Gravel/cross bike recommendations for short rider
Bikes: Specialized Ruby, Norco Search, Specialized Ruze, Norco VFR
Quoted: 12 Post(s)
I'm short (5'2) with short legs (720cm inseam) and I'm really struggling to find a gravel or cross bike model that works for me. Even the smallest frames tend to have insufficient standover.
I currently ride a Kona Major Jake size 48cm and I have no standover clearance which affects my confidence on the trails. I'm looking for a model that will give me a bit more clearance and can serve as my winter road bike, take me on gravel/fire roads, and have to option to do some cross races. I want something that has wide gearing ratios (wider than my Jake) and I'm considering a 1x set up. I'd like the option to put 28mm tires for winter riding and 40mm tires for gravel grinding.
Any suggestions for models I should look at? I'm looking to spend <$2000
Quoted: 3450 Post(s)
Liked 420 Times
I'm roughly your height and I ride 24" wheeled bikes. A huge improvement in fit over larger wheeled bikes.
I currently ride a Giant ARX 24 yet it doesn't have any suspension. I suggest you try one of these for fit if you see one, https://www.giant-bicycles.com/us/bi...-jrdot-24-2020
I have seen high end, high performance 24" wheeled MTN bikes on the market and I suggest you see what you can find where you are.
Now these bikes are called "Youth" bikes but don't let that put you off. For whatever reason, the bicycle industry has been habitually putting people on bikes that are too big for them for a LONG time and shorter adults have not been well served.
Bikes: Road, mountain and track bikes and tandems.
Quoted: 282 Post(s)
Liked 18 Times
I am 5' - 6". I used to cyclocross on a 54 cm (way too big). I have downsized to 42cm (much better). I think that you should find a store with some sub 40 cm bikes if at all possible, and try them out (see what it is like to ride a smaller bike) with the seat adjusted to your preferred height. (measure it from your current bike) Do not forget that your test ride will likely be on pavement, and a bike always "feels" bigger once you are out in the dirt, and especially when dismounting the bike.
Liked 420 Times
I should have looked earlier to see what a Kona Major Jake was.
Try to test ride one of these, Seriously. https://www.giant-bicycles.com/us/bikes-tcx-espoir-24
I expect that you will need to change a few parts out yet try it for basic fit.
https://kidsracing.co.uk/collections...p-evo-drop-bar
1x. Threaded 68mm bb. Custom build options. The 48cm frame recommends a minimum of 68cm bare-foot.
Site mentions 55mm clearance i.e. clearance between fork blades, and chainstay, so a 40mm+ 700c should fit easily.
Quoted: 12 Post(s)
Thanks for the suggestions! In one of the other threads somebody suggested the fantastic website www.99spokes.com to compare bikes and geometries which has really helped the search. I have found, however, that there is a great variation in the standover height the manufacturer claims and what it actually is when you throw a leg over the bike, so it seems that manufacturers measure the SO at different spots along the sloping top tube.
I've tried out a Specialized Diverge, Norco Search, Kona Rove, Salsa Journeyman, Cannondale Topstone, and a Trek Checkpoint. The main issue is that while shops usually have a 52 or 54 in stock, it's less common to have anything smaller especially in the mid-level range. I'm pretty reluctant to buy a bike sight unseen so I'm somewhat limited to the "usual" brands found in my area. At least I've determined that I need to have hydraulic brakes because of my short fingers, (affordable) steel is too heavy, and that a 1x drivetrain probably won't be the ideal option for winter riding.
Second follow up question: The Norco Search comes with 650b wheels in the 48 and 700 wheels in the 50.5. The 48 would be a special order but I tried the 50.5 and have sufficient standover and it felt good riding, though it felt better when they put a slightly shorter stem on it. Any thoughts on how a smaller bike with 650b wheels would ride differently from a larger bike with 700 wheels? I'm a weak hill climber, and I'm not really comfortable above 100 rpm for any length of time (I tend to push heavier gears at a lower cadence), and on bikes with a 700 wheel I seem to prefer a crank arm length of 165 (170 feels like too big a circle for my legs), if that makes any difference.
Third follow up question: on something like the Checkpoint, is it possible to have one 700 wheelset (for the road) and a 650b wheelset (for gravel) or do other things have to change when you change wheel sizes so it wouldn't be practical?
Quoted: 7349 Post(s)
Liked 2,474 Times
It's really impossible to say how the 48 will feel, but my guess is that it would work out well. I put 650b wheels on a bike of mine made for 700c wheels. (I changed the brake calipers to make them reach the rims.) It was a bit of an adjustment but not terribly difficult. I would bet that most people wouldn't even notice it.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
https://velo-orange.com/collections/...-complete-bike
Somewhat unusual with a retro-rando vibe but 51cm Polyvalent with 26 inch wheels might fit you.
Quoted: 1034 Post(s)
Liked 1,290 Times
The Midnight Special comes in a 50cm, 46cm and 40cm. https://surlybikes.com/bikes/midnight_special
