Pedals for Commuting In Rough Urban Conditions?
Quoted: 81 Post(s)
Liked 7 Times
Hi everybody,
What type of pedals do you use for commuting and errands by bike? Do you use cages, platform pedals, something else?
FYI: I just bought a set of Speedplay Syzrs to replace my worn out Speedplay Frogs (which were superb for commuting) and the Syzrs are not commuter-friendly (or safe) as far as I can see for a city environment. E.g., I can't unclip without my bike falling over with me attached when car doors pop open in front of me, pedestrians looking at smartphones stumble off of the sidewalk, rollerbladers come at me the wrong way down a bike lane, a car right hooks me without signaling, etc.
Bikes: 2008 Trek Police bike 2019 Jamis Coda Sport 2021 Surly Bridgeclub
Quoted: 76 Post(s)
Liked 924 Times
I'm sure you will get a lot of responses but I have Race Face Chesters on both of my bikes and I'm very pleased with them
Quoted: 1062 Post(s)
Liked 665 Times
I know they're cheap, but I got a pair to restore an old beater, liked them so much, that I now have them on 4 bikes: The cheap plastic Avenir "resin" pedals. Warning, they're so cheap, you can get them in 1/2 or 9/16 size, so make sure you get the right ones.
They're just nubbly enough that my feet stay on them in rain, shine, or snow.
On my bike I use for in the city I use dual sided SPD pedals, where one side is flat. This gives me the choice to use shoes with SPD cleats or just regular shoes.
Likes For mr_pedro:
Quoted: 2952 Post(s)
Liked 3,106 Times
I have pedals with spd on one side and platforms on the other (ISSI Flip). Good for days when I don’t feel like changing shoes. I don’t understand the comment about your pedals don’t allow you to disengage without falling in traffic. How do you normally disengage? Lean against a tree? Are they too tight?
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I use Shimano GR 500 in the summer and a really old set of XT clipless in the Winter
Quoted: 1364 Post(s)
Liked 1,678 Times
Platform pedals with toe clips. This allows me to wear any shoes including light-up led shoes for riding home in the dark in the winter.
Liked 665 Times
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 672 Post(s)
Liked 417 Times
At the risk of asking the obvious, but are your pedals and cleats properly set up and lubricated? That system is set up for cyclocross, and there are lots of folks clipping in and clipping out in a hurry under race conditions, and running up and down stairs, over barricades, and up hills while wearing them.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Likes For bbbean:
Quoted: 81 Post(s)
Liked 7 Times
The cleats are brand new out of the box as are the pedals. My assumption is they won't need lubrication until I hit 150 miles.
Quoted: 81 Post(s)
Liked 7 Times
1. When I was using my old set of Frogs, I would disengage right before the bike came to a complete stop. My feet would just slip out, which was easy and safe. I wiped out with my feet in the pedals maybe 3 times in 8 years.
2. With the Syzrs pedals, it's a big effort to disengage and takes planning as I ride. E.g., I have to be careful going up hills and stop ahead of time if I see pedestrians anywhere near the side of the road.
3. I've backed out the tension screws pretty far, which helped reduce the effort. However 3 of the 4 screws fell out on the road.
4. I noticed that even when the screws were backed way out, sometimes my feet would stick in the pedals. It would still take a ton of force to get out of the pedals. That isn't safe when I need to stop right away without biting the pavement.
5. The Frogs would let me gently and easily shake out of the pedals. It was a smooth gentle motion. With the Syzrs pedals, there is a big snapping movement. The vibration from the snap destabilizes the bike at low speeds and could cause someone to tip over unless they are super careful (and lucky in the urban riding context).
Quoted: 672 Post(s)
Liked 417 Times
Might want to RTFM before you dump the pedals:
https://www.speedplay.com/pubs/instru..._15_15_Web.pdf
Likes For bbbean:
Bikes: An old Panasonic Sport
Quoted: 10 Post(s)
Liked 28 Times
Been using these to commute daily for about 1,000 miles so far and they’ve been great. Great grip even when it’s wet and no clips when you need to put your foot down in an instant.
Zacro Mountain Bike Pedals - Aluminum Antiskid Durable Bicycle Cycling Pedals Ultra Strong Colorful CNC Machined 3 Bearing Anodizing Bicycle Pedals for BMX/MTB Road Bicycle 9/16" https://www.amazon.com/dp/B07ZFQQDRS...ing=UTF8&psc=1
Quoted: 2338 Post(s)
Liked 2,827 Times
for commuting SPD hands down. Depending on the bike either double side spd (one my nice road bike when I commute on it...put SL on for the weekend rides) or SPD one side and platform on the other...which is IMHO the most versatile commuting setup.
I had speed plays for a while....hated them.....
Quoted: 81 Post(s)
Liked 7 Times
for commuting SPD hands down. Depending on the bike either double side spd (one my nice road bike when I commute on it...put SL on for the weekend rides) or SPD one side and platform on the other...which is IMHO the most versatile commuting setup. I had speed plays for a while....hated them.....
Liked 2,827 Times
Flat pedals and Crocs. The only way to go.
Quoted: 2604 Post(s)
Liked 1,933 Times
Out of curiosity, how did you wear the Frogs out? I've been rebuilding Frog pedals for years. You can find the bearings at a supply house, replacement O-rings at a hardware store, and RTV at your local auto parts store.
Or are the cleats worn out, and you used up your stockpile?
Quoted: 626 Post(s)
Liked 701 Times
My velo has 3 wheels, so I am always clipped in.
Quoted: 7349 Post(s)
Liked 2,474 Times
I like SPDs for all kinds of riding. I'm quick at getting in and out. I wear shoes with recessed cleats so walking in them is fine if a little clinky.
Quoted: 768 Post(s)
Liked 1,744 Times
I use Time ATAC pedals on all my bikes. Love, love, love them.
My preferred commuting pedals/cleats are spd-sl.
I treated myself to some boots this winter, shimano mw-701, which use recessed spd mtb cleats.
They are bulky compared to my road shoes, so, because I had to get new pedals anyway, I got a set of wide double sided spd pedals, pd-me700, cleat engagement both sides.
I can ride them just fine but clipping in/out is not 2nd nature yet, as in I have to actively think about it.
But they are easy to ride away from lights, to stop easily, even if not completely clipped in as the pedal is wide and gives plenty of support. Also nice to walk in off the bike.
So I'll give it some time to get use to, as I rode spd-sl's exclusively for years so it wouldn't be fair.
They are boat anchors compared to my spd-sl's
I tried SPDs on-and-off for years. They always presented problems for me. I was born with a severe hip torsion, which was corrected incrementally every night over a period of years in childhood. The end result is that, especially on my right side, I don't always have the range to kick my heel outward to unclip.
Though I don't cycle to work these days, I use the same MKS GR-9 pedals with clips and straps that I've been using for 16 years. On another bike, I use MKS Lambda Grip Kings, which have been very nice and super grippy.
On the city bike I used when I lived in Sweden, I bought a super cheap set of Wellgo aluminum BMX platforms that didn't have replaceable sharp pins. I liked them enough that I put another set on a MTB I keep at my family's house in the USA for casual rides during visits.
The advantage of the pins is that they're super grippy, even when wet. The disadvantage is that they can gore the backside of your leg, especially that weird skin on the back of the knee, if one isn't careful...
I love these, but my commute is 5 miles round trip.
Pedal reflectors are really noticeable and the way people drive around here, every bit helps.
https://cdn.shopify.com/s/files/1/14...g?v=1471031729
[the link is glommed from rivbike.com but they are out of stock]
