To mess or not to mess with tubeless tires-9 months since I added any sealant
Quoted: 35 Post(s)
I have Kinlin XR31t tires which I'm running tubeless with G-one Microskin tires. Several months ago , during the early summer, I was losing pressure and had to inflate them every week or even more often. I took the tires off, checked the valves, re-taped and filled with sealant. No real improvement right away. But I just kept inflating weekly. Then in the fall, something improved, only needed to inflate every two weeks. Now, even better. Just like tubed tires. No more than every three weeks.
It's been about 9 months since I last put sealant in. I have read that the sealant dries out and am thinking that I should add some for flat protection, but I'm afraid if I deflate to add the sealant, then the seal will break and I'll be worse off than if I hadn't added the sealant.
Thoughts ?
Thoughts ?
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
Are you just going to add sealant through the valve? I've never had a problem losing a seal when doing so. I imagine after 9 months you do need to add some.
Quoted: 35 Post(s)
I've never heard of the zip-tie method. I was going to add through the valve. In the past, whenever I've let all the air out, the seal has broken and I've needed CO2 to get the tire to seal again. But maybe after 9 months its stuck pretty good...
I've not had a problem deflating/inflating either G-One All Arounds or Pro Ones. Of course it might depend on the rims too, it seems the overall tubeless experience varies based on specific tire/rim combinations. I've used a bit of derailleur cable as a dipstick for my tires, I cannot get my smallest zip ties thru the narrowest part of the valve.
Bikes: TREK 8000,Trek Domane 4.5,Felt FR
Quoted: 21 Post(s)
I have been running Mavic UST's for over a year. Once a month I check the sealant (Orange Seal) buy removing the valve core then using the Orange Seal dip stick. Takes just a few minutes to check then to inflate.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 268 Post(s)
Liked 447 Times
If one keeps adding sealant every few months as it dries will the tire keep gaining weight and just about fill up?
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I have 32mm tubeless and rode it for 2 winters without adding sealant. Last November i decided to remove the tires, clean the inside and add new sealant. Never had a problem but i was told to add every 6 months, but since it's a winter bike, i'll add at the beginning of the winter.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The first step is to baseline - check using the dipstick method when the tires are first mounted and sealant first added.
Then check again monthly or whenever you clean the chain.
You will know when to add sealant.
-Tim-
-Tim-
I have a set with those rims, and about 25% of the times, or maybe more, my Schwalbe Pro Ones get deseated when I deflate. I have a compressor though.
Chases Dogs for Sport
It would take YEARS -- maybe decades -- of refilling for the dried sealant to just about fill up the tire. The more common problem is that it dries and plugs the valve.
Quoted: 4717 Post(s)
Liked 1,882 Times
The "dried" sealant, in my experience, is a thin skin on the inside of the tire -- sufficiently light that it would be difficult to scrape out and weigh.
Thoughts ?
Thoughts ?
When the new Finishline sealant came out, I switched to that. It doesn't dry out (also cleans up with water) and you pretty much put it in there to last the entire time the tire is mounted. This has worked well for me and has performed just as well as the other more traditional sealants I've used but without the sealant build up and without the need to be checking it. For me, with multiple bikes and wheel sets, this has been a big time saver.
But to directly answer your question, I'd say that at 9 months you're due.
J.
Quoted: 35 Post(s)
I paid pretty close attention to this since I've been running sealants in tubeless clinchers and tubeless tubulars on road bike for about 10 years now. Typical sealants like Orange, Stans, etc... do dry out. Depends on the weather and humidity it seems, but it's about 3 months to 6 months for me.
J.
J.
Quoted: 800 Post(s)
Liked 512 Times
I have/had Stan's in my front and back tyres. My bike hung from the front wheel from the end of September to the start of March. Thinking I needed more sealant, I took my bike off the wall and took off the front tyre.
Splat! A whole bunch of Stan's hit the pavement. No bogger either.
I used the dip stick to check the level of Stan's in my rear tyre and the level was just fine. So I didn't bother doing anything with the rear. I swapped in Orange Seal for the front tyre/wheel now.
I tend to be pretty meticulous about keeping my sealant levels at the recommended level. I have yet to have a month when I didn't have to add at least a little sealant. (And, if you believe the posts on this forum, most people probably wouldn't even check the tires that often, much less top them up.) BUT, to answer your question -- most of the weight of sealant is the water. When the water evaporates (the reason for adding more), most of the weight is gone, too. When you add new, the tire gains weight, but the amount of weight gain is pretty tiny. The "dried" sealant, in my experience, is a thin skin on the inside of the tire -- sufficiently light that it would be difficult to scrape out and weigh.
I have never used Stan's and I have never had a sealant booger. Thickest residue with Orange Seal has been a layer about 2mm thick at the bottom of a tire that sat unused for a couple months.
Based on your comment and noodle soup's, I think we can assume I'm not using Stan's. Ever.
Quoted: 20808 Post(s)
Liked 9,450 Times
Liked 9,450 Times
As far as the OP, I've gotta say that I'd be a little concerned about my tires not staying bead-locked when deflated. Knowing that they'll stay on the rim during a rapid deflation is somewhat comforting and coming off so easily would also make me concerned about burping. Of course, this is without any first-hand experience - maybe my concern would evaporate within the first ten miles, I dunno.
So I started using tubeless (Bontrager Paradigm Elite wheels, Schwalbe Pro One tires, Bontrager sealant) late last year.
I filled each tire with ~1 oz of sealant, and added ~1/2 oz after a couple of months.
The wheels have been hanging on hooks since November.
I checked one recently (took the tire off of the rim part-way) and there was still plenty of liquid sealant inside, no dried hunks anywhere.
Re-seating was a PITA, since the liquid sealant got everywhere, but with a charger hand pump, I got it done.
I added more sealant, and have done several rides since.
Peter
Peter
Non omnino gravis
I had a 700x35 Hutchinson Overide last 13+ months, had sealant refreshed probably 10 times, 50mL a pop. So at least half a liter, and when I took the tire off to toss it, it weighed about 70g more than a new one. Latex doesn't weigh a whole lot, and the sealant itself is apparently about 85% liquid that either evaporates or escapes through punctures.
Quoted: 800 Post(s)
Liked 512 Times
So am I correct in thinking that Orange Seal doesn't create the same kind - if any - boogers that Stan's creates?
