factory 52t chainring) and 50x355 wheels almost as big as 20" with narrow tires (like the narrow tires of the above pictured bike). Wider tires are always a benefit for traveling.
After removal of the seatpost+saddle (no tools needed to do that), the Birdy pack really small.
