Heart Rate Controlled ERG/Resistance on Trainer
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
I'm being asked to train to HR and not Watts.
I wonder if Heart Rate Control (HRC) is available for a Wahoo Trainer over Ant+ or BLE
Don't care if the solution is Hardware or Software.
I'm looking to set a HR and have the Trainer resistance vary to keep me around that HR.
All of my searching seems to find ellipticals with the function built-in.
Thanks
Barry
Yes I originally posted this in the "Indoor" forum. But with "Indoor" being so hard to find hidden under "Road" I thought I'd try here among the masses.
Thanks
Barry
I know that Zwift in workout mode will control to power (watts.) The only work around that I see is to just free ride around and vary your work load manually by looking at your heart rate. After all, that is similar to what happens on the road, I would guess.
Is this for a set program of training or with a professional trainer?
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
The Wahoo fitness app comes close to doing what you want to do, not sure it will do the power adjust to maintain a constant heart rate or stay in zone but you can definitely setup a display to see.
I've ridden exercycles that had the mode you want and never liked it - heart rate is a very variable variable!
Bikes: Shmikes
Quoted: 10152 Post(s)
Liked 5,843 Times
The HR response has a huge phase lag and the power/HR curve is logarithmic. Moreover, the power/HR ratio drifts downward throughout a workout, particularly indoors where it tends to be hot.
How would it this system be used? I could see it for steady state workouts, but I don't think it would work very well for structured intervals.
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
Tech-Head wants HRC
For structured Intervals I build an ERG plan in ZWOfactory, copy it to the Wahoo Roam and run the plan from there. The Wahoo Bike follows along just fine and the Roam displays progression through the plan.
I want HRC for for long periods of a single HR/zone.
All of my training so far has been to a given power. My coach is asking I train to a given HR.
Yes, the HRower has lag... so significant damping required.
Yes, the power drifts downwards during the workout, that is the point of having HRC.
Don't get me wrong, I'm already doing this manually using the Roam to both monitor HR and to manually reduce the bikes ERG power setting during the workout.
Just having seen the feature available for other exercise machines, I thought it would be there for cyclists. After all, a lot of us are tech-heads.
Barry
Barry
Bikes: Shmikes
Liked 5,843 Times
Barry
Barry
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
With this baseline in hand a master plan will be devised.
And with this plan....and I quote "We will try to take over the world!"*
Barry
* The Brain
Quoted: 1247 Post(s)
Liked 1,322 Times
I hope you post the solution if you find one. It would be an interesting change to the usual trainer metrics however the smoothing algorithm to add and remove load based on heart rate would be quite challenging.
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
$0.99
All I'm asking for is a $0.99 app store program I can stuff on my Apple TV - Come on people, who wants my $0.99 ?
(I might even pay a bit more than that) 8-)
Barry
Bikes: Shmikes
Liked 5,843 Times
Good luck, man! Onward and upward with the arts and sciences.
Liked 2,946 Times
I'd ask the professional coach to provide you with a solution. They're the one telling you to maintain data that they want to see.
-Oh Hey!
-Oh Hey!
