Rim brake pads
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
Rim brake pads
For us old school people still riding the rim brakes, is there a particular type of pad you prefer? I have an older Cannondale, mid level Shimano group set and the brake pads I think are original. They are not worn out but I get this grating kind of noise when I brake. It's as if there's sand or debris on the rim or pad but there's not. Rims are only a few years old and don't show signs of ware (I only ride this bike once/week at most?).
Thought maybe a decent set of pads might correct this sound.
UPDATE: sorry, i have Shimao R500 aluminum rims and this is on a road/race bike
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Before I changed to carbon rims, I always used Kool-Stop pads. They work great on aluminum rims in all conditions.
With carbon rims, I use SwissStop pads. They stop better than the Reynolds OEM pads.
Likes For terrymorse:
Quoted: 8285 Post(s)
Liked 9,055 Times
I have Ultegra brakes on one bike and Mavic on the other. I use Shimano "Dura Ace" pads on both and they work fine. I rarely ride in the rain.
Shimano Dura-Ace R55C4 Rim Brake Pads | REI Co-op
Quoted: 1401 Post(s)
Liked 1,886 Times
if you pull the original pads and inspect closely - there might be small bits of metal / grit - whatever embedded in the pad
the pads are also probably hard (if they are old)
Quoted: 2604 Post(s)
Liked 1,933 Times
Kool Stop salmon works on all my rim brakes. May take a bit of searching to find them in the right configuration, but it's worth the time.
Likes For pdlamb:
Quoted: 548 Post(s)
Liked 473 Times
I do have Kool Stops on my vintage steel bikes but didn't know people also use them on newer bikes. Good to know, thanks.
I have also removed the pads several times, wiped them off, took some sand paper to them to remove the hard surface and even brought them into my LBS and they said, all looked good (maybe the advice didn't come from the best source as I find like most retail stores, they hire teenagers that might not be the most knowledgeable)
Likes For gthomson:
just another gosling
Quoted: 3889 Post(s)
Liked 1,939 Times
I like the blue BXP SwissStop pads. Yes, grit can get embedded in pads. Sanding them works if it's not too bad.
Results matter
Results matter
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
+1 for Kool Stop.
Likes For arex:
Quoted: 4560 Post(s)
Liked 2,802 Times
Kool-Stops on a couple of bikes, Jagwire on one or two others, Shimano basic road bike pads on another. As long as the pads are fresh they're all good. The only pads I've had trouble with were hardened from age, sun, ozone, etc.
The main issue is alignment and adjustment. Keep the rims clean. Occasionally use a fine to medium file or nail file to deglaze the pads (no sandpaper, emery board, etc, since the abrasive can be embedded in the pads). Deglazing pads can extend the life and usage. If you watched behind the scenes footage of pro cycling mechanics in the rim brake era they'd often deglaze the pads, especially before and after mountain stages.
On my early 1990s Univega hybrid with cantilever brakes, I use Kool-Stop Eagle Claw 2 (mix of salmon and black material) on the rear rim, Jagwire thinline long boys on the front (black only). The Eagle Claws are a terrific design for old school canti brakes *if* they fit. The plow shaped end makes the pad self-aligning and scrapes mud and debris off the rim. But when I moved up from 700x32 to 700x38 or wider tires there wasn't enough room to drop the front wheel without deflating the tire/tube. The Jagwire thinlines clear the tighter space between the fork and larger tires, and the pads are longer than usual, and curved to follow the rim shape, so they're very effective stoppers. The black material works as well as the salmon/black on the rear.
I think my 2010-ish era Diamondback Podium has Kool-Stop shoes with replaceable pads. I'm not sure there's much advantage over the one-piece shoe/pads, but the bike came with 'em so I use 'em.
Likes For canklecat:
Having used lots of pads, I have no preference, they all work well if properly installed and set up. On occasion, when I am doing a thorough bike cleaning, I'll remove the wheels and then dress the pads with coarse emery cloth which removes glazing and debris. I will also wipe down the brake surface of the rim with a rag wetted with acetone. I do this maybe twice per year, it makes a big difference in brake performance.
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
+1 for Kool Stops.
I’ve also had good luck with Jagwire.
I agree with a previous post, though. You might have some debris embedded in the pads you have now.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times
I've used three styles of Kool Stop pads - black Campy replacements, curved V-brake with scraper ends in both black/salmon dual compound and all salmon (best), and their triple-compound CX Cross pads on tubular wheels for their narrow track. All work well.
I can report that 45-year old Galli pads can be scary.
Likes For Fredo76:
Quoted: 18378 Post(s)
Liked 4,512 Times
I have Shimano Ultegra brakes on a couple of bikes, and they stop very well. I don't know if it is the pads, but I'm pleased enough with the brakes to use the Shimano pads.
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
The scariest experience I had on the Bianchi was on a moderate descent with new Shimano pads in Campag. sidepull calipers. KoolStop pads gave me noticeably better braking, but KoolStops with dual-pivot sidepulls gave me full braking confidence.
I use those quick-insert type ones that you just slide in and secure with a small cotter-pin. Mostly I use house-brand ones from MEC (Canada equivalent to REI).
I would suggest if you have ANY concerns about grit, change the pads - they're (fairly) cheap and your rims come first.
Lance Legweak
The rubber pads sound like they are old and hardened, which will cause the sound. Rubber pads should probably be changed yearly when you get a tune-up. I just use whatever the shop recommends.
Quoted: 548 Post(s)
Liked 473 Times
So I looked online and found the Kool stops which I have on my 2 vintage steel bikes but thought I would pay a visit to the LBS and try and support them. Good sign you're riding a trend on the way out when you can't find the parts. First store only had Shimano and Jagwire and no price which I hate having to ask for a price on something when they should simply be able to mark this on or near the product. Tried a 2nd bike shop that had nothing for rim brakes. Guy went back into his service area and found 2 service brake pads among the parts.
Might want to stock up on your favourite brand before they are no longer available!
feros ferio
Liked 1,329 Times
Likes For John E:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4393 Post(s)
Liked 3,016 Times
Koolstop.
And rim brakes work better and with less noise when you toe-in
Likes For MinnMan:
