Specialized S-Works Roubaix
2016 Specialized S-Works Roubaix SRAM etap with upgrades
S works FACT 11r carbon, Endurance geometry, 12x142mm thru axle, future shock suspension, 20mm of travel flat disc mounts, 58cm
S-works FACT carbon, 12x100mm thru axle fork
Roval CLX 32 Disc win tunnel engineered , carbon rim 32mm depth,Roval AFD hub, ceramic speed bearings, 21h front wheel
Roval CLX 32 disc, carbon rim, 32mm depth, Roval AFD hub, ceramicspeed bearings, 24h, rear wheel
Turbo Rapidair tubeless, 700x28mm , front and rear tires
SRAM red etap, wireless front derailleur
SRAM etap, 11 speed, wireless, with ceramic speed OSPW coated pulley wheels and carbon cage upgrade, rear derailleur
SRAM etap hydraulic disc, wireless shift levers
SRAM red 22, 11 speed, 11-32t, cassette
SRAM Red chain
SRAM Red 22, BB30, 50/34T with Quard D-zero powermeter, crankset
50/34t chainrings
SRAM BB30, ceramic bearings, 68mm, no spacer, bottom bracket
S-works SL, alloy, titanium bolts, 6-degree rise stem
Easton EC90SLX carbon handelbar, 46cm
S-wrap w/sticky gel tape
S-works power, 155mm, carbon rails, EVA foam, carbon base saddle
Specialized CG-R, FACT carbon, single bolt, 27.2mm seatpost
SRAM Red etap, front and back hydraulic disc brakes
Extra set SRAM red etap batteries
Lightly used and always professionally maintained at Beachwood Bikes
if ordered , unavailable till 2022
$7500.00 firm
SRAM Red chain
50/34t chainrings
$7500.00 firm
