Fulcrum AFS brake disc mounting system
Bikes: '76 Centurion Pro Tour, '78 Centurion Super LeMans custom, '10 Scott CR1 Comp/Pro, '11 KHS Tandemania Cross, '96 Kestrel 200 SCi, German Centurion Al Road Bike, Cannondale 500 (M&W), Museeuw/ZRace project
Quoted: 11 Post(s)
Liked 8 Times
Does anyone have Fulcrum disc brake wheels? I am doing a frame-up build and am considering a Fulcrum wheelset. But I don't understand the proprietary "AFS" rotor mounting system that Fulcrum has. Can anyone give me a tutorial? Specifically, how does the system allow for 142mm AND 135mm dropout measurements? How do the rotors mount and what type of rotors do I need - centerlock or 6-bolt? Do I need adapters or lockrings? And I have a bunch more questions. Thanks.
Quoted: 2026 Post(s)
Liked 1,096 Times
Looking at Fulcrum's web site it appears "AFS" is just their marketing name for their axle positioning system. These hubs take 12mm x100 front and 12mm x142 rear through axles and use a centerlock disc mount. Lockrings probably come with the hubs and use an external notch (bottom bracket tool for installation and removal. The rear hub could be used with adapters to use a standard 135mm QR skewer.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Liked 1,096 Times
Some disc rotors come with their own lockrings and Shimano's rotors use the same lockring tool as their cassettes. I don't know if the Fulcrum hubs use the same threads as Shimano hubs or if this type of lockring would work.
Quoted: 406 Post(s)
Liked 389 Times
The fulcrum lock rings are different. Shimano uses cassette locking while Fulcrum uses a larger locking.
I just bought Fulcrum racing 3 disc wheels and put Campy centerlock rotors on them. The wheels come with the lock rings. I used a Shimano standard wrench on the lock rings - Park BBT-9. I also have a very old Park BBT-19 cup type wrench with a 3/8" square drive that worked, but not perfectly. I later face sanded the cup type wrench on my vertical disc sander to give the teeth a better grip.
Eventually, owners of Campy or Fulcrum disc wheels will need a special plastic tool to hold the axle internally, while the left hand threaded lock nut on the end of the axle is removed. Without it, you can't remove a freehub body or service the bearings. The tool is a plastic hex wrench. Campy warns not to try an ordinary hex wrench or the thin walled aluminum axle may be damaged.
Quoted: 11 Post(s)
Liked 8 Times
Fulcrum axle size and dropout width
Look at the axle compatibility listing at the fulcrum website. The racing 4,5,6 list 142/135 axle compatibility, while the racingzero and racing 3 that I have only lists 142.
https://www.fulcrumwheels.com/en/whe...ls/racing-6-DB
