Rethinking SRAM Dual Drive
#76
you conveniently avoid the issue by ad hominem. the issue is why attempt an unnecessary hack when the thing is already solid? your veiled vitriol does not replace reasoning or answering the question. i listened to you, to your post. i am sorry if i asked a thorny question for which, evidently, you have no answer by the looks of your response. the plain fact is that i have a bit of experience with SDD. i even own one, and have used it extensively, unlike you. good luck with that hack...
Well, the peopel discussing this mod has got much more experience between them than what you describe. Also they have the ability to calmly discuss theyr experience between them and also to listen to eachothers opinions without anger and lack of respect. Amazing, is`nt it? Something worth trying!
#77
Quoted: 113 Post(s)
Liked 8 Times
not impressed. I set it up with a SA twist grip i had laying around for the IGH instead just to see if it would shift properly as they say. I`ll order a different SA shifter for the left side later.
If i buy another one for my white folder I`ll go with Sturmey Archer to get the pull chain instead of the clickbox you find on the Shram systems. I have been reading a lot recently and I find peopel using Shram discussing if you can remove the pin and click box and use a pull chain instead. My Sachs has got the chain and I like that.
#78
Quoted: 317 Post(s)
That is a huge difference for sure! I think maybe I would do what you did, just use the clickbox. I found the discussion about converting to chain when I searched for info on shifters. I found Aron saying all the Shram 3 speed IGH shifters was interchangable but still not sure if the Sachs/Shram 3 speed shifters are, that is why I am thinking of buying a SA shifter. I know from experience (and from the info on the IN) that you can use SA 3 speed IGH shifters with Sachs hubs but not Sachs 3 speed IGH shifters on SA hubs.
I think the guys discussing the clickbox conversion wanted to get rid of the clunky clickbox and get a more "old scool" look, some of them are close to Sheldons level so "they just have to find out if it is possible..."
I think what I did with the Surly brake hanger and the cable splitter I copyed from a picture you posted of a
Moulton you have set up this way so that invention may be yours!
#79
Quoted: 113 Post(s)
Liked 8 Times
#80
My plan to convert a DD to chain pull was going to be to cut the DD long rod, flatten and drill the end, and attach the chain.. lot of other projects ahead of that though.. I use a SA bar end shifter for the Sram IGH.. no issues.. the SRAM/Sachs 3 speed shifters will work with SRAM/Sachs hubs, but they shift in reverse of each other .. Sachs defaults to high gear when relaxed, SRAM to low gear..
SRAM also sold the older style 3x7 hub (Sachs) and branded it as SRAM Spectro 3x7. They have a different housing but are almost identical inside expect the clutch which had 6 claws in the older Sachs model and then 4 claws in the newer SRAM models.
But agreed the SRAM dual drive is completely different from the SRAM/SACHS 3x7. They are not compatible.
One more thing: The chains for the 3x7 are no longer available. I even can no longer find them in Germany. One can still buy the chain for the 3 speed where the pin is too short for the 3x7 or the chain for the 5 speed (left side) where the pin is too long. I need to try if I can use a 2mm die to extend the thread on the longer pin and then cut it to the correct length.
#81
Quoted: 113 Post(s)
Liked 8 Times
Not sure what you mean there, but I'm pretty sure we're on the same page
Let me know what length pin you need.. I have a reasonable collection in the drawer.. maybe I can mail you what you need..
#82
Quoted: 317 Post(s)
Slight correction: SRAM not equals SRAM.
About the chains (chain/rod combo) not being available: If you have the pin its self it should be possible to atatch a new chain to it, I did this some time back after buying my B with the old scool two chain 5 speed hub. It did not take me long to crush the chain on the left side and I managed to repair it. Removed the crushed chain carefully and just used a chain from a different pin/chain combo. I actually think I used one from an old Sachs 5 speed hub as that was what I had at the time. I used a small brass coloured nail as a rivet, cut it to lenght and carefully hammering it to hold the chain. I remember taking a amall nail or two as a spare on longer rides but never had to repair it. Also with this kind of drivetrain (as with the B SA two chain hub) all is not lost if half of the system can not be changed. You always have at least three gears
#83
>I eventually learned that I could use a Sturmey Archer 3 speed bar end shifter on the Dual Drive
Aha! Thank You!
Aha! Thank You!
#84
Quoted: 3453 Post(s)
Liked 1,453 Times
https://www.bikeforums.net/folding-b...ding-bike.html
Photo of my folder with a Sturmey Archer shifter on left and the Shimano rear derailleur shifter on the right back in 2018 below.
Likes For Tourist in MSN:
#85
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
Sturmey Archer 3x9hubs going for ~$90.
With ~$25 for a rim and ~$20 for spokes, that makes it competitive with a FD for cost & weight
(1090gm vs ~200 gm per chainwheel+ FD ~100gm + rear hub ~300gm, so what? 400 gm heavier?)
The wide gear spacing on my 6 and 9 speed foldies needs something and I really like the SDD on my Bike friday
Clearly not weight weenie racer, but for touring city bike, not a bad move.
#87
iti biking
Has anyone found a source for the 28 hole Sturmey Archer dual drive hubs, either the CS-RF3 or the CS-RK3? All I can track down are 32 or 36 hole versions, and I’ll quite like to be a cheapskate and reuse my existing rim.
#88
Quoted: 350 Post(s)
Liked 122 Times
I could only find this site with 28 holes, but it's pretty expensive.
https://foldingbike.biz/Dahon/Tern-N...ar-Unit-28Hole
You might as well contact a shop closer to your location, and ask them if they can order it. I see other places with 32 or 36 holes for around $100.
#89
iti biking
Other suppliers in Europe say that the regional importer doesn’t ship in the 28h model which partially explains why it hasn’t turned up other than a Tern branded version at a Tern and Dahon parts specialist in that corner of the world. Hmmmm. The extra £35 to reuse the existing 28h rim is probably better spent on a new 36h one and getting a stronger wheel into the bargain.
#90
Protecting the SRAM DualDrive Clickbox
But that clickbox looks vulnerable. So I fitted a derailleur protector. It worked. Then, I replaced it with a titanium version. Weight went from 80 to 32 grams.
Titanium derailleur hanger from EBay.
Just the right amount sticking out!
Barely clears for removing clickbox.
#91
Quoted: 172 Post(s)
Liked 95 Times
The guys here that have them guard them jealously
#92
Liked 1,453 Times
I considered trying to make a guard for my click box like the one shown above, but never got around to it. I have not toured on my folder, but I thought that if I put a rack and panniers on the back for touring that the pannier might not play well with the click box, thus I thought I might need a guard for the click box in that scenario.
#93
I have the Sram dual drive with a 9 speed derailleur on my Moulton TSR27 and wish I had had this when I was touring as it give me a huge gear range and the ability to change gear while stopped. I really can't fault this set-up and mated with the Moulton's suspension and comfort it's a dream.
#94
Bikes: Airnimal Chameleon; Ellis Briggs; Moulton TSR27 Moulton Esprit
Quoted: 3291 Post(s)
Liked 827 Times
Damned if I can remember as I've had to give up all my bikes for health reasons and it was some time ago.....probably something by Schwalbe though.
"Reading maketh a full man; conference a ready man; and writing an exact man". Francis Bacon
