Quick question on 105 hub
Quoted: 595 Post(s)
Liked 281 Times
Gentlemen, I was cleaning and repacking bearings on a Shimao 105 5700 rear and front hub. When I was done, I noticed a small, maybe less than 1mm thick washer left over that I think might have gone on the rear hub axle? possibly between the thick spacer, locking nut, and/or cup assembly or maybe I'm way off. I removed the axle by only removing the left non drive side lock ring and assembly to get at the bearings. I'm sorry I don't have another shimano hub to look at and can't find the small washer on any schematic. Do you have an idea where it might go? As always, thanks for your input.
Quoted: 114 Post(s)
Liked 119 Times
You might be able to find exploded view here: https://si.shimano.com/#/
Quoted: 114 Post(s)
Liked 119 Times
I think this is the one: https://si.shimano.com/api/publish/s...5700-3006A.pdf
Likes For MudPie:
Quoted: 595 Post(s)
Liked 281 Times
Thanks guys, I see it now in that schematic, between the spacer and the locknut. Damn, I wish I could have seen this earlier and wouldn't have needed to trouble you fine fellows. Thanks again.
