Are there any booties/toe warmers that will work with non-cycling shoes?
Old 06-24-20, 12:47 AM
Falchoon
Falchoon's Avatar
Quoted: 27 Post(s)
Are there any booties/toe warmers that will work with non-cycling shoes? My girlfriend likes to get out on her MTB but it's getting too cold for her, she said she couldn't feel her feet after riding this morning at 6.30.
She just wears normal sneakers (today with Explorer socks!) and doesn't want cleated cycling shoes.Talking temps at or below 0 degree Celsius (32 degree Fahrenheit).
Falchoon is offline
Old 06-24-20, 06:31 AM
Pop N Wood
Quoted: 667 Post(s)
Liked 529 Times in 355 Posts
I've had pretty good luck with neoprene toe warmers that go on the outside of the shoe.
https://www.rei.com/product/803548/p...hoe-toe-covers
You can get ones that go inside the shoe as well
https://www.amazon.com/Meister-Therm.../dp/B00QW10XIA
You really just need something to block the wind. Duct tape works, bu not as well at the neoprene ones. I've read posts claiming wrapping your socks in aluminum foil works great as well
But since you are dealing with a girlfriend solutions will need to be elegant.
Pop N Wood is offline
Likes For Pop N Wood:
Old 06-24-20, 06:45 AM
Jim from Boston
Jim from Boston's Avatar
Quoted: 800 Post(s)
Liked 218 Times in 171 Posts
I have previously posted about using Totes shoe covers, with additional Gore-Tex wrap-around covers for added warmth
Originally Posted by Jim from Boston
This past Monday (12/30/13) I did my 14 mile commute at about 15°F and tried a new set of foot coverings that IMO that kept my feet significantly warmer than usual. In the past I had bought a pair of neon green shoe covers made by Gore-Tex, for wet riding.
During the winter, I use platform pedals with toeclips, and my usual footwear is thin and thick socks, running shoes and Totes rubber overshoes. I use plastic bags over my running shoes to put on the Totes more easily (see the sequence below).
So with the additional Gore-Tex shoe coverings at 15ºF, I did not perceive cold until about mile 10, and I did not feel cold in the sense of permeating the soft tissues of my foot until about mile 12, but it was tolerable.
At about mile 12 I have a downhill run of several hundred yards that irreversibly drains the heat from my extremities. The next day at 21ºF, I rode without the Goretex, and started feeling cold at about mile 9 and finished significantly colder at my mile 14 destination than the day before.
Consider also the use of plastic bags over the socks as an additional layer.
Jim from Boston is offline
Old 06-24-20, 08:10 AM
Razorrock
Bikes: Litespeed
Quoted: 81 Post(s)
Liked 32 Times in 21 Posts
I use the Neoprene covers over sneakers all the time. Just order the largest size. non-cycling shoes are usually bulkier.
Shoe Covers
Razorrock is offline
Old 06-24-20, 08:30 AM
BlazingPedals
BlazingPedals's Avatar
Quoted: 1513 Post(s)
Liked 734 Times in 455 Posts
For the occasional cold ride, I just use some chemical toe warmers, which go in the shoes, under the toes. They actually work better if you don't seal your feet with booties and plastic bags. BTW if the ride is short you can put the warmers in a baggie and the chemical reaction will pretty much stop; or at least they'll store for several days.
The big brand around here is Grabber.
BlazingPedals is offline
Old 06-24-20, 08:41 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
NEOS are the contemporary galoshes https://www.overshoesneos.com/
I Wear Blundstones in the winter , up north, 6 months from now, here..
fietsbob is offline
Old 06-24-20, 11:04 AM
Toadmeister
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times in 170 Posts
I use these also. I usually buy a box each hunting season and use them for biking too.
Toadmeister is offline
