What’s changed 2015 to 2020?
Generally speaking, give a budget around $2500 what are the pro/con of buying a 2015 model with all high end gear that originally sold for $9000 Vs a 2020 for the same $2500? Both are carbon fiber construction. Has that much tech and quality trickled down in the last five years to make them comparable or has basic components and manufacturing made a 2020 mid range bike better than a 2015 top end bike? Of course this assumes the 2015 checks out in great condition.
thanks for your thoughts on this.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I have a 2015 Emonda SLR and it's just as much fun as the day I got it.
If it's in excellent mechanical condition... get it.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I have a 2014 custom bike with what were then bleeding-edge components. The only substantive change since I got it is thru-axle rather than quick release (which is an improvement if you have disc brakes). It is 11 speed Ultegra Di2 hydraulic. I'm in no rush to upgrade it. It has 40mm tire clearance, so the Trek Domane, for example, has only recently caught up to it.
In general, wider tire clearances and thru axles are the main improvements.
I like speed
Generally wider tire clearances and disc brakes. However in my case, I can only really say a bit more tire clearance but otherwise really nothing. My comparison is from about a $9000 to $2000 bike with rim brakes.
I've got a 2015 Cannondale SuperSix HM w/ SRAM Red and a 2020 Orbea Orca w/ Shimano 105. Between the two, really no difference in technology aside from the obvious performance differences in weight and groupset. The Orca is the OME frameset so it's bit more relaxed and more comfortable for longer rides. The SuperSix being lighter in weight and more aggressive geometry, averages about 1 MPH faster on the same routes.
I had picked up the Orca before they dropped rim brakes from the line up earlier in the year. However the next bike I'm planning on is an aero bike with disc brakes since I've got to get with the times.
Likes For noodle soup:
Should Be More Popular
Quoted: 22573 Post(s)
Liked 8,919 Times
Agree depends on the details, including model, wear, and of course fit matters most.
Likes For datlas:
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Some new things since I last updated my bikes in 2013:
Endurance geometries
Disc brakes
Thru axle wheels
Electronic shifting and computer linking
Bluetooth sensors
Integrated cockpits
Universal internal cable routing
Press fit bottom brackets
Tubeless tires
Wider tires
Broad acceptance of carbon fiber wheel rims
Much greater selection of power meters (back then they were hub based with just the first crank PMs making an appearance)
PM based advanced cycling dynamics
Really small saddle bags for tubeless setups
Aero road frames
Improved power transfer pedal -> wheel made possible by frames designed around wider press-fit BBs
Rear-facing radars
Just a laundry list. You may or may not care about most of this.
Disc brakes
Thru axle wheels
Bluetooth sensors
Integrated cockpits
Tubeless tires
Wider tires
Aero road frames
Rear-facing radars
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Likes For sfrider:
Quoted: 8261 Post(s)
Liked 8,998 Times
Is the used bike equipped the way you want it or will you have to make changes to the gearing and components? Could be more $$ there.
Does the used bike have any warranty? A guy on here bought a used bike and the frame cracked and the warranty was for the original owner so he was out.
Quoted: 3221 Post(s)
Liked 2,049 Times
Likes For Steve B.:
Quoted: 4717 Post(s)
Liked 1,882 Times
Disc brakes and wider tires. A frame using disc brakes often allows the wider tire, but of the 2, wider tires is the more useful most of the time. My ‘15 model year frame as example, will not accept a tire larger than a 25mm. The other issue related is that is due to the clearance allowed by disc brakes, there’s been a move towards wider rims, which when used on an older frame will make a 25mm tire run wider, like 28mm or so. That means that should you need a new rim/wheel, you’ve got to pay attention that a rim that is now 5mm wider than what you run now, may result in clearance issues with your current tires. Thus you are shopping for a legacy narrow rim.
On Your Left
Liked 2,433 Times
The biggest thing is the frame. a $9000 2015 bike frame will still be better than a $2500 2020 frame. Dura Ace Di2 from 2015 is better than 2020 105. 25mm tires on carbon rims is better than 30mm on cheaper alloy.
Both bikes will be 11 speed, thru axles, disc brakes and 28mm+ tires just don't make as big an improvement over a bottom level carbon compared to top level.
It all depends on the condition. Replacing the bottom bracket, cassette, chainrings, chain, tires and brake pads can easily add another $1000.
Liked 1,882 Times
Likes For Dean V:
Liked 1,882 Times
I have a 2016 that can take a 38mm but it's a CX bike. My road bike can fit 25mm, 28mm will not fit... and i'm OK with that.
On Your Left
Liked 2,433 Times
To use mechanical 105 vs Dura Ace Di2?
I guess it all depends on what's important to you.
Which?
2015 Emonda SLR, Sram Red eTap (or Dura Ace Di2), Zipp 303, 25mm tire, rim brakes 14# - $10,000
2021 Emonda SL, Shimano 105, Bontrager alloy rims, 28mm tires, disc brakes 20# - $2500
Sorry, i've ridden both and the 2015 is still my choice.
Liked 1,882 Times
How about that forced you to a heavier and less compliant frame?
Which?
Which?
On Your Left
Liked 2,433 Times
On Your Left
Liked 2,433 Times
Expired Member
Quoted: 3657 Post(s)
Liked 5,393 Times
Again, OP needs to specify the two bikes. We're sort of assuming 11 speed DuraAce Di2 and fancy carbon wheels but a seller could describe anything as "top end."
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Bike wars!
On Your Left
Liked 2,433 Times
He said $9000, so unless he's looking at a full suspension bike and posted in the wrong forum.... Di2 and carbon wheels are a safe assumption.
Liked 1,882 Times
I'm not sure why you think the high end 2015 bike is going to be more compliant. That's rarely the case.
Liked 2,049 Times
The rub on this with a 5 year old rim brake bike, is you really need to look at some key areas like under the fork, the chain stay clearance, etc..., to determine if you would have the clearance in the event you want to run a 28 or 32mm tire. You are more likely to get tire clearance on a newer frame.
I happen to be of the same opinion as Glenn that I’m perfectly OK with a 25mm tire on my road bike.
It would help if we knew what bikes the OP was looking at.
Likes For Steve B.:
Expired Member
Liked 5,393 Times
I think I may have misread the first post. I had in mind OP was trying to decide which of two bikes to buy. Now I see "Generally speaking...." so maybe there aren't two actual bikes and this is just noodling. If that's the case, never mind, over and out.
Likes For shelbyfv:
