Big Hole in the downtube for cabling
Old 09-20-20, 04:53 AM
Machoman121
Quoted: 95 Post(s)
Liked 9 Times in 5 Posts
How would you best try to cover up this hole so that dirt and water won't go into the bike?
I was thinking of stuffing some plastic sheets in there but once it gets lost in the tube there's no getting it out.
Merida Silex 400
Machoman121 is offline
Old 09-20-20, 05:43 AM
John_V
John_V's Avatar
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times in 85 Posts
I would leave it alone. Any water that gets in will drain from the holes below. However, if you're really concerned about dirt and other stuff getting into the frame, I would use a thin bead of clear, silicon caulking.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
John_V is offline
Likes For John_V:
Old 09-20-20, 06:14 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Liked 880 Times in 527 Posts
I'd leave it open as well. Though since you do have a small hole in the bottom bracket shell that will allow drainage, it would not hurt to put a small piece of foam in the gap and cover with tape. Don't worry about stuff getting lost in the tube. Anything you put there should eventually migrate to the BB shell.
Moe Zhoost is offline
Old 09-20-20, 06:26 AM
Machoman121
Quoted: 95 Post(s)
Dirt does go in.... from the hole - Giant Aluminium Revolt:
https://youtu.be/wCvbTqsOfEY
Old 09-20-20, 06:32 AM
Koyote
Quoted: 6958 Post(s)
Liked 10,959 Times in 4,686 Posts
I would assume that the people who designed the frame knew what they were doing.
Koyote is offline
Likes For Koyote:
Old 09-20-20, 07:10 AM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
Pull your bottom bracket once a year and clean it out if you are bothered by it. If that is too much, get a cheaper bike to ride in the dirt.
c_m_shooter is offline
Old 09-20-20, 07:46 AM
GAtkins
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times in 44 Posts
I'd leave it open as well. But if you want to close it my thought would be spray-foam insulation.
Glenn
GAtkins is offline
Old 09-20-20, 08:32 AM
Arthur Peabody
Quoted: 250 Post(s)
Liked 110 Times in 66 Posts
A rubber grommet woulc be elegant. I run my cables inside my frame.
Arthur Peabody is offline
Old 09-21-20, 05:05 AM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2744 Post(s)
Liked 3,390 Times in 2,053 Posts
You have more faith in designers than I do.
What they are designing for is unknown. Esthetics? price point? ease of assembly? I doubt longevity or ease of maintenance.
dedhed is offline
Old 09-21-20, 06:35 AM
unterhausen
Randomhead
Liked 3,694 Times in 2,516 Posts
this design element has been used for quite some time. If there were serious issues, I think we would have heard about it. Having said that, I don't like it either.
unterhausen is offline
Old 09-21-20, 12:36 PM
Barry2
LR÷P=HR
Quoted: 865 Post(s)
Liked 1,203 Times in 692 Posts
Bung
I'd fashion a bung from a Staedtler Mars Plastic Eraser or some similar material.
You can pop it out when you get the bike wet.
Barry
Barry2 is offline
Old 09-21-20, 04:15 PM
aclinjury
Quoted: 497 Post(s)
Liked 170 Times in 128 Posts
ziptie the 3 housings together, then electrical tape on the hole. Don't overthink it
aclinjury is offline
Old 09-21-20, 04:32 PM
GlennR
On Your Left
GlennR's Avatar
Quoted: 3004 Post(s)
Liked 2,433 Times in 1,187 Posts
PLEASE DON'T
I assume it's a joke but you never know.....
GlennR is offline
Likes For GlennR:
Old 09-22-20, 02:45 AM
Machoman121
Quoted: 95 Post(s)
Originally Posted by Rolla
nice - tat's perfect. I'll have to go see if it's available where i am.
Old 09-22-20, 06:28 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 986 Post(s)
Originally Posted by GlennR
PLEASE DON'T
Yes, put this idea out of your head. Spray foam is 1) messy - no matter how careful you are it will expand well past the area you are trying to plug -AND- 2) it is tenacious - you will never get it off without a lot of effort and probable damage to what it's on. Cable housing you can replace, but do you want to take a razor blade to your frame? Go simple mate, push in a small piece of packing foam ... or just leave it alone and ride happy.
Likes For Moe Zhoost:
Old 09-22-20, 07:26 AM
nomadmax
Quoted: 1104 Post(s)
Liked 1,824 Times in 878 Posts
Everyone in this thread will be long dead and gone before that open cable gangway will cause any problems; if ever. Work on another problem, that one is OK.
nomadmax is offline
Old 09-22-20, 09:17 AM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
PLEASE DON'T I assume it's a joke but you never know.....
Yeah, I thought it was obviously a joke. You use that stuff to seal gaps in brick siding to keep bugs and critters out. It adheres tenaciously and might not be removable. I'll delete my original post. Also, plastic bags are not toys!
Rolla is offline
Old 09-22-20, 11:10 AM
70sSanO
70sSanO's Avatar
Quoted: 1943 Post(s)
Liked 2,164 Times in 1,323 Posts
If you really have your mind set to waste the time to fashion something, I’d look into rubber spark plug wire looms/separators.
The holes for the ignition wire are probably too large, and you may have to just get a 1/4” thick sheet of durometer 60 rubber and make something similar. You will have to pull your cables and run the housing through whatever you make. And unless it is a thrft store bike, I imagine you want it appear remotely well designed and not look like....
Attaching it might be a issue unless you can wedge it in there tight enough and let the housings hold it in place. Of course if you’ve gone this far, you might as well make blue anodized 1/4 turn fasteners.
The reality is most likely just a solution looking for a problem.
John
70sSanO is offline
Old 09-22-20, 03:43 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 178 Post(s)
Liked 177 Times in 101 Posts
I think there's a good possibility you're missing a plastic sleeve. Take a look at this video at 2:24 and 4:08. Hard to see, but it looks entirely black behind the cables. And what are those three holes in the BB shell for?
I would go to Merida's website and ask them, or use their dealer search and find a dealer you can ask.
Rogerogeroge is offline
Old 09-22-20, 10:13 PM
Machoman121
Quoted: 95 Post(s)
https://www.youtube.com/watch?v=7vgUfr2-pug
i've checked the video out - there's no cover in taht area - it is what it is. A hole in the downtube that lets the cable out.
