Follis ~ bicyclette française masochiste
Quoted: 5888 Post(s)
Liked 3,471 Times
That will take a lot of evaporust won't it? I thought that's why people will use an OA bath because it's less expensive.
Quoted: 765 Post(s)
Liked 660 Times
https://www.bikeforums.net/classic-v...evaporust.html
And it doesn't even use up that gallon and a half, since you can pour it back into the original jugs for re-use later.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Very cool. I'm envious! I love the eccentricities of a French bike. Can't wait to see more
Death fork? Naaaah!!
With a Gitane, a Motobecane, and a Pug in the barn I would have been all over this.
Top
Top
Liked 3,471 Times
Quoted: 3464 Post(s)
Liked 2,829 Times
I think you will like how the bike handles.
that rear derailleur ... every time I see one I am reminded of the movie Brazil for some reason.
Quoted: 1829 Post(s)
Liked 3,376 Times
About the only way you could have made life harder would be to use a Cinelli Bivalent hub and freewheel.
Steve in Peoria
Quoted: 1361 Post(s)
Liked 423 Times
Peeled it down with a bit nuisance and seized aluminum crank caps.
Prior service shows an attempt with a poor Allen wrench and was partially rounded out. So, what to do? Cut a slice across the cap and with a screwdriver, tap one half of it counterclockwise. Both sides done, the rest disassembled with ease. Surprisingly, the bearings were well greased and in great condition. The Nervar bottom bracket spindle is beastly and uses plastic bearing cages. No spindle protective sleeve. (Pics later)
Frame bath with mild liquid formula Bar Keepers Friend. Note difference of the clean in progress right seat stay vs the left. Chrome has rough areas but overall, the frame is solid and ding free. Paint chipped and flaws, I'm not planning to touch it up. Cleaner wax and done.
The insides are getting an overnight white vinegar soak with follow up Seafoam coating.
Likes For crank_addict:
Liked 3,471 Times
This is going to clean up nicely.
Liked 423 Times
Embellished stem and handlebar fun.
Likely the handlebar wrap is original and thought why not just leave it?! Not perfect but fits the bikes overall appearance. Going with flying French flag colors by keeping the white AME hoods, red wrap and using blue cable.
Drilled the customary small holes at the stem split to prevent any potential stress risers. Belleri on stem is spelled different from handlebar. Mothers polish for a quick rescue.
The original long stem bolt was snapped at the top! Now replaced.
Had the TA stem cable guide stashed away and figured this is appropriate here.
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
https://www.mcmaster.com/1061t25
Best Wishes: Mike
Booyah Hubba-Hubba!!!
Likes For Nemosengineer:
Liked 3,471 Times
I've never seen the TA stem cable guide. Zip ties are lighter and cheaper for a weight weenie build but not really period correct,
So are there some threads on drilling holes on the stem split to relieve any potential stress risers? I haven't read about this. I have to admit, bar or stem failure on an old bike is something I think a little bit about. It's such a bad place for a parts failure. It's one of the reasons why I like running a new Nitto bar and stem on my builds.
Likes For bikemig:
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
In the case of stems, you'll notice a lot of them already have a 'cul de sac' at the end of the split in the stem, this is to prevent cracking. A few varieties of stems didn't have this and are prone to cracking at the 'end of the road' unless you drill a 'cul de sac' at the end. I prefer using a step bit (uni-bit, whatever you prefer) at the end of the split to get a nice, round bulb where it needs to be.
PM me your cotters
Liked 590 Times
PS: Kurt has a great write-up on death stems here: https://theheadbadge.blogspot.com/20...-and-atax.html
Many companies were guilty, pretty sure this is a 3TTT stem here, you can see where it's cracking, at the corner, 90° angles are a common fatigue point, focused stress, and why the drill-out trick is a good preventative measure.:
And here's an instructional picture from Chas:
Likes For francophile:
Liked 3,376 Times
I always thought the TA cable guide was an interesting device. Not sure how much difference it makes, but kind of fun.
Plus... it is one more vote for the "cables behind the bars" configuration!
I hope you can find new grommets for it, though.
Steve in Peoria
Liked 423 Times
Dig the headbadge denoting 'tandem'.
Inside of Pepe le Pew tubes are decent. Odd there's no gas vent holes or access to the seat stay tubes, so no way to spray protectant for the insides. I suppose could drill a small hole but will leave it for now. Frame structure is sound.
Liked 423 Times
Not wanting to rethread the crank, these Atom pedals with the 'droit' threads arrived. They spin nice though will get a full service.
Quoted: 2338 Post(s)
Liked 2,822 Times
This started with a tubular tire purpose.....just goes to show that tubies are the devil "tubies rhyme with T and stand for Trouble, right here in C&V city"
Likes For squirtdad:
Liked 423 Times
The irony, er contrary is I'm planning to use Belgium made Weinmann concave 700c hookless clinchers. Situation awareness, we continue on...
Frame is spiffed enough with corrosion removed and coated inside and out. With chrome degraded in many areas, it wouldn't pay to redo but for a complete coverage of paint. I like and accept the way it is, looking forward to the next phase of component clean and service.
As if it matters.... call it a 6 plus pounder-
Follis 172 fork
Follis 172 frame
Liked 423 Times
Not much to update other than the frame is ready for the build. When first seeing the exterior, I was concerned of corrosion on the insides, however its now really clean and oil fogged.
Quoted: 7348 Post(s)
Liked 2,470 Times
Liked 3,471 Times
A Follis is on the short list of bikes I'd like to own; this is a cool project.
