PVC Bike - Anyone tried it?
#52
wernt GT bikeslobo and similar made out of thermo plastic with aluminum lugs?
#53
My son and I are currently building PVC BikeCars... if you use 1-1/4" Schedule 40 PVC you can reinforce with 1" black cast or galvanized pipe for the basic frame. There is a americanspeedster.com offers plans for several models, but we are building ours to our own specs.
DaveP in Ohio
DaveP in Ohio
#54
PVC Bike frame
I was reading the comments on Bike Forums and I would like to make a suggestion to the PVC bike frame builders. construct the frame using PVC and cover it in carbon fiber then finisn the outtermost of the frame using a fine fiberglass cloth. if someone tries this before I am finished please post the results to this site.
#55
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Sounds like it would be very heavy. You may not be able to get fittings that are needed to fit the different angles needed for a bike. I've done a little PVC plumbing. I don't think they exist. Hope I'm wrong.
#56
Bikes: old clunker
Quoted: 684 Post(s)
Liked 104 Times
Next up: Ape Hangers
#57
rebmeM roineS
Quoted: 653 Post(s)
Liked 345 Times
Oct. 31 would have been a more appropriate date for a zombie thread resurrection.
Trick or treat a day early! PVC-flavored jellybeans? CF coated.
#58
Quoted: 2026 Post(s)
Liked 1,095 Times
Well, today is October 31 and this Zombie thread has been resurrected twice since it was born as an obvious troll over 14 years ago. I can't believe it went on for three pages.
#59
Pvc bi
I was thinking about using schedule 1" 40 CPVC. all I would need is straight pieces no angles. put the pcs. together in the shape of a bike then wrap with carbon fiber. Carbon fiber is a very very strong material, they current way a carbon fiber bike is made; they use Styrofoam or blow up plastic in the saps needed for a bike then wrap those blow up bags or Styrofoam in Carbon fiber. Surprisingly, I watched structural tests being done on carbon fiber bike frames and the carbon fiber is 10x srronger than an aluminum frame bike. that is where I got the idea to use PVC for a frame, I have never seen it done before but someone has be the first to do it.
#61
Bikes: old clunker
Quoted: 684 Post(s)
Liked 104 Times
#64
Well, I did it. Just completed a PVC bike build. Used 1 1/2" for the top tube and down tube, 1" for the seat tube, and 3/4" filled with marine epoxy for the chain and seat stays. The hardware for the head tube, bottom bracket, seat post sleeve , and drop outs are aluminum I purchased from Calfee Designs. They use this hardware for their bamboo bike builds. The joints are wrapped in 3m fiberglass casting tape. I tried to post pics but was not allowed because I am a new member and do not have 10 post. Maybe after i answer a few questions I can qualify as legit.
Likes For wltr w8:
#65
Bikes: 2 many
Liked 323 Times
#66
I did. Do not remember the exact weight but is was 8 lbs plus a couple of ounces. i will weigh the finished bike and reply back.
#67
Total bike weight: 26.2 lbs. Honestly, a little heavier than I expected. I guess all that stuff adds up.
#70
To answer your question re riding , yes I have. As you might expect, it is incredibly compliant. The tire size is 28 but it has the feel of a fat tire bike. I am still getting used to it and confident of it as it very flexible, which is probably not a good quality of a bike. Cruiser pedaling is no problem but I am reluctant to crank down on it. All in all it's a soft it ride, different, and fun. Pics to follow.
Likes For wltr w8:
