1979 Schwinn Sports Limited F/F
Bikes: LESS than I did a year ago!
Quoted: 70 Post(s)
Liked 6 Times
For your consideration...
1979 Schwinn Sports Limited Frame and Fork...with most, but not all components
I bought this frame a bit over a year ago, with great intentions...but...like my riding, my building up has stalled...so, this is the first of a couple frames that I am going to see if anybody wants.
Specifications to the Frame...
Seat Tube (CTC) - 55 cm
Seat Tube (CTT) - 57 cm
Top Tube (CTC) - 56 cm
Rear Gap - 125 mm
Material: Schwinn CroMoly Fillet Brazed
Frame and Fork are in good shape for a bike this old...paint and decals are bit beat up! This was the very end of the line for Schwinn's Fillet Brazed bikes...only made in 1979 and only in Red...Schwinn was using up some older frames with this line. Only about 1000 were ever made...and, of course, they are VERY rare today...I have not seen more than about 1 or 2 on eBay in the last year or so! But...I do not search for them every day!
So, while this one is a bit beat up...it does command some premium...and, who knows, maybe I am undervaluing (or overvaluing) it! If it sells immediately, then I know I undervalued it! But, if you think I overvalue...shoot me an offer.
As for components for it...
Headset Standard Headset
Bottom Bracket Do not know, but on bike
Gear Cluster N/A
Rear Derailleur Suntour VG-T Luxe Rear Derailleur, Long Cage, Vista Panto
Front Derailleur Schwinn Approved Front Derailleur, Double Rings
Shift Levers Schwinn Approved Stem Shifters
Brake Calipers Weinmann Schwinn Approved Standard Side Pull Brake Calipers, Front/Rear
Brake Levers Weinmann Standard Brake Levers
Crankset Schwinn Approved Le Tour Crankset
Pedals Schwinn Approved Platform Pedals w/Toe Clip and Strap
Stem N/A
Handlebars N/A
Saddle Black Shell
Seat Post Standard Steel Seat Post (Loose)
Quick Release N/A
Cable Clamps N/A
Cable Guides N/A
Front Hub N/A
Front Rim N/A
Rear Hub N/A
Rear Rim N/A
Tires N/A
Chain N/A
Chain Rings N/A
Seat Post Binder Bolt w/Frame
If it is "N/A"...it is not included
Price is $300 plus shipping (usually around $50)...Paypal Friends and Family (if you want other Paypal, you pay fees)
Pictures
Rear Gap - 125 mm
Gear Cluster N/A
Stem N/A
Handlebars N/A
Saddle Black Shell
Quick Release N/A
Cable Clamps N/A
Cable Guides N/A
Front Hub N/A
Front Rim N/A
Rear Hub N/A
Rear Rim N/A
Tires N/A
Chain N/A
Chain Rings N/A
Pictures
paulgr
3
12-21-12 09:35 PM
