View Poll Results: Have you tried 28mm tires? Do you like them better than 25's? (Vote all that apply)
I tried tubeless 28's. I like them.
58
22.14%
I tried tubeless 28's. I don't like them.
5
1.91%
I tried tubed 28's. I like them.
184
70.23%
I tried tubed 28's. I don't like them.
3
1.15%
I've never tried 28mm bike tires for very long.
10
3.82%
I'm not interested in going to 28's at all.
23
8.78%
Multiple Choice Poll. Voters: 262. You may not vote on this poll
28mm tires on paved roads . . . have you tried them? Do you like them?
#76
Long thread with many replies so this may have been mentioned already. Tire size plays a factor in comfort, grip, feel, resistance, quality etc but even more important is the specific brand/model tire itself. There are 28c tires that feel like a frozen garden hose and 28c tires that don't. Size does matter in this case but so does everything else.
#77
Intriguing thread, glad I found it as I have just gotten back to riding my CAAD9 after 10 years. Original 23 Vittoria Zaffiro Pro tires on it that I never gave a second thought back then to the quality of. Now older, smarter and google savvy I find that they are a good tire. Only reason I thought of going larger was to smooth out the expansion cracks on local bike trails. But only up to a 25, never imagining going to 28. 23 sucks in loose gravel at trailhead parking lot but I love how I can throw the bike around, accelerate on them. I would hate to lose that feeling going to wide, thinking I can keep it with a GP5000 in a 25 and smooth it a little. I still like that edge at 63.
thanks to all of you, I learned a lot reading all of the posts.
#78
Quoted: 1088 Post(s)
Liked 1,022 Times
So the new frame I built up I tried to fit a 25mm challenge tire on a 22mm internal width rim and there wasn't enough space to make me happy, the tire measured 28mm wide on that rim. I've since built velocity a23 and have put 23mm Conti on it which I pumped to 90 being a heavier guy. Riding down the street has felt very smooth, grippy and nice and light to throw around. On this rim it measures about 24mm and the wider rim makes it feel nicer than the old open pros did, feels faster too.
i did like the ride of the challenge and will be building the rim with a match into my original race bike which will easily handle the wider width. Admittedly the combo feels fairly quick and nimble as well but not quite as nice, but will do well for the rough roads I prefer riding the steel frame and fork of the old bike on.
#79
It seems most people have made the switch to 25mm tires. But much of the cycling press would like us to believe that if 25mm is good, 28mm must be better! I'm about to mount up a set of tubeless tires on my general, all-purpose road bike. If you've tried 28's, I'm curious what you think of them. Do you run them the same pressure you would run 25's?
No, 28s aren't run at the same pressure as 25s. You'll run them lower (lower max pressure rating on the sidewall too).
Do you like them for the comfort or the speed? Do you think the comfort is worth the loss of speed (if any)?
And are you tubed or tubeless? Let's keep this to paved roads (of whatever quality). Gravel changes the equation in a lot of ways. Have you tried 28mm tires long term on pavement? Do you like them? Do they live up to the hype?
#80
Quoted: 5224 Post(s)
Liked 3,581 Times
Yes to 28s commuted on them for a cpl years. They’re just right. But right now been riding 25s past decade
#81
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
28 and 32mm work great on our tandem, 285 lb. team weight, 95 psi. I ride 23mm on my singles, 100 rear, 80 front..
Results matter
Results matter
#82
Bikes: SL8 Pro, TCR beater
Quoted: 983 Post(s)
Liked 583 Times
Looks like 28 is becoming (or is already?) the new standard in race bikes, isn't it? I always look around when I am in bicycle shops and I see many 2020s with OEM 28mm.
Research seem to indicate they are indeed more efficient & more comfortable. Pwwwwoblem solved!
Likes For eduskator:
#83
Quoted: 722 Post(s)
Liked 353 Times
28's on good steel is like riding a cadillac ....smoove.
Likes For thehammerdog:
#84
It seems most people have made the switch to 25mm tires. But much of the cycling press would like us to believe that if 25mm is good, 28mm must be better! I'm about to mount up a set of tubeless tires on my general, all-purpose road bike. If you've tried 28's, I'm curious what you think of them. Do you run them the same pressure you would run 25's? Do you like them for the comfort or the speed? Do you think the comfort is worth the loss of speed (if any)? And are you tubed or tubeless? Let's keep this to paved roads (of whatever quality). Gravel changes the equation in a lot of ways. Have you tried 28mm tires long term on pavement? Do you like them? Do they live up to the hype?
I was curious about why they were still using tubular tires and questioned it on another site. All of the group "experts" spent several weeks telling me that they were the best tires ever, to ride (I rode tubulars racing and was never very impressed with them). I said that I had rolled a tubular a couple of times in races only to be told that I was stupid and didn't know what I was doing.. Those tires were glued on by a man who worked his entire life as a bike mechanic, made his own frames and supported his own semi-pro teams.
Well, I got a private email from one of the pro mechanics who said that the only reason that they use them is because they have limited roof rack room and that when a team member gets a flat you give him a tire off of the roof rack, and take the flat into the car and as you're pulling him back to the group (illegal but everyone does it) the mechanic can strip the bad tubie off and throw a pre-glued one on, CO2 it to the proper pressure and lean out the window and stick the repaired wheel into the roof rack wheel carrier. I could not even ride my Time Edge VR with 23 mm tires on it. It was far too painful to ride. Yet with the 28's on it, it became one of the nicest riding bikes I ever owned. But it was early and consequently a heavy carbon bike and I moved on.
I mentioned that to these "experts" who again told me I was stupid and no one did that. But watching the Tour de France coverage I saw team mechanics leaning out and putting repaired flats onto the roof rack. I suppose that no one informed these mechanics that they didn't know what they were doing and were stupid.
Likes For RiceAWay:
#85
As for OEM's - maybe that reflects our pus guts. At the end of a season I'm generally back down to 180 lbs and can really tell the difference climbing.
#86
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,830 Times
Don't us tubular people get a category? - you're not even considering the best tires? Bike must not be worthy!
...no need to reply.....
#87
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Recently bumped from 28mm GP5Ks to 32mm GP5Ks, and it just keeps getting better. On my stock wheels, the 32's are only about 1mm wider than the 28's on my wide wheels, but they're significantly taller, so def more volume. More comfort, more grip, no loss of speed (yes, I'm sure in a wind tunnel or TT there's a difference, but normal/fast riding around on crappy roads, gimme the extra rubber). If you've got the room, go for it, they're great!
Likes For Rides4Beer:
Likes For Nman:
#89
I only run tubulars and just went up to a 28mm Veloflex Raven. Used to run Vlaanderens which are spec'ed at 27mm and I loved the soft ride; can't imagine these being any worse.
#90
velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
i'll continue to be one of the few, riding tubular, dissenting voices. i find 28's heavy and slow. rather have the bars double wrapped to minimize road chatter and run 23's to
maintain what little nimbleness, acceleration, handling and lightness they give me vs 28's...or 25's. if all i rode were flats, i'd probably feel differently. if i'm doing a tour
with some/all roads i've never ridden, i'd be more predisposed to do 25's vs 28's. if i'm doing a road ride with a significant percentage (20+%) of dirt/gravel section(s),
then yes, slap on the 28's. i haven't found 28's (or 25's) to be less/more prone to flats or wear than 23's with the same manufacturer/model.
i run the 23's at 95-100 and weigh abo 180. to each their own...
#91
I've recently moved from GP4000 25 to Michelin Power Protection + 28 and could not be happier with them. I previously had used Schwalbe Marathon Plus 25 as there is a ton of debris on the roads where I ride and I was tired of puncture flats from small sharp objects penetrating the tire. Those tires were relatively heavier, slower and harsher riding than I'd like but being able to ride without ever getting a flat was a worthy trade off. I decided while riding in another part of the country to go back to the GP4000 25s and they were definitely much better riding and noticeably faster than the Marathons, which was enjoyable on the smooth, debris free tarmac I was riding on. But back on my usual roads, I began having to deal with the periodic punctures again. I also tried a set of Specialized Turbo Pro 26 w/ blackbelt protection that I had on hand, but found those to not offer much better puncture resistance.
I didn't want to go all the way back to the Marathons and researched to find a happy medium, as well as determining whether my Ultegra 6800 brake calipers would clear 28c tires. I ended up with the Michelins as they seemed to offer considerable puncture protection without the weight and stiffness of the Marathons. I've found that with the lower pressure I can run on the 28s, they're very comfortable, have excellent grip and thus far with a few hundred miles I haven't had any punctures. They are 299g in 28 vs the GP4000 25 at 225g and Specialized Turbo 26 at 250g; meanwhile the Schwalbe Marathons 25 at 580g so not nearly the weight penalty of the Marathons with thus far similar flat protection. I only have experience with this one tire in 28, so how much is the 28 vs the 25 I can't say at this point, but I am finding this 28 setup to be pretty ideal for my riding conditions thus far. I'd definitely recommend trying a 28, especially if your paved roads are not super smooth.
#92
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
#93
Bikes: Lynskey R230, Bianchi Vigorelli, Jamis Dragonslayer, Surly Cross Check, EAI Bareknuckle
I put 28 Gatorskins on whatever road bike will fit them. Seems to hold up better here in the land of glass and goatheads than narrower models -- it might be in my head but they seem to impart a certain security and I don't notice a speed penalty.
#94
Bikes: 86 Nishiki Prestige, Russ Denny, 98CannondaleR4000, Olympus Zeus,Torelli Countach OS, 88 Centurion Ironman Master, 70's Ron Cooper, 91 Klein Quantum, Kuota Kaliber, 04 Trek 5200, Ellsworth Ride, Cannondale MT400 Tandem, 98Cannondale Raven, 86 Fuso
I went from 23's to 28's on a Specialized Roubaix, made a world of difference, especially on the rougher portions of the asphalt
#95
Quoted: 4802 Post(s)
Liked 3,922 Times
It isn't nearly so much the size as the road surfaces you ride over that the specific tire. I really was shocked going from 23 mm Continentals to 28 mm Michelin Pro4 tires on our rotten roads here. The difference in ride and speed was immediately plain. I'm a pretty large guy, 6'4" and 190 lbs and that definitely makes a difference but the pros are using 26 mm wide tubular tires presently on most of their "smooth road" European races. I tried Schwalb and a few others but they didn't rode nearly as well as the Michlin's.
Pure speculation here - those mechanics know that if they run out of spares, that rider cannot finish under the time limit and is out of the Tour and can no longer assist his team leader. Simply not acceptable. I bet that re-tired wheel is not used until the rest of the spares have been depleted. (After all, the mechanic's job and reputation are on the line, A rolled tire doesn't look good for him and may well have big consequences on team earnings. But a rider not finishing because they ran out of wheels? Also not good. Those mechanics earn their pay.)
Edit: You rode tubulars racing and weren't impressed? Did you ride good ones? I raced the Criterium Setas in the '70s like so many of us did. I'm guessing they were no wider than 23c. (Most tires didn't say and width numbers wasn't really in the lingo yet.) Magic carpets. Completely trustworthy cornering. Handled any road surface. Perfect for racing down Smuggler's Notch in VT in the rain, glasses pulled down my nose so I could "see" (barely). Going around corners I'd never seen before but had been told brakes were not needed. Thankfully there was a yellow line. My poor eyesight could see that. Now those tubulars all had their flaws, usually in the stitching around the valve. (Just like true magic carpets - handmade in Persia.) But once you were riding, that didn't matter.
Ben
#96
Im sure, if you wanted, you could glue a clincher too ;-) - or just not ride paper thin race tyres down a mountain a ludicrous speed. Thats just asking for it ...
#97
Quoted: 3947 Post(s)
Liked 7,291 Times
Well, I got a private email from one of the pro mechanics who said that the only reason that they use them [tubulars] is because they have limited roof rack room and that when a team member gets a flat you give him a tire off of the roof rack, and take the flat into the car and as you're pulling him back to the group (illegal but everyone does it) the mechanic can strip the bad tubie off and throw a pre-glued one on, CO2 it to the proper pressure and lean out the window and stick the repaired wheel into the roof rack wheel carrier.
#98
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
I recently got a new bike that came with Roval 50 and 28mm tires. The tires match the Roval 50 rims perfectly. I would speculate that the aero drag coefficient is pretty good but the frontal area not so good. The ride is nice and rolling resistance is great.
I think it gets down to how fast are you going to go and what is the road surface. I will take narrow and higher pressure on good roads versus wider and lower pressure.
#99
Bikes: 2020 Pinarello Dogma F12 Disc (Enve SES 3.4), 2021 S-Works Aethos (Roval Alpinist CLX II), 2024 Topstone Lab71 (Terra CLX II), 2006 Cervelo Soloist (10 speed Ultegra), 2021 S-Works Epic
Quoted: 74 Post(s)
Liked 74 Times
#100
