Straight bars vs drop bars
Bikes: Specialized cross trail, surely pugs, 2 mongoose beast
What are the pros and cons between the to. I'm liking the narrow width but not really being all hunched over. (Or is that something to get used to). I am looking for a all purpose bike and want to thin the heard. I have a Surley pugs fat bike and a older cannondale touring bike that I'm trying. I'm not liking the shifting of the cannondale on the drop bar. Are the newer style shifter a lot easier to use. Really like the thumb shifters on my pugs. I do crushed lime stone riding, city hauling the kids in the trailer, and gravel.
Thanks
Thanks
George Krpan
Quoted: 12 Post(s)
I run an upside down north road bar. It uses mountain bike brake levers and shifters. Road bike brifters can also be used on this bar but you might have to devise a shim because drop bars are 23.8mm in diameter, mountain bike bars 22.2mm in diameter. I hate drop bars.
I have my straight bar controls and levers on figure 8 bend trekking bars.. offers many hand hold change positons ..
Aka ' butterfly bars '
https://www.google.com/search?q=trek...w=1152&bih=982
So choices are not either/ or , there are more options.
All the 22.2 tube controls will transfer to Trekking bars , like Grip shifters
(Rohloff only makes a 7/8" tube grip shift)
and the combined Brake shift levers and MTB Hydro disc brakes ..
The hand position option is Near Or Far reach rather than Down and Up
sides like climbing bar ends are there too, like hands on the hoods .
swap is simple ..
swap is simple ..
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Thanks
Thanks
Being hunched over is a function of frame size, stem rise, stem length etc, not just handlebar shape.
Quoted: 4560 Post(s)
Liked 2,802 Times
Drops felt more stable and less twitchy, to me. They don't overreact to user input. And, sure, the narrower width helps in traffic. Unfortunately a neck injury makes it too uncomfortable now for me to ride low drop bars, although some spacers or a different frame geometry might help.
I haven't tried a bike with narrower flat bars, no idea how they handle. My current bike with upright bars is comfortable but twitchy. The bars are wide and while that may seem comfy and friendly to newbies, it overreacts to every tiny input. And in group rides or tight traffic it feels like I'm gonna bump into something. I'm considering trimming an inch off the ends since I usually grasp the bar closer toward the center anyway.
The old style friction shifters took a little practice. They work better on the downtube, which minimizes the slack and know-nothing feel. But they're handy on the stem for a more upright and leisurely feel. You can get used to them pretty quickly with practice.
I never tried bar-end shifters, just seemed like a bad idea -- putting the input on the ends of the bars rather than the center of the bike seems likely to throw off the balance.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
@GeoKrpan has a nice setup that might accommodate your multipurpose needs.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Have a good fit, and reasonable mobility in your back and hips, and a good core and there shouldn't a whole lot of hunching going on.
Bikes: Giant Escape 1
Quoted: 136 Post(s)
I have both kinds of bikes. I prefer the flat bar for several reasons:
1. Width - I cut my flat bar so that it is not so wide and is just slightly wider than a drop bar. It's the width of my shoulders so that my hands are in a straight forward line.
2. Hand positions - I do not find this to be a problem. I have used bar ends and they will give you extra hand positions if you need them. When I ride the drop bar, 90% of the time I am in hoods or the tops. I seldom ride in the drops. Flat bars accommodate Ergon-type grips which are more comfortable than any position on a drop bar.
3. Body position - I prefer being a bit more upright as it gives me better vision which I find valuable. I suppose I am a bit more visible to other users of the road as well.
4. Better access to controls - I like having the break levers and shifters literally at my fingertips. I do not like reaching for them. I also like having shifters with indicators on them so that I know exactly which gear I'm in. I have developed a shifting system that works well for me and the indicators really help me stay within the "system."
5. Mirror - a mirror (which I feel is a must for all riders, even more so than a helmet) works better on a flat bar vs. drop bar.
I ride between 1,000 and 2,000 miles each year. I ride almost exclusively on roads and routinely do rides of 25-plus miles with longer rides of 50-75-100 miles thrown in. My typical speeds are about 16-17 mph. I call myself a recreational rider.
Beicwyr Hapus
^+1
I had to check to make sure I hadn't written the above post myself.
Other Worldly Member
Quoted: 194 Post(s)
Liked 136 Times
Flats on the beach just didn't give me many choices ploughing into steady ocean wind so I tried Salsa Woodchippers. I'd estimate over a half-dozen hand positions. They work great and make the transition between road and beach bikes super easy. I don't miss the near constant (high) position of flats and can nearly mimic with hand positions. I have to be much sharper on riding technique. These are 46 cm bars.
Make ******* Grate Cheese Again
Bikes: 2016 Specialized crosstrail comp disc
I only go to straight bars.
Every time I vary from this rule, mens keeps hittin' on me.
Bikes: Breezer Uptown 8, Jamis Renegade Expert
I have one of each.
Well the first bike used to have a flat bar but now it has a trekking/butterfly bar for greater variety of hand positions.
The drop bar is on an adventure road bike. The saddle, handlebar, etc. are all set up so that I can ride it with a slight forward lean. While my torso isn't perfectly upright, it's close enough that I have no trouble swiveling my head around to observe traffic - and I don't have any special neck flexibility either. That is why the type of frame on this bike is called "relaxed geometry". The one that the the OP is talking about is an aggressive geometry bike, where you're leaning a lot more forward for that racing posture. The LBS of course made sure I got a bike with an appropriately sized frame then put me through a basic fitting session.
If you have a road bike and you're really hunched over, your frame could be too aggressive for your tastes, or you have the wrong size of bike, or you haven't been fitted properly to your bike.
Bikes: 16 Haibike Sdruo Cross SM
Quoted: 30 Post(s)
I live in a hilly city, road bike just work better for climbing out of the saddle. More power and more natural feel. The flat bars holding the bar ends up hill don't have the leverage I have found out.
Quoted: 7652 Post(s)
Liked 3,478 Times
Drop your bars flat and they may bounce back up into your hands. otherwise you will need to bend over to pick them up, and you mention you don't like bending.
(avidone1 already won the thread .... mine is a poor effort by comparison.)
Everything everyone else has said is true. There is no "better" or "worse" there is only preference. I have done thousands of miles of city commuting on flat bars and as many on drops. Both work equally well, if they are set up right.
When you say "older cannondale touring bike" and "I'm not liking the shifting of the cannondale on the drop bar" I have to ask, how old and which model, does the C'dale fit you really well, and does it have brifters (combined brake-lever/shifters) on the bends of the bars, or on the down tube?
I have an old C'dale tourer, and it is a little long for me (came with a ridiculously long stem too) and with downtube shifters (which were a pain.) Even with the brifters I installed, and a short stem, the reach is a little long. On a bike which fits, i generally ride "on the hoods," that is, with my hands on the brifters, so the controls are always right there ... my fingers are resting on them, just as they would be with a flat bar.
I don't find thumb shifters easier or harder to use, just different, but what I like has nothing to do with what you will like.
As for bar width, a wider bar slows the steering a little and feels more stable. If you cut a flat bar too short your bike will be unstable and hard to control. About 44 cm (average width of a drop bar) ought not to be too bad ... stem length will play a part here too.
Ninety-nine percent of the time I would recommend drop bars for every situation except dedicated tough-trail MTB riding, but if you do a lot of crushed rock a wide flat bar might give you more stability, and if you are towing kids in a trailer in traffic ... you are crazy? No, I was going to say, you would want to have the best possible view in every direction. However, for crushed rock you would want a pretty wide bar, i would think (I would,) and you like a narrower bar.
If it weren't for the gravel and particularly the crushed rock I'd definitely recommend a butterfly bar such as fietsbob recommends in post #3 . You can set them to a variety of angles and grab them almost anywhere to get good aero or an upright posture and whatever else you might need ... but I wouldn't want all that bar out there if I was riding crushed stone. Just a personal thing, can't prove anything.
Bikes: 2005 Gazelle Golfo, 1935 Raleigh Sport, 1970 Robin Hood sport, 1974 Schwinn Continental, 1984 Ross MTB/porteur, 2013 Flying Piegon path racer, 2014 Gazelle Toer Populair T8
Quoted: 396 Post(s)
Liked 8 Times
Flat bars just don't work for me, the put my hands in an awkward position that causes numbness without any options, but they do work great for maintaining control in challenging conditions. Just too limited for me.
Drops are a little better as they offer some options, but I never use any position below the hoods. The top position is too narrow for my taste as it doesn't offer good control on rough surfaces, especially riding one handed such as when signaling. I really dislike having the brake levers in a position I never use. IMO, they get far more credit then they deserve, and are actually rather marginal for most uses.
Traditional Dutch and Northroad bars offer day long comfort, and are well suited for most uses when on bikes they are intended for, which is why they've been so widely used all over the world for so long.
Trekking bars have the advantage of doing everything flat, drop, and traditional bars can for those who rarely, or never ride in a full drop position.
Bikes: Litespeed M3, Trek Fuel EX7, Giant Defy 1
I like drop bars. They provide good leverage out of the saddle. I mostly use the flats and hoods when riding, but I really like the drops when downhill or on the occasional flat section. I think ultimately it comes down to what works best for you and is most comfortable, and what will allow you to enjoy your bike and rides more.
Quoted: 1062 Post(s)
Liked 665 Times
Horses for courses. I've never been able to ride comfortably in the drops, and flat bars pound the hell out of my wrists. I can ride all day on north road style bars, and they are now on all of my bikes. They provide sufficient control for urban streets and rails-to-trails that are typically crushed limestone or hard clay around here. Swept bars have my hands at or behind the centerline of the head tube.
Naturally they'd be out of place in the peloton, but a lot of things about me would be out of place in the peloton.
Quoted: 185 Post(s)
Liked 36 Times
Pretty much all the issues that people have with drop bars can be put down to "get a bike that fits you properly".
I ride both, but if I'm riding a century I'm picking drop bars.
My road bike has drop bars--- for me, the drops are mostly useless, except for short (I mean SHORT--- less than 60 seconds.) stretches, or if hitting the brakes. I've tried the flipped north road setup, and the drop in the middle increases the reach too far. I'm thinking about some flipped bullhorns.
Quoted: 5224 Post(s)
Liked 3,582 Times
my wrists couldn't take the straight bars
Quoted: 27 Post(s)
I am pleasantly shocked at how many have given the correct answer of neither.
You can create the best primary position with instant and total command of the brakes and shifters with 22.2 bars and ergo grips.
With my wrists, swept back is much better than straight.
Many northroad or albatross or whatever bars actually offer as many useful alternative hand positions as the overrated drops.
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
In a nutshell, drop bars allow more hand & body positions. On long rides, hands can get fatigued or nerves can get impinged, so it's nice to be able to move around so you don't develop discomfort or numbness. And moving from the top or the brake hoods to the lower part of a drop bar gives you a more aerodynamic body position, helping you maintain a higher speed or helping you cut through a headwind.
If drop bars don't float your boat and straight bars don't offer the hand position(s) you're looking for, there are other options out there, too. Trekking bars, bullhorns, and all sorts of different swept bars (porteur, albatross, north road...).
Bikes with drop bars do tend to position your body forward a little bit, but if you're "all hunched over" while riding on the hoods, the bike might not be well-fitted for you. You need to be riding an appropriate frame size, plus the stem angle/height/length and and saddle height/angle/position all need to be adjusted to get you in a good riding position.
Some bikes with flat bars also tend to position your body forward, so it's not just a function of handlebar shape. You wouldn't sit bolt upright while riding trails on a mountain bike, for example, but might on a cruiser. Different bikes have different geometries for different types of riding.
If there was a perfect "all purpose" bike, there wouldn't be so many kinds of bikes!
If your riding is mostly on pavement and limestone, and you sometimes cover long distances, I'd opt for a touring bike over a fat bike. Touring bikes are at home on the road and they're designed to be comfortable for long rides. They can typically take wider tires than racing-style road bikes, giving you plenty of rubber for limestone trails. A 700c x 32 mm tire will give you plenty of rubber for limestone trails. (Or 27" x 1 1/4" if you're riding older 27" wheels.)
On the other hand, if you occasionally ride on snow, sand, or mud, the fat bike can make your riding much easier. The big tires help you float on top of stuff that skinny tires would sink into. But they also add a lot of rotating mass, and it takes some energy to move those things.
Being that it's a touring bike, I'm guessing you might have bar-end shifters, aka "barcons". They're nice on touring bikes since they're darn near fail-proof. You don't want a shifter failure on a bike tour miles and miles from nowhere. If you're having a hard time with them, it might be a matter of technique. If you grab just the lever, it might be hard to move it precisely enough. But if you grab the end of the bar and use the back of your hand to move the lever, it should be a piece of cake to shift.
With that said, newer-style integrated brake/shift levers, aka "brifters", are pretty darn nifty. With integrated levers, you can shift or brake using the same levers without needing to reach somewhere else to shift. And most integrated levers can be reached from the hoods or the drops, so they're completely functional from multiple hand positions.
Quoted: 396 Post(s)
Liked 8 Times
I have a drop bar road bike, and the issue isn't so much comfort, but rather the face down riding position forced by positions other than the top, that keeps one focused on the road. For those of us who don't consider cycling a "sport" drops are rather limited.
Super Moderator
Liked 927 Times
Same here. I put mine in a vise and bent them in a bit, to improve the wrist angle. It helped, but I need to give them a bit more bend.
