Mounting & removed tires too much?
Curmudgeon
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times
Does frequently mounting and removing tires “stretch” them or otherwise damage them?
for my gravel bike I have one set of rims and two sets of tires, one with a much more aggressive tread pattern, that I choose depending on terrain I’m riding.
Does the repeated mounting and dismounting harm the tires? Will they stretch and no longer seat to the wheel?
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
I've never experienced that, but am also interested in what others have to say. It may depend on your method. Do you need tools, or can you do with bare hands? Some installers are easier on tires than others.
Likes For andrewclaus:
Likes For choddo:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I would say that an inept mounting and dismounting of the tires might stretch them. Procedures executing out with skills barely challenge the tires, certainly less than regular riding.
Likes For 2_i:
Quoted: 3515 Post(s)
Liked 2,929 Times
Why not just get a second set of wheels? That's got to be infinitely easier than mounting and dismounting tires and tubes time and again.
Likes For smd4:
Curmudgeon
Quoted: 157 Post(s)
Liked 32 Times
I use a standard tire lever to initially get the bead over the rim, then remove by hand. I can always get them on by hand.
Likes For rbrides:
Curmudgeon
Quoted: 157 Post(s)
Liked 32 Times
Yes, a second set of wheels would be best. I should add that, the tire change-over happens 3 or 4 times a year. So not REAL frequent. But, are tires manufactured with the expectation of mounting only 1 or 2 times ever? Would two or three years of 3-4 times a year be detrimental to the tire?
Quoted: 6975 Post(s)
Liked 10,975 Times
So, I do suspect that some tires might stretch out a bit, and I would also suspect that regular mounting and unmounting would accelerate that process. With that said, I also suspect that any problems would manifest when mounting; i.e., if you can get the tire to pop onto a rim, and it holds air, it probably won't blow off the rim while riding as long as you're using reasonable psi.
PS: buy a second wheelset and stop blowing your time with tire swaps. You'll not regret it.
Likes For Koyote:
Liked 2,929 Times
My tires use a Kevlar bead, which I understand doesn't stretch. So I don't worry about it too much.
Likes For smd4:
Quoted: 506 Post(s)
Liked 639 Times
I would expand on this to say I wouldn't worry about it AT ALL. Unless the only stress on the tires is mounting and dismounting, they should wear out well before any actual damage manifests. In order for mounting/dismounting to damage tires, you would have to be breaking the fibers in the bead, and this is highly unlikely.
Quoted: 2604 Post(s)
Liked 1,934 Times
Depends on the rim. It's not too difficult with a tight tire/rim combination to start mucking the bead up as you're sliding a tire iron around a not-quite-loose-enough bead. Repeat near the same spot half a dozen times, and bead damage is possible.
I've got a tire on a spare rim I've used for a few years to proof tube patches, and it's got a couple threads that have come loose from that kind of treatment. Not enough to care for that use, but I'd be antsy to be riding on that tire.
Likes For pdlamb:
Quoted: 94 Post(s)
Liked 151 Times
For the vast majority of tire and wheel combinations that use tubes there should be no problem with tires stretching due to multiple tire swaps. The only issue might be on some where the tire is extremely tight and difficult to remove and replace. The tire bead should be inspected closely each time it is removed to insure it is sound.
Likes For ARider2:
Quoted: 1563 Post(s)
Liked 1,737 Times
If it's a tubeless tire then I would definitely leave it on there until it wears out. Tubeless tires are not good for frequent mounting and dismounting unless you enjoy pulling dried sealant goop off the tire bead every time.
If it's not tubeless then you should definitely switch to tubeless.
Likes For icemilkcoffee:
Quoted: 1613 Post(s)
Liked 2,598 Times
All's I know is that tires that have been inflated and used for a while are definitely easier to remount.
Likes For curbtender:
Are you denting your rim? I can't imagine how one can deform the steel or Kevlar beads on the tire without damaging the rims. Or are you taking chunks out of the casing?
Quoted: 6199 Post(s)
Liked 4,816 Times
I've always felt that simply inflating them and using them makes them easier to get on and off. Not sure if the bead actually stretches. Might likely be more that everything just slides into place better as the old rubber isn't as grippy on the rim as you take it off or put it on.
Likes For Iride01:
Quoted: 5793 Post(s)
Liked 2,594 Times
Short answer is NO, it does not stretch or otherwise damage tires.
Longer answer is that it depends on HOW you mount tires. Poor mounting technique, and/or with very tight tires, each mount and dismount risks abrasion or other damage to the tire plies down near the bead. So, you need to be mindful of the potential damage and factor that into your decisions.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 1088 Post(s)
Liked 1,028 Times
Likes For Russ Roth:
Liked 2,594 Times
In any case, this has nothing to do with the OP's question, because tire bead material doesn't lose its stretch like underwear waistbands. Mount them as often as you want, as long as you don't fray the tire cords where they wrap under the beads.
Likes For FBinNY:
Quoted: 504 Post(s)
Liked 437 Times
Quoted: 981 Post(s)
Liked 584 Times
This is the tool. It's pretty compact.
Instructions for use...
Liked 2,598 Times
If it is plastic, at some point it will break.
Likes For sweeks:
I can't recall where I recently read this, but they did experiments, based on statistics of people with a flat when going fast, large number (like 50%) digressing rapidly to the tire flopping, locking up the wheel and causing a serious accident. They found that a tight fit of tire on rim, prevents this (and I think this is both a factor of match between the tire and rim bead diameters, but also how deep the tire, when not inflated, can sink into the rim; quite a bit with my cheap single wall rims, would be less with double wall rims with only a "drop center" like on car wheels, which is probably why car wheels are designed that way! They experimented by building up with tape the inside rim diameter.) Makes complete sense. So easy on and off may be bad, but also the rim design may matter. I don't know if frequent changes will cause loosening, or just an original size issue. Be aware of ease on and off, and watch for if it gets easier. And look at whether the inside of your rims is deep due to single wall, or shallow due to double wall or at least higher near the sides.
Also critical is whether you shave rubber off the bead area each time you swap tires.
Likes For Duragrouch:
