Strange frame alignment problem
Hi,
I have strange alignment problem with my old Nishiki road bike. I have done cold setting for the frame to 130 mm spacing. After that I aligned the dropouts.
The rear wheel is true and centered, but when I put it on the bike it sits closer to left side chainstay. Offset is approx. 3 mm. The clearance gets a bit too small with 28 mm tyre.
Strange part is that there is nothing wrong with the frame alignment. I checked it first with the string method and then again with DIY alignment tool.
Both times the result was same: the rear triangle alignment is OK.
I also measured lengths of the chainstays and those were same. There is no visible damage on the frame.
I could move the rim 1.5 mm to right to "fix" the problem, but I would like to hear first if there is anything else I could try.
Edit: The rear axle was to blame after all.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
You could try a different wheel, confirm that it's not the frame.
Likes For mitchmellow62:
Quoted: 455 Post(s)
Liked 112 Times
When you measure the CS are you measuring to the dropout? Horizontal vertical DO?
Troubleshooting an Off-Centered Rear Wheel on a Road Bike: Possible Causes and Soluti
It sounds like you have already done a thorough job checking the frame alignment and dropouts, which rules out some common causes of this issue. Here are a few other things you can check:
If none of these checks reveal the cause of the problem, moving the rim slightly to the right may be your best option. Just make sure that the wheel is still properly dished and that the tire has enough clearance.
- Check the dish of the wheel: Make sure that the wheel is properly dished, meaning that the rim is centered between the hub locknuts. If the wheel is not properly dished, it can cause it to sit off-center in the frame.
- Check the axle spacers: Make sure that the spacers on the axle are symmetrical and that the wheel is centered between them. If one spacer is thicker than the other, it can cause the wheel to sit off-center.
- Check the derailleur hanger alignment: If the derailleur hanger is bent or misaligned, it can cause the derailleur to pull the wheel off-center.
- Check the frame alignment in relation to the seat tube: Even though the rear triangle may be aligned, the seat tube can still be off-center. This can cause the wheel to sit off-center in the frame.
- Check the dropout alignment again: It's possible that the dropouts were not perfectly aligned when you checked them the first time. You may want to double-check them using a different method or tool.
Quoted: 4412 Post(s)
Liked 1,566 Times
Spacers are dish, dish is spacers. Either the wheel is dished or it is not.
Did you observe that the frame was actually aligned before you spread it? Presumable that was with a different wheel, and that wheel might not have had perfect dish, making up for dropouts that may not have been perfect.
If the frame is straight and the dropouts aligned, the thing to do to align a dished wheel is to remove a tiny bit of dropout material with a round file. Less than half a millimeter total would shift the wheel 3mm.
Quoted: 1143 Post(s)
Liked 1,753 Times
Check the seatube alignment to the bb driveside, then downtube to the same bb face, then the headtube to the seatube. The string test only tells you something is out it won't be accurate for the rear needs unless the front is in check.
Likes For Mr. 66:
Quoted: 883 Post(s)
Liked 824 Times
Quite the dilemma since the offset is the same with the "perfectly dished" wheel installed either way. I would guess (even though you checked) that the dropouts were "moved" relative to each other when you spread the frame.
Quoted: 6196 Post(s)
Liked 4,811 Times
Sounds like the wheel isn't dished correctly if the dropout spacing was done correctly and the slots are lined up correctly. Or you just got a spacer on the wrong side of the hub.
Expired Member
Liked 5,441 Times
It seems to me that if you get the same amount of offset from midline in the same direction when the wheel is flipped, the wheel is not the culprit. That would leave frame and dropout alignment. Sometimes fresh eyes will see the problem when I don't. A competent friend or professional mechanic?
Quoted: 6972 Post(s)
Liked 10,971 Times
Expired Member
Liked 5,441 Times
I'm hoping they'll institute a rapid sanction before this kind of stuff takes root.
Quoted: 4210 Post(s)
Liked 3,878 Times
Almost. The suggestion that the der hanger can cause a wheel to shift is not the best way of saying if the dropouts are not parallel to each other AND also not parallel to the centerline off the bike (this part is rarely mentioned) that the wheel can shift on tightening. Technically the hanger is not the axle slot.
I've seen many bikes that when the wheel is tightened in place it wants to "walk" or move slightly within the drop out. I have found this to be far more likely with axle nutted wheels (the axle sometimes wants to turn with the nut allowing that "walking" to happen).
Having read this thread I would want to see the bike and wheel before making any claims of what's wrong. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Expired Member
Liked 5,441 Times
^^^^To clarify, I wasn't endorsing any of this, just pointing out it was AI generated mush. As for the OP, he's certain it's not the frame and certain it's not the wheel. I agree it's strange.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
if they learn to defend their power sources, we are in big trouble...... see: Star Trek: The ultimate computer
Liked 739 Times
is the frame in question Steel or Aluminum?
i just reset a Tange Champion steel frame and that sucker is tough to move..
If your frame is steel. you may have bent OTHER tubes and twisted the frame as you reset it.
that twist may have left the seat tube "centered" in the middle, but out of true at the top and bottom......... a definite possibility.
Likes For maddog34:
Liked 3,878 Times
Kerri R- Don't know where you are but you can see my city. if you're close I can help you figure this out. Andy
AndrewRStewart
AndrewRStewart
Half way there
Quoted: 987 Post(s)
Liked 880 Times
Are you absolutely sure the wheel OLD matches your 130mm frame spacing? If the OLD is less than 130 (say 126 mm) the stays would be pulled in when the wheel was secured, but not maybe not equally. Given that the dropouts and frame are aligned well, the wheel is true and properly dished, and the stay lengths are equal, I can think of no other reason for your issue.
