Any Interest In A Chain Tensioner For Fixed Gear Use
Hi all,
I have an idea for making a chain tensioner that will work with fixed gear drive trains.
I just wanted to test the waters to see if people would be interested in such a device.
It would be about as complex as a single speed tensioner so I guess it would come out somewhere similar in cost.
If such a thing was marketed, would you buy one?
Thanks
Thanks
Pants are for suckaz
Bikes: Hardtail MTB, Fixed gear, and Commuter bike
No. but I'd be interested to see what you've devised anyway. I find it hard to believe that there is a safe way to retrofit a tensioner onto a frame that wasn't designed for it. ENO hubs, Eccentric BB's or just accepting that you need a frame with horizontal dropouts or track ends have all worked fine for years.
Bikes: Specialized Tarmac Expert, Cannondale R700, Specialized Langster, Iron Horse Hollowpoint Team, Schwinn Homegrown
I'm sure if you made one, and it worked, people would buy it. Do you think Edison asked for permission?
Bikes: 1987 Schwinn Super Sport, Surly Steamroller
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
^Truth.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
I personally want the device to convert an old road frame I have and like and the ENO hub is too spendy for me, but you know how often this comes up in the forums so it seems some would be interested.
Why would I do that when working with basic physics principles yields functional devices?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Unless you file for a patent, the Chinese will steal it the first day it is released, and flood the market with cheap knockoffs.
This again?
Why?
Good luck in your pursuit, OP. I thought that international patents did not apply, or would not deter the Chinese factories from making knockoffs. Unless you have a legal team like the large corporations.
Why?
I know you're thinking of a clamp on the chainstay that would hold it in place.
i'll probably break it
they already market something that will make them way more money - they are called bike frames with horizontal dropouts/track fork ends.
i promise you guys, if this was an idea worth pursuing, someone would have already done it.
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
They still move up and down based on which way you are applying force to the drivetrain, plus when they fall out, you are hosed.
The only plausible tensioner would have to be fixed, which really isn't an option as it would have to be attached to the chainstay, which would have a hard time taking stress.
People do mount rigid gears to their frame. See retrodirect drivetrains and certain recumbents. But none of them clamp on on the drive side of the chain, as far as I know.
Why have I never seen a fixed-gear bike with two spring-loaded tensioners? Same slack as a ghost ring without the risk of anything falling out.
Because the slack would really suck. I'm all about some play in the chain, but running double tensioners is an overkill solution to a problem that does not exist.
Your cog is slipping.
Maybe when they don't sell you can approach Bikes Direct about picking up the whole lot of them for pennies on the dollar and incorporating it into some sort of wack Kilo model.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
I think 5-6 years ago there would have been a market but now there are so many cheap frames out there. It may not make sense to buy a $150 way to convert a frame when you can buy a new frame for the same price or cheaper.
coasterbrakelockup
Bikes: surly steamroller w/coaster brake, electra single speed cruiser, specialized rockhopper commuter, no-name single speed folder, 700c ultimate wheel, 24" unicycle, specialized bmx lsd, single seat single speed huffy tandem, pink upsidedown parade bike
Veteran Racer
Liked 764 Times
As an engineer, I've always found that the simplest solution is always the best, i.e. the KISS principle. For over 100 years, the track frame with its rear facing horizontal dropouts (aka track ends) has withstood the test of time as the best and simplest solution for a fixed gear bicycle. The second best solution is forward facing horizontal road dropouts, which have drawback that if the wheel hub axle slips, the wheel can fall out of the frame, creating a dangerous condition. For this reason all of my SSFG bikes have always had either track or horizontal road dropouts, and I've never bothered to convert any of my old bike frames with vertical dropouts. The fact that something complex and expensive can be done, doesn't mean that it should be. The whole appeal to me of SSFG bikes is their inherent simplicity, so it makes little sense to then complicate them with elaborate work arounds due the use of an inapproprite frame design.
My name is Mike, not Cal
