Fork and Shock Advise
Old 01-31-20, 03:58 PM
lwindham510
I just got a 2018 YT Capra. I'm currently 6'5 and 275 lbs which i know is heavy for mountain bikes. I was hoping someone could let me know the ideal air pressure for my Forks and Shock. They are the the 170MM rockshox lyric fork. any ideas?
lwindham510 is offline
Old 02-01-20, 05:52 AM
Canker
Quoted: 330 Post(s)
Liked 209 Times in 133 Posts
Not really. You get your sag in the range YT specs and then tweak the air pressure up and down from there to get it to feel how you like it.
Canker is offline
Old 02-01-20, 08:54 AM
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1090 Post(s)
Liked 935 Times in 600 Posts
Lots of how-to videos on YT on how to set-up your suspension. GMBN has a couple.
2cam16 is offline
Old 02-01-20, 04:56 PM
grubetown
grubetown's Avatar
Quoted: 110 Post(s)
Liked 24 Times in 21 Posts
Find a friend to help! Suspension set up is an dynamic process as terrain type, weather, how broken in your bike is, etc all play a role. Start with the set up recommended in the bike/manufacturer's manual and then go from there.
grubetown is offline
Old 02-03-20, 08:16 AM
carlosponti
Bikes: '90 Raleigh Technium Prestige, '90 Fuji Thrill - Gone, '18 Fuji Nevada 1.7 29er, '19 Fezzari Abajo Peak
Quoted: 38 Post(s)
Liked 34 Times in 23 Posts
also might say what shock you have.
carlosponti is offline
Old 02-03-20, 08:18 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
nice bike, and good advice already provided.
Set the sag and ride your local trails and fiddle to your own preferences.
For example, I prefer mine a tad more than usual. YMMV
qclabrat is offline
Old 02-05-20, 12:35 PM
bikeme
Quoted: 136 Post(s)
Liked 57 Times in 31 Posts
Sag is generally set at 20% (+/- 5%) of suspension's full travel for XC use (forks with 100-120mm travel), 25% (+/- 5%) for trail (130mm+). You should be wearing your full kit with shoes and your hydro pack when setting sag. Put in enough psi so you get 25% travel of the 170mm when you sit on the bike.
bikeme is offline
