'54 Bianchi Campione del Mondo pictures
Quoted: 3449 Post(s)
Liked 2,800 Times
Pretty bike.
I think the blue handlebar tape might be keying off the accent color on the fork at the crown.
The images do not show detail of the rear dropouts, the generation of those might suggest a time period a bit, on an older Italian frame I have they helped.
That project has been at a standstill for a long time. I have the FB crank set, but have to compile a bottom bracket and cotters.
Bikes: A few
Liked 7 Times
All three of the frames posted above have eyelets front and rear, whereas the OP's bike doesn't have any I can see.
Quoted: 39 Post(s)
Liked 32 Times
BTW, the hubs are also not likely original as they were supplied OEM with Bianchi branded hubs. In the photos below you can see the OEM cranks
Quoted: 39 Post(s)
Liked 32 Times
Here are some original faded decals. While I have bought decals from Greg in the past, I would not personally ever get decals for a 50's Bianchi from Greg. His production method with vinyl film does not correspond to the time period. Varnish fix or water slide decals are readily available in Italy.
my name is Jim
Here is the description from the eBay listing. I had guessed 54 based on various pictures I saw. I really appreciate all the info guys. I will love it no matter what but I am very interested in learning as much as I can. I will pop it on the stand today and check to see what I can find in the way of date codes, etc.
[h=3]This is a early 1950's Bianchi Campione del Mondo in excellent condition. Acquired from Pietro M. from Peggio Memilia , a regional Pro Mechanic. He kept this bike safe for over 30 years. The bike was refinished many years ago in Italy retaining most of the original parts. Features some early interesting parts like a early steel campy seat post, Gran Sport derailleur with narrow spring cover, Open C shifters and skewers and early Butchered Brooks saddle. Some parts that are not original are NOS. The clamp that you see on the top of the seat tube is a crest of the Ghisallo Chaple the "Patron Saint of Cycling". The bike has not been ridden for many years. Oh yea it also come with Clement tire covers.
[/h][h=3]
[/h][h=3]
Frame: Columbus tubing
[/h][h=3]Size: 58cm seat tube c-t, 57cm top tube c-c 32 in stand-over.[/h][h=3] Crankset: Magistroni cottered crankset
[/h][h=3]Pedals: NOS Sheffield pedals, Balilla clips
[/h][h=3]Derailleurs: Early Campy Gran Sport front and rear
[/h][h=3]Shifters: Open C Campy down tube [/h][h=3]Brakes: Universal brakes and levers w/NOS hoods
[/h][h=3]Seat post: Steel campy post
[/h][h=3]Saddle: Early Brooks saddle [/h][h=3]Bar: Ambrosio
[/h][h=3]Stem: Ambrosio[/h][h=3]Wheels: Rebuilt wheels NISI tubular rims w/Original Gran Sport Hubs and Stella Spokes[/h]
[/h][h=3]
[/h][h=3]
Flickr Albums
ebay: cicloclassico
70 Pogliaghi ItalCorse, 72 De Rosa, 72 Masi Gran Criterium, 75 Masi Gran Criterium, 77 Melton, 79 Bianchi Super Leggera, 79 Gios Super Record, 81 Picchio Special, 82 Guerciotti Super Record, 82 Colnago Profil CX, 83 Colnago Superissimo, 84 Fuso
Flickr Albums
ebay: cicloclassico
my name is Jim
I am reviving this very old thread because I finally got time to work on this bike and take a closer look at a few things. First off the axle lock nuts are CAM 57. The seat post is 25mm and the seat tube is sleeved. The seat is a Brooks Competition Standard B17. On the underside it says Made in England and the number 19. The seat cluster lug does appear to have been cut down. It appears there was originally a 5 digit serial number. I can't make out the numbers but it might have been ?251?. No eyelets as noted previously and a clamp on rear derailleur cable stop. Shifters are open C as are skewers. Rear dropouts are the long variety. The rear derailleur is one of the early generation narrow Gran Sports with the cable adjuster. More pictures:
Flickr Albums
ebay: cicloclassico
Flickr Albums
ebay: cicloclassico
Quoted: 39 Post(s)
Liked 32 Times
Bikes: 2001 LeMond Nevada City, ‘92 Merlin Titanium, '84 Torpado Super Strada, ‘84 Schwinn Tempo, '81 Bianchi Limites, '73 Raleigh Supercourse
Quoted: 161 Post(s)
Liked 69 Times
Just another beauty in your stable. Thanks for sharing.
Liked 2,800 Times
Thanks for all the info! I am sure you are correct. I should have said maybe a 1954. It was sold to me as a 1954 but I took that with a grain of salt. I have seen other pictures of supposed 1954 Campione del Mondos with the same crank but those were simply unattributed internet photos. I will check the locknuts and spindle as soon as this one pops to the top of my project list. I will also look for any other identifying info. I can almost make out the serial number on the seat lug but it is mostly filled with paint.
I am slowly piecing together my '53ish Italian road bike, it has been a long hunt for a proper bottom bracket. That and deciding on what saddle to place on it.
Just saw the recent post with the close up shots. Yes, later dropouts. I was wondering about those, the early ones were a bit different and used a larger diameter adjuster screw. Sometimes referred to as the BrevO style ends.
Bikes: 1989 Schwinn World Sport. 1994 Diamond Back Response Elite MTB. 1964 Schwinn Typhoon. 1974 Bridgestone Sprinter, 2015 Scott Sub 10 Citybike.
Quoted: 1687 Post(s)
Liked 78 Times
Is it a rider?
my name is Jim
Yep I think that is the case.
Flickr Albums
ebay: cicloclassico
Flickr Albums
ebay: cicloclassico
my name is Jim
I have ridden it but no it is not a regular rider. It rides pretty nicely but the brakes are not the greatest and the Gran Sport is not exactly the crispest shifter. The geometry is pretty relaxed with a pretty raked fork. The chain was originally too short so I have put on a longer chain and pulled the rear wheel back in the dropouts as the RD was having trouble shifting onto the large rear cog. And the chainline is not so good with chain rub on the large chainwheel when on the small chainwheel and in any of the 2 smallest freewheel cogs. Rear wheel may not be spaced correctly or BB spindle may not be the right.
Flickr Albums
ebay: cicloclassico
Flickr Albums
ebay: cicloclassico
Quoted: 161 Post(s)
Liked 69 Times
BTW if you haven't looked at Jim's website...take a look. He has many beautiful bikes to look at. And if you find one that you want to buy he is great to work with.
Bikes: '89 Miele Azsora, '09 Motobecane 700HT
I've always been fond of the 90s celeste, but this one (if they even called it that in the 50s) is fantastic! I don't dare ask the price o_o
Quoted: 926 Post(s)
Liked 1,285 Times
Wow! That is a work of art and a piece of history, all rolled into one.
Bikes: Colnago (82, 85, 89, 90, 91, 96, 03), 85 Cinelli, 90 Rossin, 83 Alan, 82 Bianchi, 78 Fountain, 2 x Pinarello, Malvern Star (37), Hillman (70's), 80's Beretto Lo-Pro Track, 80's Kenevans Lo-Pro, Columbus Max (95), DeGrandi (80's) Track.
Quoted: 176 Post(s)
Liked 196 Times
Simply beautiful. A stunning bike.
Get off my lawn!
Bikes: 1917 Loomis, 1923 Rudge, 1930 Hercules Renown, 1947 Mclean, 1948 JA Holland, 1955 Hetchins, 1957 Carlton Flyer, 1962 Raleigh Sport, 1978&81 Raleigh Gomp GS', 2010 Raliegh Clubman
Quoted: 93 Post(s)
Liked 98 Times
Glad I looked this morning. I can honestly say, "Italian bikes never really caught my eye before this one!" Wow! The modifications seem to only enhance an all ready beautiful machine, and the patina make it scream, "ride me!" Congratulations on a great bike!
Quoted: 722 Post(s)
Liked 353 Times
amazing....do you ride it?
Quoted: 4199 Post(s)
Liked 2,914 Times
Very nice.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Trek 500 Kid
Quoted: 2904 Post(s)
Liked 380 Times
https://www.cicloclassico.com
Gawd that there is bike porn that's whut that is
