Aero bar recommendations for ultra endurance?
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
Currently I'm using a Control Tech Aero Cockpit Plus, because it's the only (reputable brand name) model that I've found so far that is both ITU legal, and also short enough to comply on a handlebar with short reach (75mm).
However, I'm wanting to look for something that allows the arm pads to be placed further back and also for bar ends that angle upwards rather than straight ahead. Control Tech has a Scirocco model that can be mounted to the stem, so it seems to fit the bill, but that seems to be unavailable practically everywhere (by practically, I'd say trustworthy/reputable site with a reliable international shipping - Like Amazon, where I originally got my Control Tech).
I've searched around and found another brand called Profile Design, that also seems to be relatively popular with the ultra long distance crowd, however their aero bars are very long and therefore not ITU legal. I suppose they could be cut down to length, but since I've not done anything like that before I'm not sure if that's a big deal or no... but anyways, besides them, are there any other brands that I should be looking at? Reputable brands, not random cheap junk which breaks after the first few rides (I used to have a cheap set, the arm pads were made out of cheap plastic, ripped itself right off the screws after just 2 rides).
Syntace XXS?
The ITU confirming Syntace XXS is 200 mm long from the center of the handlebars and places the arm rests behind the handlebars.
Apart from PBP, which ultra events require ITU conformity?
Jedi Master
I got a set of the Profile Design Supersonic Ergo 35c bars earlier this season and like them a lot in the right circumstances. They have the most adjustability of any of the bars I found, so you can get the pads way back and the extensions super short if that's what you're going for. It was pretty easy for me to find a comfortable position almost immediately. I don't know anything about ITU regulations, but if that were something I cared about I would have two different sets of aero bars, and probably two different bikes to go with them.
Kamen Rider
Quoted: 351 Post(s)
Liked 277 Times
Interesting to note that Profile Design used to have short ITU draft-legal bars but no longer list any in their product catalog. Wonder what happened?
Syntace has a couple of interesting models, I'll check em out.
The Supersonic Ergo 35c is probably my second best choice if I had to make a pick for its u-shaped arm rests and flexibility to position them behind the handlebars... just need to trim that length...
Anyway I just use ITU regulations as a reference because the new PBP regulations on aero bars is practically similar, and I'd rather get accustomed to the lowest common denominator rather than ride with a longer bar and then be forced to compromise on comfort if an event allows only short ITU-style bars (e.g. PBP 2023... probably).
The Crank
Anyone know if I can get a pair of Profile Design T3 aluminum - I can’t find them advertised anywhere so I presume they are discontinued.
Quoted: 34 Post(s)
Liked 8 Times
PBP relaxed their usual ban shortly before the 2019 event, but there is no telling what the rules will be next time around. It's unclear to me that they offer any benefits at PBP.
Bikes: Colnago Crystal, GT MTB, Fuji D6 TT bike, Breezer Beltway commuter
Quoted: 35 Post(s)
Liked 13 Times
I like the profile design Airstryke with the elbow pads that rotate out of the way when you're not in aero position. Not the lightest but I appreciate having the extra handlebar position when climbing. And the one piece design makes mounting a headlight on the front end easier.
Airstryke on Amazon
Airstryke on Amazon
Randomhead
Liked 3,697 Times
I was wondering if they would have helped into that pernicious headwind. I certainly rode the drops far more than I usually do, to the extent that I was starting to worry my left arm was getting too weak to be safe. I think most randos I know that use aero bars do it to relax.
Kamen Rider
Quoted: 351 Post(s)
Liked 277 Times
Quoted: 34 Post(s)
Liked 8 Times
I guess I am questioning if the ITU bars would be comfortable enough on a 1200K. They are basically intended for a few minutes at a time when the rider is at the front of the pack. I was having a hard time riding in the drops by day 3.
Kamen Rider
Quoted: 351 Post(s)
Liked 277 Times
The most comfortable way I've found with riding ITU bars is to ride them as if you were riding invisible aero bars -- i.e. you aren't really gripping the end of the bars like you would with normal length aero-bars, and you steer with your elbows. My hands just sort of dangle over the front section (which either has a horizontal bar or U-shaped end, depending on the specific model) more for stability purposes than for control/steering. I've ridden this way for up to 600k -- so no idea if this will hold up for a 1200k -- but I'll say that core strength is the key. Don't hunch and keep your shoulders below your ears (or whatever the correct term is), otherwise its a surefire way down sore neck road.
If you try to grip the ITU bars, that puts your elbows further back and makes you rest on your forearms closer to your wrists than your elbows, which gets uncomfortable fast.
(edit)
Found a photo of Darren Franks riding in PBP:
Notice how his hands are just more-or-less dangling off the bar ends with a very light/minimal grip, rather than firmly gripping them like how you would with a normal time trial bike, or track bike, or on normal length aero bars.
(edit)
Jedi Master
How is that safer than normal length bars? Wouldn't surprise be if PBP changes the rules again to allow normal aero-bars.
Kamen Rider
Quoted: 351 Post(s)
Liked 277 Times
No idea. I'm just assuming they're mimicking ITU rules for simplicity... and as for the reason, I'd make a wild guess and maybe they think shorter bars are less likely to skewer the guy in front in a mass crash sort of situation? /shrugs
Randomhead
Liked 3,697 Times
I think they might not want people hunched too far over their bars. I generally don't see that with randonneurs, they are usually pretty upright.
