Front wheel lifting off ground when sprinting
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Ja wohl. Und es ist ein Strava Club. #fullforcevoraus!
Quoted: 20810 Post(s)
Liked 9,456 Times
Oh, I'm not concerned about falling off, I'm concerned about the well-being of the bike frame, being clamped in and subjected to stresses that it wouldn't necessarily see in use on the road. Maybe I'm being too conservative, but the few times that I've sprinted on the trainer made me cringe and back off before reaching full ham.
Likes For WhyFi:
Liked 9,456 Times
Well, in the winter I ain't going out on a weekday in the dark and cold, or rain for that matter, so I only had the trainer for some months. I feel good sprinting on it, greatly improved my max output as well, my current max is still from trainer. But I take your point, I never really thought about it before to be honest (like why would they advertise "up to 2000W" and what do people doing Swift races do, they output way more than me I bet).
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Are you on the drops when this happens? If not, perhaps going to the drop position on the handlebars for sprints will shift enough weight forward to prevent this from happening.
Habitual User
Quoted: 4946 Post(s)
Liked 8,087 Times
Liked 9,456 Times
I get where you're coming from about different stresses. I'm going with the belief that high-quality bike frames are built to handle a lot more power than I can put out, even if it is somewhat different. So far, so good. I understand it you don't feel so comfortable with it, though.
Habitual User
Liked 8,087 Times
Likes For Eric F:
Quoted: 3952 Post(s)
Liked 7,297 Times
If I broke a frame sprinting on my trainer, I’d hang it on the wall and brag about it on some silly online forum.
Likes For tomato coupe:
Quoted: 850 Post(s)
Liked 344 Times
I've lifted my front wheel when sprinting before. I'm not Sam Bennett but I'd say I have pretty good technique.
I believe this happens when you imitate a standing start like a trackie. Basically doing a proper lunge and pulling both ends of the bar up. Hopefully the front wheel is only lifting when you first accelerate. Quite frankly, this sounds like a problem caused by you adapting your technique to sprinting on a trainer, where you cannot sway the bike. Stop sprinting on the trainer - or at least stop using trainer sprinting technique on the road. They are not the same.
Like someone said above, you should be pulling on one end and pushing on the other. It helps to sway the bike a little. You don't have to do an MVDP sprint but it doesn't have to be a greipel sprint either.
Maybe try recording your sprint and seeing what your form is like. I'd say cavendish and bennett are good examples.
Liked 7,297 Times
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,470 Times
Likes For SoSmellyAir:
Quoted: 1529 Post(s)
Liked 718 Times
Yeah, I've actually had the front wheel jump a bit sometimes when I give it some from the drops, but only on my weight weenie bike...
Quoted: 529 Post(s)
Liked 255 Times
I do the same thing. When I accelerate quickly, the front wheel comes off the ground. This is on a fat bike, with handlebars higher than a road bike. It's fun.
I recently spend a little time in the city. When the traffic lights turn green, I accelerate with the traffic. When It is busy, they might get up to 30 or 40 kph before slowing down for the next set of traffic lights. I go with the flow of the traffic. If it is only a minute or two before the traffic slows down for the next traffic lights, you don't need massive endurance. But it is dangerous riding at high speed in busy traffic. If I stayed there too long, I might get killed.
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,899 Times
If that's true, it must be entertaining to watch you walk or run.
Likes For genejockey:
Liked 11,899 Times
But, the comment is about walking. Try walking with each arm swinging forward with the leg that's swinging forward. If you can manage it, it will feel really strange. Also, it will LOOK really strange.
Quoted: 528 Post(s)
Liked 230 Times
Everyone I've ever seen stand up on the pedals has done the same thing - pull up on the bar on the side your leg is pushing down. You do this automatically because your leg is pushing the bike to one side and you automatically correct it back. Nobody has to think about it, you do it right the very first time you ride a bike and stand on the pedals.
Quoted: 528 Post(s)
Liked 230 Times
So I tested it again and this time it was no issue. However, I output quite a bit less watts in the drops and leaning forward to push weight forward.
Quoted: 850 Post(s)
Liked 344 Times
If you're changing your technique, you're definitely not going to fully realize your gains instantly. I'm assuming you're trying to do the whole opposite arm/leg thing and it's generating less power than pulling straight up on the bars?
What cadence are you sprinting at? I imagine that the cadence must have been quite slow if you were pulling straight up. Like 70-80rpm?
Try loosening up, swaying your arms and hitting 110ish rpm.
Quoted: 528 Post(s)
Liked 230 Times
I was not specifically looking to practice the opposite side arm push/pull. I was going to do it on my long weekend ride with multiple sub 100% sprints, but then I ended up doing a route with a lot of climbing and I did not want to add extra stress. But I did want to try one sprint on a local segment with leaning forward. So that is what I did the next day, basically one very easy ride with that one effort.
Quoted: 6963 Post(s)
Liked 10,963 Times
I don't understand why this is something the OP needs to practice. It's about as natural as breathing.
Quoted: 741 Post(s)
Liked 412 Times
Depending on how skilled you want to become at sprinting, there is a fair amount of technique to be able to do it and actually go faster. I was out at the velodrome and the sprinters were working on their accelerations. They would accelerate down the banking and ease up after the 200 to go line. I was on my road bike and one of the sprinters joking saying I brought the wrong bike today. I told him it was going to rain tomorrow and I would rather do my endurance ride in the sunshine and do my speed work on the trainer. He replied he would rather work on all the intricacies of sprinting in the sun. He could sit on a trainer and crank endurance miles.
