10-speed Campy Cassette installation
Bikes: 2015 Felt Z75 Disc, 2008 Fuji Cross Comp, 2010 Trek Navigator 1.0, 1974 Raleigh Sports, 1974 Schwinn Le Tour, 1981 Schwinn Super Le Tour, Surly Cross Check, 2021 Giant Talon 2
Quoted: 202 Post(s)
Liked 71 Times
Hello. I'm installing a 10-speed Campy cassette on a Miche hub. It appears to be on correctly as the spacing between sprockets looks good, but the final sprocket doesn't fit as deep on the freehub body as I was expecting. It is in the notches, but not completely in them. Is that normal? I would have expected them to be more flush. Here is an image:
check out the Frugal Average Bicyclist
Frugal Average Bicyclist – The goal here is to help you keep cycling on a budget.
Quoted: 65 Post(s)
Liked 107 Times
That looks pretty decent to me. As long as your lock ring is snug and you have no play in the cassette, you’ve installed the system correctly.
If anything, typically the lost cog will barely sit on the free hub splines. Once you get the lock ring on, that’s when the cogs compress appropriately along the free hub body.
Quoted: 5793 Post(s)
Liked 2,584 Times
Yes, it's normal and absolutely HAS to be this way. Having the cassette overhang slightly allows the lockring compress the cassette instead of bottoming against the freehub.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 202 Post(s)
Liked 71 Times
Thank you for the replies! Glad it's right.
Quoted: 241 Post(s)
Liked 232 Times
Like the others have said that looks correct. I will add that you must have the lock ring torqued properly. If it is too loose you will have some very strange shifting issues - it will work fine one direction but not the other, later it will work right the other direction but not the original direction. If the lockring is too tight you can pull the threads out of the freehub or split the freehub. This is more of a problem if you have the steel lockring.
