Who made this (grip) Shifter?
Quoted: 702 Post(s)
Liked 672 Times
I remember riding a bike with one of these. Anyone know who made it and when?
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Both Sturmey-Archer and Shimano used these into the '70s but they were most widely used (and longer) by Shimano. Which IG rear hub do you have?
Likes For thumpism:
Likes For Reynolds:
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 436 Post(s)
Liked 3,467 Times
That shifter was on my red Columbia Sports III in the late 1960s. A great bike!
I never had a problem with that shifter.
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
Likes For SpeedofLite:
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 61 Post(s)
Liked 76 Times
https://www.ebay.co.uk/itm/Vintage-S...4383.l4275.c10
By Sheldon Brown:
The Shimano "333" 3-speed Internal Gear Hub.
While Japan was in stage 1, in 1957, Shimano introduced the "333" 3-speed hub. It was in many ways an innovative design, and managed to avoid infringing on Sturmey-Archer's patents, but it had problems.
The 333 hub was much more complicated internally than the Sturmey-Archer AW. The diameter of the hub was smaller, and so stresses on the internal parts were higher. The metallurgy of Japanese steel at that time was not up to the standards of British steelmaking, so the parts were weaker. Japanese cyclists were (and still are) lighter, on average, than Americans.
The combination of design and metallurgy of the Shimano 333 hub was probably adequate for the needs of the Japanese market, but when sold in the U.S., the hub acquired a reputation for unreliability.
The failure mode of the 333 hub is also different from Sturmey-Archers'.
When a Sturmey-Archer AW hub gives trouble (which it rarely does) it is usually due to lack of lubrication, and one or two of the gears stop functioning reliably. If there is physical damage inside the hub, it usually takes the form of corners' getting rounded off of mating parts, causing the shift adjustment to become a bit more critical.
When a Sturmey-Archer hub gives problems, it can almost always be repaired, usually without needing any parts replacement.
When an older Shimano 3-speed hub fails, it is most often because one of the under-engineered pawls has shattered. The hub may still work after a fashion, so the rider continues to use it until the broken fragments of the pawls have gone on to destroy the gears and other parts, making the hub basically irreparable.
Our basic recommendation is to avoid any Shimano 3-speed hubs other than the Nexus hubs. Generally, older Shimano 3-speed hubs were only ever spec'ed in low-end bikes anyway.
Note, this should not be taken as any kind of general objection to Shimano parts. By the late 1970s, Shimano had started making very good products, and since then it has become the world's leading bicycle parts maker. It should also not be taken as a general indictment of Shimano's internal-gear hubs. With the exception of the early 3-speeds, Shimano internal-gear hubs provide reasonable service if not abused. Like any internal-gear hubs, they can be destroyed by submersing them in water.
Likes For Bob the Mech:
Quoted: 3807 Post(s)
Liked 3,331 Times
the 3-3-3 marking is visible on the end of the handgrip
Likes For juvela:
