Why are disc brakes so desirable?
Out
Bikes: two-wheelers
If you aren't riding through water four to six inches deep, are disc brakes even needed?
Don't they warp under heat?
Just curious.
Just curious.
Redheaded Stepchild
Bikes: A fat tire & a skinny tire & two others I loaned out
Same reason they're desirable in cars--they work better & are more consistent in wet/muddy conditions.
after installing front disk brakes on my 1 bike i would not want to go back. it seem to always work at a constant rate even if it is wet out. i have some bikes that barely stop when it is wet out till the pads seem to dry off.
I can really understand it in the case of warping a wheel, and I plan to upgrade because they do perform better, but in general I don't think they're needed. My V-brakes will lock up the front wheel just fine. They squeal a tiny bit for a few minutes sometimes when they get wet, but still stop well. I can definitely flip myself over the handlebars pretty easily if I want, so I don't see a huge need to go disk until it's convenient.
Like most innovations in the sport that takes hold, its because people see a value in it. There are always exceptions, but most people I know that give disk brakes a try tend to stick with them. I know people that still run V brakes and are happy, I was until I got a bike with disks, now I cant imagine my MTB bikes with out them. They are a big improvement all the way around. I am sure V-brakes will never go away, and thats cool if thats what you like. I have a friend who rides a steel, full rigid single speed, he sees no value in gears, disk brakes and front or rear suspension. He has his reasons and I am quite sure thats how he will roll till the day he stops riding.
I would say give them a try if you ever have the chance.
Cantilever Brakes
Single speed 32/18
Platform Pedals
700cc x 35 cyclocross tyres
I find v brakes to be trouble, I went stock on my bike and never looked back
If I was going to get a new bike I would go disk, but only higher quality then the cheap set you sometimes get.
Now with hydraulic brakes is the question at hand, why?
Redheaded Stepchild
Hydraulics = more for less (more brake for less effort). Don't know the full or even basic physics behind why they work the way they do, but it's a greater mechanical advantage than regular cable brakes. Take a bike with well-tuned BB7's & put it up against a bike with well-tuned Juicy 3's. Pull a brake lever on each bike with the same amount of force, & you'll get more braking power from the Juicy 3's. People like hydraulic brakes for the same reason they like power steering--it's easier.
Bikes: Mongoose
one less horse
No, at least not the amount of heat generated in a mtb application.
Try a search. The comparison of discs vs rim brakes has been beaten to death on this forum, especially 5+ years ago.
No they don't - not under the loads they see in a mountain bike application. Mechanical brakes lose efficiency in two main areas - friction and housing compression.
Bikes: 1989 Team Miyata, 1989 Miyata 1400, 1989 Miyata 1400, 1986 Miyata 610, 2007 Specialized Stumpjumper Hardtail
Quoted: 16 Post(s)
Before I got my Stumpjumper I felt like disc brakes were not very important. Now that I've used these ones (Avid Elixirs) I can't imagine going back to rim brakes. The difference is huge.
Below Par
Bikes: '13 Trek Stache 8; '08 Giant Rincon
Quoted: 9 Post(s)
This is the first time I've actually realized I hadn't ever thought about why hydraulics work better (when compared to cable disc). What do you mean by housing compression? I understand how friction is a now-obvious reason for considerable power loss. But when you think about it, it's all about leverage, which is easy to solve (considering frictionless, for the sake figuring out the remainig loss), so where does the remaining force disappear to? What 'gives' (bends), so to speak?
Still spinnin'.....
Bikes: Fisher Opie freeride/urban assault MTB, Redline Monocog 29er MTB, Serrota T-Max Commuter, Klein Rascal SS, Salsa Campion Road bike, Pake Rum Runner FG/SS Road bike, Cannondale Synapse Road bike, Santana Arriva Road Tandem, and others....
This reminds me of the debate over suspension forks and frames back when they where first introduced. Until you think about where and how you ride, and then try them where you ride, you won't really know what you need.
I have bikes with V-brakes and disks, and with front suspension and with solid forks, and with rear suspension and a hardtail. Each was built for a different purpose and each works well for what it was built for. So if you are commuting, trail riding, bombing down hill, or doing trials, you need to think first about how and where you ride.
BTW: I prefer the power of a hydraulic caliper but like the feedback of a cable caliper better for some uses. You just need to try each option to know what will work best (or acceptably) for your use.
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
That there are still people who adhere to this tired and totally debunked truism amazes me.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Redheaded Stepchild
Once you rationalize an irrational idea to yourself, you're the only one who can change your mind. No amount of outside reasoning will do any good.
Bikes: Yes
Quoted: 3235 Post(s)
Liked 3,882 Times
one less horse
When a control cable is placed under tension, the cable stops exert a compressive force on the cable housing. This phenomenon is frequently and incorrectly termed "cable stretch." With the proper housing, and after break in (get it?), it's not that big a deal.
The force doesn't really "disappear" - it's just that it is much less with mechanical systems as opposed to hydraulic. It's a lot easier to increase forces hydraulically than it is mechanically (see: backhoes) I suppose you could make a V brake lever that exerted similar leverage to a hydraulic system, but it'd be 8" long and it'd be too far from the bar for you to reach.
Hope this answers your question?
one less horse
when you are on the trail and bend or dent one or both your rims you will wish you had disk brakes. i know i have had to limp my bike off the trails with practically no brakes before because i have damages a rim.
Bikes: Secteur, Camber, Trek 930
As a recent switcher from cantilever (or whatever those notoriously difficult-to-adjust brakes are called) to disc, I love disc brakes so much better. I really had to clamp down with all fingers going down steep hills on the old brakes, now it takes just one finger on each hand. On long hills I even had to stop and give my hands a rest cuz they were cramping up. No more.
Te mortuo heres tibi sim?
Bikes: hardtail, squishy, fixed roadie, fixed crosser
