Polishing my crank
Bikes: Yes
Quoted: 3231 Post(s)
Liked 3,874 Times
Polishing my crank
Like "frosting the pastry," "wind surfing on Mt. Baldy," or "shaking hands with Abraham Lincoln," "polishing my crank" may sound dirty but it really isn't.
In this case, it was the result of planning a parts bin build for my recently acquired Cannondale, but then seeing how nice the paint was cleaning up and deciding that I needed to build it up with nicer looking parts. I had considered rebuilding it with the original parts, but when I started stripping it down I saw that they were too heavy and in too poor shape to even give a fair impression for a few test rides to see how I like the bike. So I started going through the parts bin to see what I could use. I've got an FSA Gossamer triple crankset that I've had for over ten years and at this point use almost exclusively for bin builds (more on that later). It's so chunky and badly scuffed up that I never want to leave it on a bike that I like any more, but it's perfectly functional, so I keep it around for quick builds of newly acquired frames.
I thought I'd do that again with the Cannondale, but as I polished up the beautiful, sparkly metallic blue paint, I began to fall in love. And so I started reevaluating what parts I had on hand. I've got some really nice 10-speed Shimano derailleurs and a set of SL-7900 indexed Dura-Ace downtube shifters, but I had no suitable crankset. Then I thought, maybe now is the time to take a deeper dive into the wonderful world of parts polishing. I've got some Mother's aluminum polish, and I've used it to very good effect on parts that were in basically good shape but had lost their luster. The Gossamer crank, unfortunately, started life as an anodized part and more than half of it still was anodized. So, recalling a few instructional threads I'd read here, I decided to pick up some oven cleaner and see how well the trick of removing anodizing works. I figured this crank couldn't get much uglier, so there wasn't much to lose.
It turns out, the trick works really well.
Stepping through this to show my progress, here's the crank with chainrings removed, showing its full patina.
I had tried sanding the anodizing off of the NDS crank arm, but the impracticality of that asserted itself quickly. For the drive side, I used nothing but Heavy Duty Easy Off and a wet sponge to get this result.
Next, I spent some time wet sanding, using 400, 600, 1000, 1200, 1500, and 2000 grit sandpaper, to get to this point:
Finally, a very little bit of work with Mother's Mag and Aluminum polish yielded a very shiny surface, shown here with the merely de-anodized NDS arm for contrast.
Another half hour or so going through the same process with the NDS arm, and I had a matched set.
And, of course, the thing that made this project worth undertaking was that I had some very lightly used chainrings to put on it.
Those with good eyes will see that I left a lot of small scratches. I hear you can work those out with more sanding, but I didn't want to do that much work. It also looks like I didn't sand the NDS arm down quite as well as I did the drive side. I'm OK with that too. I imagine after a few rides even the most perfectly polished part will start to look like what I've got here. The key for me was to get a crank looking nice enough to not detract from a frame that was starting to look nice. The frame isn't perfect either, so this is a good match. I also think the oversized tubes on the Cannondale will be more forgiving to the chunkiness of this crank than a steel frame would be.
Finally, I'd like to explain why I thought this was worth sharing. There have been other threads posted by people more skilled and more patient than myself. They've also left better instructions for how to do this yourself. Apart from being pleased with my own result and wanting to share, I thought it would be worthwhile showing others who, like myself, are impatient and unskilled at this sort of thing that they can, nevertheless, get some pleasing results.
My Bikes
My Bikes
Bikes: Yes
Liked 3,874 Times
Also, I promised in the first post that I'd say more about the history of this crank as my go-to parts bin build crankset.
This crank was original equipment on a 2008 Kona Jake that I bought new. It originally had some FSA logo on it, but that disappeared before I started keeping pictures of my bikes. I used that bike for everything from commuting to cyclocross racing to weekend road rides. The crank has had a hard life, but when I sold that Kona Jake, I put a 46-36 cyclocross crank on it and kept the triple. Since then, it's been on a lot of bikes. Here's a brief pictorial history.
The original 2008 Kona Jake with the original black chainrings
2009 Surly Cross Check (powder coated as soon as I bought it)
2001 LeMond Nevada City, the FSA logo was gone by this point
2001 LeMond Buenos Aires
1984 Pinarello Gran Turismo, last appearance of the black chainrings
1976 Austro Daimler Ultima
1987 Pinarello Montello
1980 Schwinn Voyageur
Now that I've polished the crank, I feel like it has new life. Who knows how many more bikes I might use it on!
My Bikes
My Bikes
Likes For Andy_K:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4688 Post(s)
Liked 5,835 Times
That's a lotta crank love.
Likes For gugie:
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Quoted: 431 Post(s)
Liked 478 Times
My first thought is that this wouldn't work with a square taper bb. Things would get clicky or sloppy after a moving from so many bikes.
But wow, the travel of that triple! It seems rare to find something that works so well that you take it from bike to bike like you have.
Bikes: Yes
Liked 3,874 Times
My Bikes
My Bikes
Likes For Andy_K:
Quoted: 4521 Post(s)
Liked 6,412 Times
Many of the cranks we swap around here have been on dozens of bikes over decades.
I had a "Mighty" Sugino Mighty Competition set that I got on my first good bike in high school, I rode it 1000's of miles then including the first belated overhaul after the BB had the pathetic factory grease washed out before I realized it was going south in waterlogged PDX. I got the tools, a supply of new bearings, proceeded to carefully replace bearings and grease monthly for several months to mitigate the damage to the cups and spindle. After that frame broke, it was eventually moved to a Raleigh SC that was also ridden many 1000's of miles before that was stolen.
I would bet good money its still going strong as are all of the old cranks I have acquired here and on the bikes I have also gotten from all different sources.
Just my 2 cents and I know it seems like some don't hold up.
I did have one that I thought was creaking, turned out to be a cracked frame.
Quoted: 2432 Post(s)
Liked 641 Times
Blue Magic polish is much better than Mother's or anything else.
In the 2000's I had a sports car with very expensive HRE wheels which were non-clearcoated polished aluminum. I was living in NJ unfortunately and the rain up there is very hard water. The water spots it left after every single rain shower were horrific, almost like it was corroding the aluminum. I tried Mother's and every other store bought polish and nothing would get rid of the spots, not even a little bit. Then I came across Blue Magic at Advanced Auto and it completely wiped them off with no effort. Now I use it to restore and polish up vintage bike parts. Mirror finish after wetsanding.
https://www.amazon.com/Blue-Magic-40.../dp/B000BO8Z9I
Likes For Lazyass:
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
I've got the same crank. I picked my copy up at the coop just to try the outboard bearing thing. I was actually quite impressed with the lightness but the look bothered me. I will say I use much smaller rings. It usually has 24-41-bash guard. Mine is also grossly underpolished. Frankly I should use it on any bike I ride a lot because it's an excellent crank.
Likes For 52telecaster:
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,108 Times
That looks real nice Andy. I did something similar once with a set of I believe Veloce cranks. They had that cheap plastic looking dull gray finish (no not the Century finish) so I did a similar process sanding off the finish and working my way down to 1000 grit paper. I then made some water slide Campy shield logos to replace the ones I sanded off.
Likes For Spaghetti Legs:
Bikes: Yes
Liked 3,874 Times
I haven't had any complaints with Mothers, but I'm always interested in different products. I have no idea how any of them work. With Mothers, I know if it turns dark gray when I rub it on it's probably going to work. I don't know if that's a chemical reaction or the result of light abrasion. Blue Magic claims to be non-abrasive, so it must be triggering a chemical reaction.
I did have one case where an old stem wasn't improving with Mothers and I had to sand it a bit. I don't think it was anodized. It was just extremely weathered. After sanding it shined up pretty well. I wonder if Blue Magic would have worked better in this case.
My Bikes
My Bikes
Bikes: Yes
Liked 3,874 Times
My Bikes
My Bikes
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 281 Post(s)
Liked 962 Times
I always love to show pictures after I polished my crank. This is on my '71 Bob Jackson.
One thing I found important after spending a lot of time polishing my crank was that I also needed to wax to keep everything clean. To be clear, I mean wax my chain.
Bikes: Numerous
Liked 3,108 Times
Held the shine pretty well and decals were great. I think I brushed a little clear coat on top and they still looked good when I sold the cranks after a couple thousand miles of fair weather riding.
I found a couple pics. One is the crank after about 3 years of use and the other is before the strip and polish.
Quoted: 1372 Post(s)
Liked 1,754 Times
I picked this home made grinder up at a yard sale one day for a very small cost...
I can achieve terrific results in very short order with it. I did, however, have to buy/install a cloth wheel and buy a couple of sticky of polishing compound...
The results are top notch, in my opinion...
Likes For randyjawa:
Bikes: Numerous
Liked 3,108 Times
Looking back at the old thread I realize in post #13 I promised two pics but only posted one, which is the before pic. The clear coat was a little brush on Testors decal clear coat, which I put on directly on the decal without any other prep. I was worried there would be some kind of ridge or line where the clear coat ended but O was careful and nothing showed. Was sounds like a good idea but I didn’t do anything like that and just left the metal bare.
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3898 Post(s)
Liked 6,506 Times
Polishing my crank
Likes For SurferRosa:
Quoted: 880 Post(s)
Liked 2,303 Times
I use Mothers on most alloy parts and it stays nice for quite a while . It seems to have a protectant built into it. I live in Southern California so rain isn’t an issue. My bikes are stored indoors in a dry environment. I have had to sand the oxidation out of parts before because they were just so bad but always use wet & dry paper with water . I then finish with mothers.
This bike was the worst I ever dealt with…rust and oxidation
Over a year after polishing
See “ Rusty Resurrection”, joesvintageroadbikes .Wordpress
Likes For Kabuki12:
Quoted: 3814 Post(s)
Liked 6,734 Times
Likes For nlerner:
I don't know.
Quoted: 321 Post(s)
Liked 860 Times
to the OP, thanks for posting this. As a person who's watched videos on YouTube of people who bring back old tools to mirror finishes, I admire your work. I wish I had the patience/time to do it.
Quoted: 1645 Post(s)
Liked 838 Times
On a related topic, how do I choose/find a good bench grinder/polisher?
I was ready to buy one a few weeks ago, after I decided that I had enough sanding and polishing my components by hand.
What brand and model should I get?
Tried to shop for one at .my localHome Depot and was surprised to find out they did not carry any.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Bikes: Yes
Liked 3,874 Times
As a said above, one of the reasons I shared this was to show the results you can get without really knowing what you're doing or putting a lot of time into it. I'm really not the kind of person who sticks with things until they're perfect. I'm more the kind who starts off with great intentions and then very quickly decides "eh...close enough" and that really does apply here. I used several different grades of sandpaper, which might give you the impression that I put in a lot of effort, but I probably only spent 5-10 minutes each time around.around. The end result wasn't a perfect mirror finish, but it went from looking like crap to looking like a good component does after a little bit of use.
My Bikes
My Bikes
Bikes: Yes
Liked 3,874 Times
Honestly, if it oxidizes evenly I'll probably just leave it. This isn't a show bike or anything, but I didn't want it to look totally beat up.
My Bikes
My Bikes
