Havenít biked in years, starting over. Whyís everyone riding on less psi now?
Road Cycling ďIt is by riding a bicycle that you learn the contours of a country best, since you have to sweat up the hills and coast down them. Thus you remember them as they actually are, while in a motor car only a high hill impresses you, and you have no such accurate remembrance of country you have driven through as you gain by riding a bicycle.Ē -- Ernest Hemingway
Old 09-19-20, 01:54 PM
Sapience
Liked 2 Times in 1 Post
I havenít biked in forever and now Iím a fatty. Iím trying to get back on the bike and ride myself back into shape. Itís been fun reading these forums again, especially that thread on Gatorskins because I just bought some again last week (I live in AZ where thorns are everywhere so go easy on me)
One thing Iíve noticed is a lot of people are running on less PSI. I weigh 155 and used to run 110 in my front wheel and 120 in my rear. This seems to be uncommon now. Whatís the rationale for less psi and what should I be riding at these days? Thanks all
Sapience is offline
Old 09-19-20, 01:58 PM
GlennR
Passing on your left
GlennR's Avatar
Quoted: 2101 Post(s)
Liked 1,054 Times in 565 Posts
That's because wider tires distribute the weight over a wider contact patch.
When you ran 110/120 were you on 19mm or 23mm tires? These days 28mm are very common and some run 32mm. Tubeless also reqire less pressure.
GlennR is offline
Likes For GlennR:
Old 09-19-20, 02:03 PM
Sapience
Hey thanks for the info. I was running 23s back then, and I just picked up 25s. Would you recommend I stay at 110/120 psi or come down a bit? Iím running tubed, but keep seeing the GP5000 tubeless mentioned. Not sure if itís worth ditching the Gatorskins sooner than later to switch Tubeless
Sapience is offline
Old 09-19-20, 02:24 PM
masi61
masi61's Avatar
Quoted: 621 Post(s)
Liked 97 Times in 72 Posts
What rims do you have? Older rims may not be tubeless ready without doing extraordinary measures (i.e. ghetto tubeless).
masi61 is offline
Likes For masi61:
Old 09-19-20, 02:31 PM
Bah Humbug
runner
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 6125 Post(s)
Liked 1,697 Times in 908 Posts
I haven’t biked in forever andnow I’m a fatty. I’m trying to get back on the bike and ride myself back into shape. It’s been fun reading these forums again, especially that thread on Gatorskins because I just bought some again last week (I live in AZ where thorns are everywhere so go easy on me)
One thing I’ve noticed is a lot of people are running on less PSI. I weigh 155 and used to run 110 in my front wheel and 120 in my rear. This seems to be uncommon now. What’s the rationale for less psi and what should I be riding at these days? Thanks all
Bah Humbug is offline
Old 09-19-20, 02:37 PM
DaveSSS
Bikes: TWO Colnago C-RS w/Chorus 12
Quoted: 474 Post(s)
Liked 182 Times in 146 Posts
155 is twenty pounds more than I weigh. I was fat at 148. Now I'm back to 133-135. I can wear all of my old jerseys that date back to the early 90's.
As for tire pressure, 85 front, 90 rear should be plenty on 25mm.
DaveSSS is offline
Likes For DaveSSS:
Old 09-19-20, 02:38 PM
Sapience
oh boy Iím on my old 2012 specialized allez. Wheels are 2012 DT Swiss 2.0s that came stock
In the event I keep running tubed gators @ 25 for the interim, what psi would you suggest?
thanks for the help
Sapience is offline
Old 09-19-20, 02:44 PM
Bah Humbug
runner
Bah Humbug's Avatar
Bikes: S1, R2, P2
But then man, what's the word for me at 175lbs?
Likes For Bah Humbug:
Old 09-19-20, 02:52 PM
HTupolev
Quoted: 1561 Post(s)
Liked 522 Times in 276 Posts
High PSI reduces the amount of energy lost due to the tire deforming against the road surface. But, if the tire is pumped stiff to where it's transmitting surface irregularities to the bike and rider (rather than smoothly deforming around the irregularities), that energy spent vibrating the bike and rider is getting stolen from your forward motion. So excessively high pressure is not only less comfortable, it can also be slower.
The "optimal" pressure depends on a lot of variables: the tire size, the mass of the bike and rider, and the roughness of the particular surface, among other things. Smoother surfaces and heavier riders should use higher pressures.
The wider the tire, the less it will deform against the road surface for a given PSI, so lower pressures should be used with wider tires.
When unsure about optimal pressure, it tends to be much better to err low than high.
This is a good article on the subject.
HTupolev is online now
Old 09-19-20, 03:02 PM
Sapience
Gentlemen I really appreciate the help. Although some things in cycling have changed for me, good to see this community is still active and helpful
Sapience is offline
Old 09-19-20, 03:08 PM
wgscott
Occam's Rotor
wgscott's Avatar
Quoted: 2366 Post(s)
Liked 1,480 Times in 746 Posts
Malnourished.
wgscott is offline
Old 09-19-20, 03:09 PM
datlas
Beyond Bogus
datlas's Avatar
Quoted: 13047 Post(s)
Liked 1,914 Times in 1,014 Posts
I suggest you try 80F 90R. You can tweak up/down 5-10 based on road conditions.
Addiction is all about class.
datlas is offline
Likes For datlas:
Old 09-19-20, 04:15 PM
Litespud
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor S/S, Nashbar 3sp commuter
Quoted: 365 Post(s)
Liked 328 Times in 185 Posts
Hey thanks for the info. I was running 23s back then, and I just picked up 25s. Would you recommend I stay at 110/120 psi or come down a bit? I’m running tubed, but keep seeing the GP5000 tubeless mentioned. Not sure if it’s worth ditching the Gatorskins sooner than later to switch Tubeless
I'm 185# and I run tubed 25s at 90psi front and 95psi rear. 110/120 at 155# will rattle your fillings out
Litespud is offline
Old 09-19-20, 04:29 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Bikes: Canyon Endurace, 105; Battaglin MAX, Chorus; Bianchi 928 Veloce; Ritchey Road Logic, Dura Ace
Quoted: 778 Post(s)
Liked 900 Times in 480 Posts
Might be 5 foot nothing.
genejockey is online now
Old 09-19-20, 04:34 PM
genejockey
genejockey's Avatar
Quoted: 778 Post(s)
This was also my happy discovery when I started paying attention to road bike tech again after a dozen years. Running 28s at 90/95 on two of my bikes, and 25s at 95/100 on the other two has been a revelation!
Old 09-19-20, 05:48 PM
Bah Humbug
runner
Bah Humbug's Avatar
Bikes: S1, R2, P2
Tire pressure donít care though. A 155lber, no matter how they get there, has more leeway in pressure than you or I do.
Old 09-19-20, 05:58 PM
noodle soup
noodle soup's Avatar
Quoted: 4446 Post(s)
Liked 1,549 Times in 842 Posts
5' and 155 pounds is pretty fat for that height, but it's still only 155 pounds as far as tire inflation is concerned,
noodle soup is offline
Old 09-19-20, 06:01 PM
bruce19
bruce19's Avatar
Quoted: 1262 Post(s)
Liked 603 Times in 363 Posts
I'm running 25's that are tubeless and I run approx 85-90 psi rear and 75 psi front. I'm 185 lbs.
bruce19 is offline
Old 09-19-20, 06:02 PM
genejockey
genejockey's Avatar
Quoted: 778 Post(s)
Yes, but Bah,Humbug highlighted "I'm a fatty" and "I weigh 155" and added a headscratchng icon, so I pointed out a situation in which those two statements are not at odds.
Old 09-19-20, 06:05 PM
genejockey
genejockey's Avatar
Quoted: 778 Post(s)
I use the Silca and SRAM calculators, then aim in between. The only times I've ever pinch flatted were both hitting God's Own Potholes at >25 mph (dappled sunlight). One of the times the hit was so hard I managed to turn the bar down in the stem, and both bottles popped out of their cages.
Likes For genejockey:
Old 09-19-20, 06:08 PM
znomit
Zoom zoom zoom zoom bonk
znomit's Avatar
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35
Quoted: 336 Post(s)
Liked 332 Times in 159 Posts
Drop the pressure until you get pinch flats, then add 10psi.
znomit is offline
Likes For znomit:
Old 09-19-20, 06:13 PM
Bah Humbug
runner
Bah Humbug's Avatar
Bikes: S1, R2, P2
Not in abstract, but yes, I meant in the context of tire inflation.
Old 09-19-20, 06:20 PM
GlennR
GlennR's Avatar
That's like tighten till it snaps and back off 1/4 turn.
I determined my optimal psi by trial and error. I started high and went for a ride. Over the next few weeks I lowered it until If felt better and then squishy.
Your weight, the tires you pick, the size of the rims and your personal feel. I did the same with my collector car when I went with different size wheels and tires.
GlennR is offline
Likes For GlennR:
Old 09-19-20, 06:21 PM
genejockey
genejockey's Avatar
Quoted: 778 Post(s)
If you don't mind my saying so your post was rather minimal. I don't think my interpretation was entirely out of left field.
Old 09-19-20, 06:22 PM
znomit
znomit's Avatar
Quoted: 336 Post(s)
So, you mean like trialing lower pressures until you find an error (a pinch flat?).
znomit is offline
