Super Record Bottom bracket mayhem! Help! Lol!
Old 06-25-19, 09:02 PM
Augie B
Quoted: 7 Post(s)
I am in the process of restoring a 1983 DeRosa super prestige. All the original parts are present and in good condition. The cranks and drivetrain are Campagnolo Super Record. As I began to “mock up”the bike but I noticed the inner ring was dragging on the chain stay. I also noticed that the bottom bracket cups appeared to be backwards? The side with a lock ring was on the drive side. I don’t have the correct tool to remove that cup so I removed the opposite side and took out the spindle. It measures 110mm and is marked 70 ssa . After doing some reading it seems that super record cranks should have a 115.5 mm spindle for Italian threads. Is this correct? Could it be because the bb is installed backwards that it is rubbing and the 110 mm is correct? It is symmetrical btw! And the crank is marked Strada 1 and is pantographed
Bb for these are very expensive, I don’t want to buy if unnecessary... if you are a campy expert .., HELP! Lol!
Augie B is offline
Old 06-26-19, 03:17 AM
P!N20
P!N20's Avatar
Quoted: 1079 Post(s)
Liked 1,898 Times in 931 Posts
I don’t think having the cups ‘reversed’ would make much difference. Sounds like you just need a 115mm spindle.
P!N20 is offline
Old 06-26-19, 03:39 AM
100bikes
Industry guy
Bikes: To many to name - I ride a custom built steel frame.
Quoted: 115 Post(s)
Liked 80 Times in 48 Posts
Was the BB retapped?
Was this bicycle imported from Europe, as opposed to sold in the US?
Was this a custom build or team bike?
Spec's can be different.
There is a "Swiss" named thread(35 x 1G- Same as the French gauche/left), where both sides are threaded with the same tap.
If the threads were damaged, this tapping arrangement may have been a solution.
Generally, BB threads are designed to allow the cups to tighten as you pedal forward.
Hence the need for the lockring on the adjustable cup.
I am not certain if the offset from the face of cup to bearing race is the same on both types of cups,
which would affect the amount of spindle protruding, I would suggest mounting it with the adjustable
cup on the non drive side. That way, if it loosened you could adjust without taking the crankarm off.
As to the spindle, make certain it is in the bb with the logo readable from the saddle- if you could see it.
Dimensions and tolerances are pretty tight, and there are many options available.
rusty
100bikes is offline
Old 06-26-19, 03:54 AM
Kuromori
Quoted: 237 Post(s)
Liked 83 Times in 64 Posts
It's a DeRosa, so Italian, especially considering the 70 marking, not Swiss.
Kuromori is offline
Likes For Kuromori:
Old 06-26-19, 06:49 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3587 Post(s)
Liked 3,400 Times in 1,934 Posts
A De Rosa is likely Italian thread (36mm x 24tpi), so it is possible to install the bottom bracket cups backwards without damaging anything.
Most 80s road bikes sold with "Super Record" components used a Nuovo Record bottom bracket. You can check for this with a magnet: a Nuovo Record bottom bracket has a steel spindle and is magnetic; a Super Record bottom bracket has a titanium spindle and is non-magnetic. Super Record bottom brackets use smaller balls than Record/Nuovo Record bottom brackets.
Campagnolo bottom brackets can be a hot mess. Campagnolo USA published an article explaining the various spindles and where they are used:
https://www.os2.dhs.org/~john/campy-BB-specs.pdf
JohnDThompson is offline
Old 06-26-19, 07:34 AM
Augie B
Quoted: 7 Post(s)
rusty
This bike was purchased from the original owner and was ordered by them ,from the Factory,in 1983. They had mentioned that they had to replace the original titanium spindle with a steel spindle because of excessive flex.
Apparently, DeRosa sent a hand written letter apologizing and explaining there was a problem with the campagnolo TI spindles!
There is rub on the chain stay from the inner ring, so I think this bb was always too small. I don’t know who reversed it, but it is definitely Italian threads! I think the bike sat most of its life or this would have come up sooner!
I think it was simply replaced with the wrong spindle and unfortunately I am going to have to buy a new one.
Now I am wondering if the bb that is in the bike will fit my “c record “Chorus groupset I have. If so maybe I can make use of it
Augie B is offline
Old 06-26-19, 09:07 AM
madpogue
Quoted: 2363 Post(s)
Liked 1,749 Times in 1,191 Posts
Was the _spindle_ reversed as well?
madpogue is offline
Old 06-26-19, 09:17 AM
CV-6
If I own it, I ride it
CV-6's Avatar
Quoted: 591 Post(s)
Liked 663 Times in 312 Posts
^^this
Considering it is 1983, the spindle being reversed is the most likely cause for the situation.
If it turns out you need a spindle, I believe I have a couple you could have pretty cheap. I only have one Italian and for some reason I have several Italian spindles.
Lynn Travers
Photos
CV-6 is offline
Old 06-26-19, 09:39 AM
Paletti
Bikes: 1985 DeRosa SLX, 1994 DeRosa Primato, 2009 DeRosa x-light, 1993 Paletti, 1983 Colnago aero cx, 1984 Colnago Mexico, 1983 Colner strato professional, 2016 Colnago V1-R
Quoted: 8 Post(s)
Liked 4 Times in 2 Posts
If I remember right the titanium spindles had some issues with breaking. I want to say Lauren Fignon was on the receiving end of a titanium failure during a sprint and crashed pretty hard.
Paletti is offline
Old 06-26-19, 10:27 AM
Augie B
Quoted: 7 Post(s)
I re-inserted it both ways and no difference. the spindle is not offset , it is symetrical. I'm pretty certain, thanks to everyones help, that it is simply the wrong part.
Augie B is offline
Old 06-26-19, 10:59 AM
Augie B
Quoted: 7 Post(s)
Thank you Lynn... I might take you up on that!
Augie B is offline
Old 06-26-19, 11:19 AM
snowball123
Quoted: 9 Post(s)
Liked 9 Times in 6 Posts
I recall when I worked on my De Rosa, the C Record inner ring also contacted the chainstay with a campy record cartridge bb installed. Believe the campy axle length was 109mm, so I went looking for a slightly longer axle bb to clear the stays. Ended up installing a Miche ITA cartridge bb, 111mm length and it cleared it by 1.5mm!
snowball123 is offline
Old 06-27-19, 05:34 PM
JohnDThompson
Old fart
Yeah, wrong spindle. 80s era Super Record used an asymmetrical spindle.
Old 06-27-19, 07:13 PM
mech986
mech986's Avatar
Quoted: 355 Post(s)
Liked 345 Times in 174 Posts
The later 70-SS spindle should work, 56mm between bearing shoulders, 28mm left side, 31.5mm right side, overall length 115.5mm. Use the later thick rifled cups. Should check whether needs 1/4" or 3/16" ball bearings.
The older 70-SS-120 +1, 1.5 should also work, similar dimensions.
Show us pics of what you currently have so we can see the threading, cup thickness, and bearings that are already in there. Can you measure the diameter of the bearings using a pair of digital calipers?
Italvega and Torpado Enthusiast
mech986 is offline
Last ride 76
Classic & Vintage
17
09-05-19 11:54 AM
Augie B
Classic & Vintage
9
06-26-19 01:33 AM
Narhay
Classic & Vintage
7
05-13-17 02:46 PM
b dub
Classic & Vintage
24
11-05-13 12:15 PM
sloar
Classic & Vintage
6
07-16-12 08:55 AM
