The Freak - Gazelle Friiik
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
Sometimes you come across a bucket list bike for such a cheap price you just have to make a trip halfway across the country to pick it up.
Technically maybe too young for the vintage part of the forum but a classic in its own right, the Gazelle Friiik (pronounced as "Freak") was introduced in 2011... and killed off in 2012.
That looks like some generic modern Dutch commuter bike... So why was I so curious about this one?
In one word; GSS, the Gazelle Shifting System. This bike has a fully sealed 7-speed derailleur system in a load bearing aluminum chaincase. Meaning a very efficient drivetrain with low wear. It also has a single sided rear fork, making it very easy to replace the tyre in case of a leak.
Courtesy of TestKees & Fietsersbond
The bike used to cost €849 back in 2012 (about €1000 now) which was about €100 more than a comparable bike using a Shimano Nexus 7. But reviewers loved it and told people to try it before buying the Shimano.
So why did it fail? Well, Gazelle blamed retailers for being too conservative but those in turn blame 4 changes in management in the two years while the Friiik was available. In the end it was forgotten about and never developed further.
From what I've read users really liked it but Gazelle being Gazelle they had a lot of proprietary parts in here. The big issue with these bikes is the bottom bracket. Once they wore out there were no spares available and the manufacturer either stopped making them or went bankrupt. They do use standard industrial sealed bearings but most bike shops don't have the tools and the skills to work on that.
My own example:
So I picked up mine for €75, knowing the bottom bracket was shot. It was pretty bad. When I rode the bike back from the seller to the trainstation I stopped to check whether my right crank arm was loose and about to fall off. It was the bearings.
What I did notice though is that it was indeed a very nice smooth ride that took very little effort to bring up to speed. And that's reasuring with the bike being close to 20kg (44 lbs). This could make for a very comfortable all-weather commuter if I can get it all working again.
As I picked it up from the seller:
From what I can tell quite a few parts need replacing:
I'm tempted to replace the rims with something a bit more sexy, like a black H plus Son Archetype and a Sturmey Archer XL-FDD dynohub in the front but let's focus on getting it working again first. With everything being metal I could even have the whole bike repainted in matching/contrasting colours. A Mondrian setup would be sweet!
But I digress.
It's a fun bit of history and I'm looking forward to digging into the technical bits and pieces. I needed something fun to get a bit more active with this hobby again.
And worst case scenario... I spent €75 on a dud.
My own example:
- Sprockets. Shifting felt a bit rough at times. Apparently it is a 7-speed system using 9-speed parts. I wonder if I could make it work using 11-speed parts? Maybe using friction?
- Twist shifter. It looks like a standard 7-speed Sunrace shifter with GGS labeling. A trigger shifter would probably be safer.
- Cables. Both brakes were sticky and hard to press. The kind of feeling you get with rusted cables.
But I digress.
Likes For JaccoW:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
History placeholder
2011 Ladies version
Front suspension version
Examples by other people:
- Emscherblues - Flickr. A pristine example
- WMZ Projecten. He has a bit of technical info and some inside shots.
- Internet Archive. The original 2011 product page on the Gazelle website. The first model came out in an all-white colour scheme.
- Velomobile Seminar (Dutch). A blog post with a bit of info on the downfall of this model and many users commenting with their experiences.
- About the patent (Dutch)
- Early GGS prototype (Dutch)
- Fietsersbond (Dutch). TestKees review of the bike.
Likes For JaccoW:
Quoted: 7359 Post(s)
Liked 2,502 Times
Wow! In some ways, it’s a very good idea. But they should not blame retailers. There is a risk that comes with leaving standards behind.
Am I correct that your model has two drum brakes? I guess this accounts for some of that 20 kg weight. Wow, that’s heavy.
Likes For noglider:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
And the 20Kg isn't extraordinary unfortunately. These bikes were loaded up with some heavy duty parts and luxuries so even a 2022 Gazelle Orange C7+ weighs 19 kg (42 lbs). Sometimes I wonder if they even know how to make light bikes.
Likes For JaccoW:
Quoted: 3464 Post(s)
Liked 2,834 Times
Single sided frame...
paint it Red and put Ducati graphics on it
Likes For repechage:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
Quoted: 2337 Post(s)
Liked 5,109 Times
OK, I'm saying it, that is on cool bike! I like the odd stuff and the challenge of getting it all going again. Can't wait to see more about this one.
Steel is real...and comfy.
Likes For beicster:
Liked 2,834 Times
Quoted: 1649 Post(s)
Liked 844 Times
I think single sided rear wheels on steel bicycles do not work as well as they do in motorcycles as they could not beef up the frame enough as they did on the motorcycles, to minimize the resulting twisting flex at the rear, caused by the moment forces coming from the cantilevered rear axle.
I guess on a townie bikeike this one it will not be an 8ssue but on a road race steel bike it certainly will. Monocoque carbon bikes like the famous one from Lotus are of course, an exception.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2211 Post(s)
Liked 4,669 Times
Note the spare goat on top:
Single sided hub = solution to a non-problem.
Quoted: 3817 Post(s)
Liked 6,750 Times
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
For the rear, especially with disc brakes, there is simply not enough room to put the cassette and disc on the same side. I'm willing to bet it's very possible to make the rear stiff enough but it's more a case of not enough real estate.
There have been fixed gear bikes that are one-sided however: English project right
Likes For JaccoW:
www.theheadbadge.com
Quoted: 2425 Post(s)
Liked 4,418 Times
I remember digging these up one day on an unrelated search for Gazelle-compatible chaincases. Delighted to see that one of these has made it's way to your mad scientist's lab, JaccoW.
Also looking forward to seeing how that BB gets serviced - given the corrosion over the whole thing, I can see where premature wear of a BB can become a normal thing over there. Does it have press-in cups, or is it simply press-in bearings, a-la Lambert/Viscount?
-Kurt
-Kurt
Likes For cudak888:
Liked 4,418 Times
Likes For cudak888:
Shifting is fun!
Bikes: Yes, please.
Liked 4,669 Times
It would have been a bit of a challenge for a hamster, methinks. I've been informed that the goat could get the 'bike' up to15kph, which actually makes it a useful thing. I rather like it, assuming the goats don't mind (or perhaps even enjoy) the trips.
Liked 4,418 Times
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
So I wanted to work on the bike during the day and actually use the sun that is still out here in min-November (hottest day ever, which is not a good thing)... but I ended up doing other things instead. Still, I managed to take a first look at the chaincase and open everything up.
First off, I took out 15 screws + 1 bolt, removed the rear wheel and took a look inside. Taking off the wheel turned out to be much easier than expected. All it took was a single 8mm hex and the whole thing just popped off.
When I went around and cracked open the chaincase I could see things were actually in pretty good shape! As far as I can tell there is hardly any wear on either the cassette or the plastic bits. The main issue is the method of shifting itself, but I'll get to that in a bit.
There does seem to be a lot of small custom bits but also a lot of modified Sunrace/Sturmey Archer parts. The shifting mechanism uses an extra-short indicator chain that threads into a spring-loaded gear selector assembly. Which in turn pulls the derailleur mechanism up and down a ramp. To my eye however it looks suspiciously like a regular 3-speed clutch spring!
It's honestly ingenious in its simplicity.
That indicator chain is a ***** to get right though (I haven't been able to get it back in yet) and since it is some custom short version I will probably have to make my own custom version at some point.
I do think however this mechanism is easily modified for use with a friction shifter (or trigger shifter) since the responsibility for the right cable pull is entirely up to the shifter, not the derailleur.
And if that works... maybe I could use 11-speed or even 12-speed parts to make a cassette with smaller steps. I don't think I'll be able to make big changes to the gear range due to size constraints but smaller steps between gears is always nice.
Removing the rear wheel
All the screws!
The chaincase with some bearings in there.
Gearing overview
Extra short indicator chain
First look at the bottom bracket assembly
All the screws!
Gearing overview
Likes For JaccoW:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
Likes For JaccoW:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
I'm just doing some napkin calculations on the gearing here.
Assuming what another owner said about spacing is correct (7 sprockets/speed using thinner 9-speed parts) you could theoretically use even narrower parts as long as they adhere to the Shimano HG standard.
So assuming:
Meaning, that you could fit 8 speeds using 11-speed parts for a total width of 38.98mm!
9-speeds would probably be too much at 44.32mm but could theoretically work if they did use 7-speed parts.
Something to ponder and measure!
EDIT: And then there's the SunRace MZ90 12-speed (MTB) and CSRZ800 WAV, WAT and WAW HG-compatible 12-speed models...
9-speed in 42.8mm anyone?
Source: Obike.de
So assuming:
- 7-speed uses 1.8mm thick sprockets spaced 5mm apart.
- 9-speed uses 1.78mm thick sprockets spaced 4.34mm apart.
- 7-speed uses 1.6mm thick sprockets spaced 3.74mm apart.
Source: Obike.de
Likes For JaccoW:
Quoted: 3825 Post(s)
Liked 3,377 Times
Liked 4,418 Times
Side note - you might want to consider your alternate gearing based on the ramp of the derailer chainguide. I wouldn't be surprised if it can accept a thinner cogset, but you may have issues if the guide runs higher or lower than the cogs themselves.
-Kurt
Likes For cudak888:
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
Jacco, try lying the bike on its side while ensuring the half-moon "derailer" is shifted into the large cog position. Then try inserting the indicator chain. This will let gravity guide the end of the indicator, and since it'll be in low, you'll have a shorter distance to get it into place, giving the indicator less opportunity to find the edges of the tube instead of the threaded hole in the center.
As for the gearing, with the limited space I don't expect to be able to vastly change the gearing anyway. Worst thing that can happen is the narrower chain causing issues while shifting. I've seen it happen with vintage front derailleurs and modern chains.
It will be an experiment.
Likes For JaccoW:
Ride, Wrench, Swap, Race
Quoted: 1566 Post(s)
Liked 1,300 Times
That cassette looks odd in terms of it's cog sizes.
Looking to my eye like 11-13-15-18-21-23-25t, so perhaps 25t is all that there is room for(?), unless that one bolt boss can be relieved enough to fit in a 26t.
Likes For dddd:
