Yet again a question about Campy bottom bracket spindle taper...
Bottecchia fan
Bikes: 1959 Bottecchia Milano-Sanremo (frame), 1966 Bottecchia Professional (frame), 1971 Bottecchia Professional (frame), 1973 Bottecchia Gran Turismo, 1974 Bottecchia Special, 1977 Bottecchia Special (frame), 1974 Peugeot UO-8
Quoted: 33 Post(s)
Liked 12 Times
I thought this had been covered a million times but as I searched the forums I could not come up with a definitive answer. I know Campagnolo spindles used ISO taper in the C&V period. I think they continued to use ISO taper until Campagnolo retired the square taper design for Ultra-Torque a couple of years ago. But I've seen references to Campagnolo having made a change to the spindle taper in the early 90's so that modern square taper Campagnolo bottom brackets would not fit classic cranks. Can anyone confirm or deny that rumor? I could not find anything from Sheldon Brown, Campagnolo, or Phil Wood making any reference to "old" Campy taper and "new" Campy taper so I'm betting there was no change and it's all just ISO. I'd just like to be sure. Thanks.
1959 Bottecchia Milano-Sanremo(frame), 1966 Bottecchia Professional (frame), 1971 Bottecchia Professional (frame),
1974 Peugeot UO-8, 1988 Panasonic PT-3500, 2002 Bianchi Veloce, 2004 Bianchi Pista
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Campy tapers pre '94 are not ISO. Early stronglight spindles are, and some others. Unfortunately they are not JIS either, just kind of their own Italian design.
FWIW, I took a circa '81 Stronglight crank (ISO) and placed it on an ISO spindle, a 70's Campy spindle, and a JIS spindle. The q-factor went from "X"mm on an ISO taper, to "X+3" on the 70's Campy, an measured "x+6" on the JIS.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
I have never had a problem swapping older European and SunTour spindles and cranks, including Campagnolo. Shimano was the odd man out in the 1970s, but evidently by the mid 1990s everyone else had conformed to them, presumably for a slightly stronger spindle.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
Well, what I'd like to do is use a nice modern Campagnolo light weight, hollow spindle, cartridge bottom bracket like a Centaur or Chorus with a vintage Record Strada crank. Hence why I need to know if Campagnolo ever changed the spindles. In fact, IIRC, it might have been you that said you had problems trying something like that John. If you look at modern square taper Campy spindles today they specify ISO taper. But now Bob Baker is saying the old ones were NOT ISO. So now I really don't know. Alas, if only I had a Sutherland's.
Disraeli Gears
I think that Bob Barker's correct, according to all the info I've been able to dig up, and also based on my own measurement of various spindles. As Sutherland's says, the end square goes from smallest to largest: ISO, Campy, and JIS. I also believe that Suntour Superbe (different from other Suntour, reportedly), and Sugino Mighty (MW) spindles are Campy clones, as far as my dial caliper can tell, anyway.
And also (though I have no first hand knowledge here), I believe that Campy did change from their own standard to ISO in the 90s. Phil Wood's site has always recommended JIS for older Campy cranks.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
Ok so it would seem that if you attempted to use a modern Campy bottom bracket with a vintage Campy crank, the modern spindle would be too narrow and the crank might bottom on the spindle. Well crud! I should probably call or email Phil Wood to verify what they recommend. As I mentioned, they only list "Campagnolo" on their site so they say nothing about older and newer that I could find.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Disraeli Gears
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
My question for pre-1990ish Campy double-chainring cranks, what would be the best spindle lengths for recent English and Italian threaded cartridge BBs?
Also, what were the original Campy spindle lengths for pre-1990ish English and Italian threaded BBs for Campy double-chainring cranks?
Thanks.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
Try here, look on p. 14:
https://www.philwood.com/index/2008%20Catalog.pdf
Quoted: 1858 Post(s)
Liked 664 Times
Do you need an NR BB? Sounds like you're trying to get around using one. I have one, unused, NIB, for an English BB. The spindle is a 68-SS-120. Check it out at Greg Parker's commercial site, https://www.bicycleclassics.com/, he's put together a really good compatibility guide for early Campy cranksets, as well as being a great but $$ source of NOS parts. Mine has cups, lockring, spindle, crank bolts, and original caged bearings. Greg doesn't really sort out the entire history, he's definitely focused on the early days, and except for a few key items, he doesn't do Japanese.
Kommissar, you could use that site to sort out the wild variations in NR cranks and BBs, if you haven't, and see if you can use mine. PM me if you're interested.
Bikes: 2005 S-Works SR Equipped,1978 Tom Ritchie Road bike, Kuwahara Tandem
I have the exact same set up. Well to tell you the truth I have a NOS Record crank that is around the late 70's era. I have a 102mm Record spindle for the last years of the square mount Record cranks. I will have to dig the parts up but if you are wondering if the taper will fit and bolt up I will post before Sunday to let you know.
Liked 664 Times
My recollection is that JIS and Campy have the same taper angles, but JIS has a smaller cross-section. If they had different taper angles and you tried to install, you'd get uneven stress distrubution in the aluminum of the crankset, which I would not want on my bike. As it is they'll be evenly stressed, but because of the smaller cross section, the Campy crank will fit on teh JIS axle with narrower Q factor or tread, and it might end up rubbing on the cups! So it would bolt togetner ok, but not work ok.
Torqueing a crank onto a taper, the aluminum crank expands in a known way, that over the years has proven reliable. There are other long-term stress issues in NR and SR cranks, but not related to the tapers. I'd be very nervous about upsetting that balanced situation that Campy engineered, by substituting potentialy non-compatible BB parts. Getting another replacement crank is expensive, and only promises to become more so.
Liked 664 Times
One source who I know could absolutely nail the answers for you, Kommisar, is Peter Chisolm at Vecchio's Bicicletteria in Boulder, CO. He takes phone calls. I always just look up their website to get the phone number.
You could just drive up there, as long as Monument Pass on I-25 is not closed!
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
Exactly. I was thinking something lighter to save weight. It just might not be practicle however.
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
Bikes: 1978 Schwinn Paramount racer, 1974 Schwinn Paramount racer, 1973 Schwinn tourer, 15+ Schwinn Stingrays from the 70s, 1989 Klein Quantum roadie, 1985 Falcon Race roadie, 1999 K2 MTB
My 1989 Klein has the original bottom bracket. I recently replaced the pressed in bb bearings but that is another story.
I replaced the original Chorus first generation crankset with a 2000 model Chorus 10speed crankset and it worked beautifully.
Disraeli Gears
Liked 664 Times
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
722 S. Pearl Street, Denver CO 80209
303-722-3004
Liked 664 Times
Bottecchia fan
Quoted: 33 Post(s)
Liked 12 Times
LOL...not a clue. I'm a "redneck" from down here in the 'Springs, not one of those sophisticated Denverites. My customers and vendors are in the Tech Center and my buddy in Denver lives nearby near Cherry Creek so I've never had much reason to go past there.
Shucks I'll have to take me a vacation and go visit the big city
If you have time, PM me and maybe we can do lunch or something when you're there.
Bikes: Road Cyclocross
I just went through the spindle dilemna as I have two sets of Campy cranks from the early to mid 90's. I talked to the Campy guy in California who had me email one of their product guys in Italy.
After getting confusing info from both of them, I resigned myself to having to buy Campy sealed bottom brackets from the mid 90's.........UNTIL
In speaking to a very well versed Campy guy that works for one of the larger mail order bike stores in the country he told me that the Token and Accura bottom brackets sold on Ebay as being suitable for pre 94 cranks work great.
I'm not so much of a Campy snob that the idea of paying right around a $100 for a new sealed bearing bottom bracket that weighed a lot less than a conventional bb wasn't appealing.
I bought a Ital thread and a English thread. They slid right in and are very smooth.
