Vintage Kent Rollin' Thunder
Hi, I'm new here.
I have a neighbor who collects junk off people's curbs, and one day when I was walking my dogs past, I noticed this beauty. My research indicates it's a late 80s-early 90s Kent Rollin' Thunder, and it's obviously a 10 speed with overdrive. I was really excited when I saw it, since my current bike is a crappy Walmart $80 Schwinn BMX.
Long story short, I picked it up today for only $5!!!!
Obviously, it's missing the seat and pedals, but the tires hold air, I think they're original, and everything looks straight, so no wrecks. The paint is hardly even scratched! There's a bit of rust on the crank arms and the front reflector mount, but I can fix that. The bearings and freewheel mechanism are great, and the brakes work excellently, locking up either tire when I want.
I think the derailer is shot, it doesn't seem to want to shift(although I'm not sure since it's not rideable yet) and it seems to leave the chain a little slack.
I've got a few questions:
I think the front tire is backwards, thoughts?
Parts like the derailer should be fairly universal, right? I just want to make sure Kent doesn't use some weird size.
I've heard only 1,000 of these bikes were made, does anyone know?
Feel free to chat about the bike, but advice would be awesome. I have a nice bike shop nearby, so I'll probably save up some money and take it over there. I also need to see if the pedals on my Schwinn BMX will fit this thing.
NOTE - The site isn't letting me post pics until I make 10 posts, so I'll post pics when that happens. Sorry!
Quoted: 3780 Post(s)
Liked 3,284 Times
If memory serves Kent is a chainstore brand.
When you are able to post images forum members may be able to identify the actual manufacturer, in case you are curious.
Forum members have an "album" they can post images to.
If you have pictures of the bicycle you can place them there and folks will be able to pull them out.
Another workaround is to upload them to a host site and post the URL here in munged form (software does not permit posting of URL's until a member has ten posts).
Forum Moderator
Quoted: 3059 Post(s)
Liked 6,376 Times
Pic Assist
Likes For cb400bill:
Quoted: 4719 Post(s)
Liked 3,034 Times
Even if there were only 1,000 manufactured, this still only a $5.00 bicycle. It's a bottom of the barrel model, typical of those sold at the X-Mart box stores. It looks like everything is steel, except for maybe the rims, so it's probably very heavy. It's a pseudo ATB in that it styled like an ATB to appeal to the lo\west common denominator consumer but it doesn't have true ATB features like cantilever brakes and triple chainrings. It probably is early 1990s. The freewheel looks to be a standard 28T large cog and it appears to have friction shifting, so just about any inexpensive claw mount rear derailleur should be able to handle the job.
Likes For T-Mar:
Ok good to know. Part of me is disappointed it's not very remarkable, but at any rate, I'm just going to be using it to get around town comfortably, it's not going in a museum, and it's still better than my current Schwinn BMX. Plus it doesn't need specialized rare parts either!
I'm pretty sure the frame is steel, I haven't taken a magnet to it, but it's a little hefty. It's still lighter than my BMX, and the tubing is noticeably smaller.
It's still a neat bike!
BTW - Can someone confirm if my front tire is on backwards??
Likes For JTSpeedDemon:
Bikes: Indeed!
Quoted: 1504 Post(s)
Liked 3,441 Times
Yes, The front tire is mounted backwards (not that it makes very much difference unless you're riding on steep technical trails.)
You can remedy that by unbolting the wheel and turning it around. Don't have to remove the tire.
Brent
Brent
Likes For obrentharris:
Liked 3,034 Times
Many tyres are designed to be directional and in these cases the front tyre is often mounted to rotate in the opposite direction of the rear tyre, on the premise that the rear tyre performs the driving while the front tyre provides most of the braking. Rotational direction is not a concern on hard surfaces but becomes more important as the surface becomes looser and softer. If you examine the sidewalls of the tyre, there may be directional arrows on them. Lacking directional arrows, I would have mounted them as shown.
Likes For T-Mar:
Bikes: Too many to list
Quoted: 1764 Post(s)
Liked 1,119 Times
If the derailleur does not work - the first thing I would check is to make sure the cable itself moves freely inside the housing. If it doesn't, that may be the culprit for the shifting issues
Good luck with it
Good luck with it
Likes For DMC707:
Thanks for the input all! I need to get off my tired butt and get working on it! I'm going to try to recondition the parts as best as I can, as I'm on quite a budget. So first off will be a general lube/adjustment, check the tires, find out what the frame's made of, etc.
I still need to check if my Schwinn BMX pedals will fit. I'd imagine pedal threads are fairly universal?
Quoted: 872 Post(s)
Liked 795 Times
Size of frame tubes mean very likely it's steel. BMX pedal size frequently is 1/2" and MTB 9/16" so may not fit. Excellent chance that cable/housing change or just lubrication will correct rear derailleur problem.
Likes For 2old:
Liked 3,034 Times
As noted, there are two common pedal threads, 1/2" and 9/16". Being a department store bicycle with a one piece crankset, it wouldn't surprise me if the subject bicycle has 1/2" pedals. Be aware that the right/drive side pedal is right hand thread, while the left/non-drive pedal is left hand thread. Most pedals are marked with an L & R on the wrench flats or axle end.
Likes For T-Mar:
Randomhead
Liked 3,662 Times
Kent was someone's house brand, I think. I never figured out who sold them, but they would show up at the shop occasionally in the early '80s. They weren't the worst, but there wasn't a line of us mechanics hoping to work on them.
I doubt there were only 1000 made of any given model. Maybe per week.
Likes For unterhausen:
Seems to be a sizeable corporation, at least now:https://kent.bike/
I'm just glad it's not my brother's Huffy!!
Quoted: 1589 Post(s)
Liked 2,486 Times
Too bad it wasn't a Clark Kent.
Liked 3,034 Times
Kent was never a "house brand". The Kent brand dates back to 1958 and since it's beginning has been owned by Kent International. The company is headquartered in New Jersey, where the bicycles were originally manufactured. Over the years, the bicycles also been manufactured by various Asian sources, though the company has recently brought back manufacturing to a California factory. The Kent brand was marketed through various large retail chains, which may have given the impression that it was a house brand but these retailers did not own the brand, so Kent should not be considered a house brand. It's worth noting that Kent International has revived and now owns two brands familiar to many C& V members; Shogun and Takara.
Likes For T-Mar:
You guys are THE BEST! I took the pedals and seat/post off my Schwinn BMX, and lo and behold, they fit the Kent! So after some lubing, plus adjusting the derailleur cables, and I got to ride it today! I found out the shifters are the non sequential type, so it's really cool to feel for the gears! Took me a little bit, but I'm starting to get the hang of it.
This bike is SO much better to ride than my BMX! It actually fits me properly(my BMX is too small now), plus the 10 speeds are so nice to use compared to a single speed!
I still need to readjust the brakes, but overall:
Thanks for your help, guys!!!
Oh yeah, and I confirmed that there are no directional arrows on the tires(I'll let it be as-is as far as the front tire), and the frame and rims are steel.
Liked 2,486 Times
Turned out nice. The lettering mimics the Specialized brand. You'll have no trouble upgrading now...
Likes For curbtender:
Haha, that's just to ride it! I'd say it's still far from nice!
It's hard to see in the picture, but there's light corrosion on the cranks and the front reflector mount, and the paint needs some help right around the seat post. Plus it needs the brakes to be properly adjusted, plus maybe some new pads.
As far as upgrades, it would be cool to upgrade to front disc brakes, or maybe even double discs. But that needs more budget I don't have, so for now I'm just going to fix it up to ride nice.
That includes a cushy seat! That Schwinn BMX seat is ROCK HARD!
I'm actually going to be using this bike this fall to get to my early morning religious seminary classes, that was part of my motivation to fix this thing up.
Quoted: 1792 Post(s)
Liked 1,671 Times
Stop right there. This bike cannot be upgraded economically to disc brakes, front or rear. Overhaul what you have, get your brakes working properly with new cables and brake pads
SE Wis
Quoted: 2731 Post(s)
Liked 3,356 Times
Just typing that in is more than you should have spent entertaining the thought of that "upgrade".
Eh, that's fine. It was just an idea, and like I said, I don't have nearly the budget for that!
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
That reminds me of the Huffy "White Heat" that I absolutely needed to have circa 1992. I should drag it out of the storage garage and start a thread for it.
BTW, try not to lay the bike on its right side anymore. That's a good way to bend the rear derailleur and mess up the shifting.
Likes For ThermionicScott:
