One piece chain connector rant..
I bought a new chain for my cruiser. The old chain had a connector that is U shaped and snapped right in. The new chain has a one piece solid connector with two holes punched out. I tried everything to snap that @#$$&#$&)()$## on. Nothing. The holes are about 1/16” too far apart. I finally took the U shaped connector off the old chain and used hat.
How the heck do you use the chain connector that is one piece with 2 holes punched in it?
Quoted: 303 Post(s)
Liked 136 Times
You don't, you throw it away and use the vastly better two piece symmetrical design used by SRAM/KMC/Wipperman et al.
My recumbent bought in 2001 had a chain with one of those, back then the symmetrical design was not easy to find but
available.
I assume you refer to the design with a side plate with two pins in it and a separate side plate with two holes that pop
onto the pins to join the chain? Yeah terrible design.
On further thought, you may refer to the design with a master link with a U shaped link that slides over the ends of the
pins, which have tiny slots cut in the ends outside of the outer plate. Sort of like snap ring washers. Not what I refer to as the symmetrical design.
Those date to the 50s in my experience but could be older.
Some pix of various designs: https://duckduckgo.com/?q=bicycle+ch...ages&ia=images
available.
Does anyone use the chain link tool to disconnect and reconnect the chain? That is what diy ended up doing. Any issues with this?
Quoted: 4209 Post(s)
Liked 3,875 Times
The two piece master link described is likely for a 1/8" chain, not a 3/32" der chain. The side plate with two holes does have the hole spacing closer then the pins are. One places the plate with pins intop both ends of the chain and then flexes the chain laterally so to bring the ends of the pins closer together and allow the holed side plate to be slid over the ends. Then when the chain is in use the tension will keep the pin ends trapped in the side plate, unless the chain is again bent laterally.
My preference is to use the three piece master link instead for 1/8" chains. Andy
AndrewRStewart
AndrewRStewart
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
If you have a modern, riveted 3/32" chain, such as used on derailleur-equipped bikes with 8 or more sprockets on the rear cluster, then no. You need to use an appropriately sized master link of some kind to close the chain.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Quoted: 2338 Post(s)
Liked 2,827 Times
and too things are of great help a quick link tool (one the the better tool investments I have made)
and a piece of wire bent at both ends to hold the chain in place while you fiddle with the link
Likes For squirtdad:
I bought a new chain for my cruiser. The old chain had a connector that is U shaped and snapped right in. The new chain has a one piece solid connector with two holes punched out. I tried everything to snap that @#$$&#$&()$## on. Nothing. The holes are about 1/16” too far apart. I finally took the U shaped connector off the old chain and used hat.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Likes For canopus:
SE Wis
Quoted: 2747 Post(s)
Liked 3,399 Times
You connect the master link through the chain like normal making sure it is pushed through the chain completely. Hold the outer plate against the master link, usually aligning one hole with a pin on the master link, then using both hands and a thumb holding the plate in place, gently bend the chain in toward the tire at the master link, this brings the two pins closer together enough to slide the plate onto the pins, when it snaps into place release the chain, The plate is held in place via the master link pin groves and chain tension. Easy peasy.
For these style links.
https://www.ebay.com/itm/New-old-sto...-/303111651154
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Perfectly agree and as old spoke makes the perfect tool for the "wire"
Quoted: 1188 Post(s)
Liked 1,154 Times
Helps too if the chain isn't on the sprockets, so you can flex it properly.
Thanks!
Liked 3,875 Times
No but that's exactly why I like the 3 piece master links, they are harder to come undone. For those who believe that der chains see the hardest use what with shifting stresses and all spend a season servicing kids bikes and you'll likely change your opinions. Kids don't think about their chains (even though the chain is often the critical link (pun) in their brake system), run then loose/tight/rusted. Have skidding contests, jump their little BMX bikes over any curb cut or plywood ramp they can find. Leave their bikes outside all week. Bend their chainrings on other bikes or their legs. Get those training wheels removed by clueless Dads and big sister's boy friends.
I've seen more then a few 2 piece links fail from bent rings/teeth producing the needed lateral prying. No, I'll take a 3 piece any day over the 2 piece. And on my own bike that use 1/8" chain (all with Sturmey Archer IGHs) I'll connect the chains with a pin, just like we used to do with der chains when I was young. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
As far as kids doing accelerated high stress testing of their poor bikes, I resemble that remark. Lost a bit due to the mists of time, but...
We also torture tested skateboards. Our friend's house was on the shallow slope of small valley. Their driveway pointed straight down that slope and intersected the street which ran up and down that valley. Across the street the valley slope continued downward to a creek. We build a skate board ramp sloping up. I think some building site acquisition of materials was made. So you zoomed down the hill, crossed the street, hit the ramp at high velocity, and went up. We build the ramp big enough and with enough slope so that it wasn't a jump (it would have been about a 15 foot drop into the creek). We had fun with skateboards, then tried bikes. Insanely fun. A parent would be arrested for child abuse today if they let their kids do that. Sigh. Good times....
Quoted: 336 Post(s)
Liked 309 Times
I am the guy in our neighborhood who keeps all of the kid’s bikes rolling, but I have much respect for those who do this for a living.
Likes For aggiegrads:
